Toymods » Tech & Conversions » Turbo 2T questions
silverfox
Cabooture QLD
Turbo 2T questions Wed, 16 July 2003 11:03 Go to next message
ok i'm currently working on my turbo 2t project and i need to know where would i pick up a oil feed on the engine for my turbo , would i have to T-off at the oil sensor thing? would it have enough pressure to reach up to the other side of the engine
and what kinda boost could a 2t with stock internals take before i had to lower the compression?
Re: Turbo 2T questions Wed, 16 July 2003 11:11 Go to previous messageGo to next message
You could have a look at and adaptor on a 3TGEU! The one that sits under the oil filter.
silverfox
Cabooture QLD
Re: Turbo 2T questions Wed, 16 July 2003 11:44 Go to previous messageGo to next message
so that woudl work on the 2T then ? where could i come buy one of these?
Re: Turbo 2T questions Wed, 16 July 2003 11:47 Go to previous messageGo to next message
I'm not sure if it would but the blocks are very similar. And I have no idea where you could get one.
inferno
Re: Turbo 2T questions Wed, 16 July 2003 13:30 Go to previous messageGo to next message
yeah it would fit by swapping the oil filter screw in the block with the 3tgteu oil filter screw which is longer, but finding those parts would be very difficult. best idea is like u said a T piece off the oil pressure sender unit with rubber oil lines around the block, should get enough oil to the turbo that way.
TA22-3SGTE
MACKAY
Re: Turbo 2T questions Wed, 16 July 2003 13:33 Go to previous messageGo to next message
Use a tee piece into the sender unit hole but make sure you use a steel tee and fittings as the brass ones have a habit of cracking under heat and vibration .
I fitted a high compression 2T with fuel injection and bolted a 1GGTE supercharger on the side , Ran 12psi and had no ignition control and it used to detonate between 3000 - 4000 rpm but just drove through it and never did any damage so with good fuel and ignition control as not to get any detonation I think 15psi would be OK !!!
Trevor
silverfox
Cabooture QLD
Re: Turbo 2T questions Wed, 16 July 2003 15:31 Go to previous messageGo to next message
holy smokes TA22-3SGTE i didnt think a 2t woudl take that much ? was that stock ?
juzzo84
Hornsby, N.S.W
Re: Turbo 2T questions Wed, 16 July 2003 21:06 Go to previous messageGo to next message
here is a pic of the 3t oil feed that they are referring you to.
justin Cool
http://img.villagephotos.com/p/2003-7/284437/3toilfeed.jpg
http://img.villagephotos.com/p/2003-7/284437/3toilfeed1.jpg
http://img.villagephotos.com/p/2003-7/284437/3toilfeed2.jpg
*edited by mod. to line up pics*
[Updated on: Fri, 18 July 2003 07:54] by Moderator
juzzo84
Hornsby, N.S.W
Re: Turbo 2T questions Wed, 16 July 2003 21:07 Go to previous messageGo to next message
its the line that comes out from under the oil filter, its for sale if you want to buy it.
justin
TA22-3SGTE
MACKAY
Re: Turbo 2T questions Wed, 16 July 2003 21:17 Go to previous messageGo to next message
silverfox
Yes that was a old motor we pulled out of a wreck , when we first put the blower on it would onle rev to about 6000 rpm so I put a larger cam and heaver valve springs in then it used to rev to 8000rpm and very smooth .
Trevor
silverfox
Cabooture QLD
Re: Turbo 2T questions Thu, 17 July 2003 03:23 Go to previous messageGo to next message
thanks Trevor
Hey Juzzo84 how much you asking for it?
silverfox
Cabooture QLD
Re: Turbo 2T questions Fri, 18 July 2003 04:43 Go to previous message
bump
really would like to hear from anyone who has or is doing a turbo 2t engine at all
Previous Topic:7M Cam Gears
Next Topic:1JZ engines for sale
Current Time: Thu Nov 19 08:08:20 UTC 2026
Total time taken to generate the page: 0.30971908569336 seconds
