Toymods » Tech & Conversions » ct26 3tgte HELP!!!!
bootheman
in a box
ct26 3tgte HELP!!!! Thu, 17 July 2003 04:54 Go to next message
well ive just got deiliverd my ct26 A turbo and it dont fit so what the F@#k should i do...
as 4 thoes who said it would fit Evil or Very Mad
now what do i do
Re: ct26 3tgte HELP!!!! Thu, 17 July 2003 05:40 Go to previous messageGo to next message
I recall this thread awhile ago.. Dunno if I remember anyone saying it'd fit..
You need either a custom exhaust manifold or an adapter plate made up.
Probably need new dump pipe also.. Oil drain etc.
bootheman
in a box
Re: ct26 3tgte HELP!!!! Thu, 17 July 2003 07:14 Go to previous messageGo to next message
this is it...
http://www.uniqueautosports.com/Images%202/Toyota/turb.jpg
YelloRolla
On your mum!
Re: ct26 3tgte HELP!!!! Thu, 17 July 2003 08:03 Go to previous messageGo to next message
Mmmmm. Always remember that anything that is a straight fit - NEVER is. Turbo shops told me that the CT26 would bolt to my manifold too - Wrong (as you have unfortunately found out) best to have a custom manifold made for the job - or make one yourself (I know someone who can do these).
In the applications that I have seen there would be insufficient room to run a CT26 straight under the standard manifold with an adaptor in place.
The performance is worthwhile BUT there are many variables affecting how it goes in and how well it all runs.
Some things that you will need to address are-
Oil feed to turbo.
Oil drain from turbo.
Water feed to turbo.
The "clocking" of the housings (basically their orientation to each other). If you decide to change them for better piping angles you will need to modify the wastegate actuator and drill the housings to change the locating pins (you will also need to be sure that the drain hole faces in the desired direction - down).
Piping - both intake (to the turbo and intercooler) + exhaust dump all need to be revised and modified to suit.
Injectors - running the stock injectors out of juice is dead easy with the CT20 the CT26 is infinitely easier. I will go as far to say that if you don't upgrade the injectors don't bother with the CT26.
Pistons - if you are running the stockers you won't be running them for too long after getting the CT26 going.
Both TurboRA28 and I have done this conversion in VERY different ways (mine is better of course Laughing) and I can tell you that it is not that difficult to get done. Like all worthwhile car mods it costs a fair whack of the folding stuff.
Have fun - at about 20PSI it will put a smile on your dial that looks something like this Very Happy
[Updated on: Thu, 17 July 2003 08:05]
bootheman
in a box
Re: ct26 3tgte HELP!!!! Thu, 17 July 2003 08:39 Go to previous messageGo to next message
well current mods are... its in a ae86 btw
3TGTEU
5 speed supra box
Turbosmart BOV
2 1/2 inch exhaust
haltech f10 ecu
front mount GTiR intercooler
2.5" pipen all round
how much for a custom manifold im not after looks just aslong as it works mate
im in melbourne btw..
bootheman
in a box
Re: ct26 3tgte HELP!!!! Thu, 17 July 2003 08:41 Go to previous messageGo to next message
injectors will keep up not standard and also got a new VLT pump cos old one died
YelloRolla
On your mum!
Re: ct26 3tgte HELP!!!! Thu, 17 July 2003 08:46 Go to previous messageGo to next message
I hate to do manifolds without the car in front of me there is just too many things to run into. A simple manifold system can probably be bought for as little as $400 or $500. But most people doing this need the car to gat it dead right.
Purple_Beasty
New Zealand
Re: ct26 3tgte HELP!!!! Thu, 17 July 2003 08:54 Go to previous messageGo to next message
If you have the CT26 of a 7M-GTE it will bolt up to your manifold with slight slotting of the holes in the turbo (only a few mm). If it is the twin entry off the 3S-GTE it is a totally different ball game.
I can't remember the specific webpage this info came from, but it did have pics and comparisons of the two turbos. The manifold was also ported out a bit to match the new turbo better.
Callum
TE72_Turbo
Re: ct26 3tgte HELP!!!! Thu, 17 July 2003 09:03 Go to previous messageGo to next message
From the picture, it looks like a single entry CT26 (7MGTE type) ??
If so, it can be made to fit the 3TGTE exhaust manifold, You need to elongate the mounting holes in the exhaust housing about 5mm outwards, and die grind the outlet from the manifold to match the exhaust inlet of the turbo. Then as Jason said, you're up for a dump pipe, water & oil etc. Leaving the housings as they are will have the outlet pointing the same direction as the original CT20, so you can make your intercooler plumbing from there quite easily.
I can send you pics if you want, I really wish there was a tech section on this website that was updated at least once a year so useful articles with pictures could be added for common topics like this one.
Phil
[EDIT] looks like Purple_Beastie replied same time as me. sorry for the duplicate info.
[Updated on: Thu, 17 July 2003 12:43]
TE72_Turbo
Re: ct26 3tgte HELP!!!! Thu, 17 July 2003 13:04 Go to previous messageGo to next message
A couple of images of my old setup here:
http://www.geocities.com/te72_turbo/3TG_CT26.html
Phil
[Updated on: Thu, 17 July 2003 13:06]
bootheman
in a box
Re: ct26 3tgte HELP!!!! Fri, 18 July 2003 02:10 Go to previous messageGo to next message
nice well if anyone can make sure its from a supra im 98% sure it is. 7mgte....
dose anyone have the specs for me to make a plate to fit the turbo to the manifold. or anything like this.?
TE72_Turbo
Re: ct26 3tgte HELP!!!! Sat, 19 July 2003 07:20 Go to previous message
are you listening?
You dont need an adaptor plate if you are fitting a single entry CT26 Rolling Eyes Smile Just elongate the holes in the exhaust housing, and port the manifold to match the turbo entry.
Just take a look at the two items, i'm sure you'll figure out that its quite simple to make the turbo fit the manifold, its the other items like water/oil/dumppipe that will require fabrication.
Previous Topic:what should i do to an engine before i put it in my car?
Next Topic:fuel system
Current Time: Thu Nov 19 21:54:15 UTC 2026
Total time taken to generate the page: 0.006633996963501 seconds
