Toymods » Tech & Conversions » hooking up boost guage
tempest
mona vale,northern beache...
hooking up boost guage Thu, 17 July 2003 01:12 Go to next message
like the title says i want to wire up my boost guage, is this a difficult procedure? if anyone could give me directions on this it would be appreciated. i dont know if it makes a difference or not but the car is an ra28 and the engine is a 3tgte (ct20 turbo)
Re: hooking up boost guage Thu, 17 July 2003 01:27 Go to previous messageGo to next message
It couldn't be easier. If it's a mechanical gauge, just hook up the reference line to somewhere on the plenum and run it through the firewall to your gauge. If it's an electronic gauge, mount the sensor near the plenum and hook up the reference line as above. Wiring instructions should be provided with your gauge.
tempest
Re: hooking up boost guage Thu, 17 July 2003 01:57 Go to previous messageGo to next message
the engiine has just been put into my ra28 from my ta22 and the boost guage was already wired up in the ta22 when i bought it, hence-no instructions. the guage in question is a 2 1/2" pro comp autometer guage(mechanical???).you will have to excuse my ignorance as my knowledge of cars is limited-what is a plenum and where can i find it?
Cyber-punk
Brisbane, QLD
Re: hooking up boost guage Thu, 17 July 2003 02:38 Go to previous messageGo to next message
If its mechanical there is no wiring....just plumbing
turbovan
Kenthurst, Sydney
Re: hooking up boost guage Thu, 17 July 2003 02:42 Go to previous message
if it is mechanical then there will be a brass fitting on the back. Clear plastic tubing goes from there to your plenum. You use brass "olive" fittings on the end of the tube.
it will still have wiring, this is for the illumination. You can hook it straight up to an ignition fed +12V or you can hook it up to the existing dash lighting feed on your dash so that the light comes on only when your headlights are on. Grab a test light and poke around under the dash till you find the dash illumination feed (test light will come on with the headlights)
Previous Topic:1G-GE Frontcuts in Melb
Next Topic:EFI Turbo 4K
Current Time: Thu Nov 19 00:31:08 UTC 2026
Total time taken to generate the page: 0.0054919719696045 seconds
