Toymods » Tech & Conversions » 16V 4AGE extractors on 20V head?
TE72_Turbo
16V 4AGE extractors on 20V head? Wed, 16 July 2003 11:32 Go to next message
Can you fit 16V 4AGE extractors on a 20V head or is the exhaust manifold flange different?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: 16V 4AGE extractors on 20V head? Wed, 16 July 2003 18:08 Go to previous messageGo to next message
The flange is the same except for the two holes at either end, they are both a little bit different. I have a flange & gasket from each I could take a pic later on in the day.
It can be done, I doubt you'd have a problem.
TE72_Turbo
Re: 16V 4AGE extractors on 20V head? Thu, 17 July 2003 08:37 Go to previous messageGo to next message
So it shouldnt be too hard to mod my turbo exhaust manifold to fit then huh? Very Happy Very Happy It looks like a bit of a bugger to fit the dizzy on the back of the head though... can the dizzy cap be removed & just use it as a cam angle sensor? Did any 20V's come out with direct fire ignition?
sideshow
Re: 16V 4AGE extractors on 20V head? Thu, 17 July 2003 08:47 Go to previous messageGo to next message
r u goin to fit a turbo to a 20v
if u use the quad throttles u will have to make sure u get right aftermarket ecu
most cheaper ecus cannot do multiple throttle bodies and turbo on same engine properly
u need one that does throttle mappin off boost and boost mappin on boost
autronic does it
TE72_Turbo
Re: 16V 4AGE extractors on 20V head? Thu, 17 July 2003 09:07 Go to previous messageGo to next message
I wouldnt use the quads, just make a custom plenum with a single large throttle body on the front. I need to get some info on flow capabilities verses the 16V head before I seriously get stuck into this. I wonder if the VVT has as much merit in a boosted application? Have other people left it working, or disabled it?
sideshow
Re: 16V 4AGE extractors on 20V head? Thu, 17 July 2003 09:08 Go to previous messageGo to next message
well nissan ca18 turbo engines still use the butterflies
if u dont set them up on a ca18 the engoine goes abit doggy down low
TE72_Turbo
Re: 16V 4AGE extractors on 20V head? Thu, 17 July 2003 09:14 Go to previous messageGo to next message
I didnt realise that CA18's had quad throttle bodies.... in which cars did they come out in like that?
sideshow
Re: 16V 4AGE extractors on 20V head? Thu, 17 July 2003 09:16 Go to previous messageGo to next message
no they dont
they have a similar setup to tvis
oh sorry u said vvt
if u use the 20v head its prob best to use vvt
if u r runnin aftermarket ecu then use an output for the vvt
[Updated on: Thu, 17 July 2003 09:17]
Ben Wilson
Re: 16V 4AGE extractors on 20V head? Thu, 17 July 2003 22:29 Go to previous messageGo to next message
You can pick up old 20v headers fairly cheap, it wouldn't be that hard to cut the flange off an old set of them then weld your manifold to it.
Come to think of it, most importers would probably have buggered sets of 20v headers you could have for free (or close to it..)
CrAiGzEE
south of the big smoke
Re: 16V 4AGE extractors on 20V head? Fri, 18 July 2003 01:45 Go to previous messageGo to next message
i thought you can fit 20v headers to the 100kw but not vice versa cause as joel mentioned the bolt pattern, they wont fit to the 86kw either AFAIK
BigWorm
Turramurra, Sydney.
Re: 16V 4AGE extractors on 20V head? Fri, 18 July 2003 07:46 Go to previous message
I've never compared 100kW flange, so I can't comment on that, but here's a pick of an exhaust gasket from an 88kW and a turbo manifold flange for a 20V.
http://members.optushome.com.au/big.worm/flange/flange01.jpg
http://members.optushome.com.au/big.worm/flange/flange02.jpg
http://members.optushome.com.au/big.worm/flange/flange03.jpg
Previous Topic:4agze
Next Topic:7M Cam Gears
Current Time: Thu Nov 19 11:35:45 UTC 2026
Total time taken to generate the page: 0.0097627639770508 seconds
