Toymods » Tech & Conversions » anyone ever had "cryogenic" treated parts??
anyone ever had "cryogenic" treated parts?? Thu, 17 July 2003 18:41 Go to next message
Hey all,
dug around a bit after cryogenics was brought up recently.
wondering if anyone has had parts done or considered it?
a few links.
the company trying to flog it off..
http://www.metal-wear.com/index.htm
an article/ad they put in a journal, written by their employees.
http://www.metal-wear.com/Articles/Heat%20Treat%20 Progress.pdf
metallurgical fact is that it can help with transforming retained austenite into martensite, after quench/temper heat treatments. this is successfully used, and has been proven by research, to work for things like gear teeth and hardened shafts, cam lobes, diff gears.. anything steel based that has surface hardening.
what these guys claim is that everything is improved by the treatment..
their claims that byt treating both brake pads and brake rotors, you get '2-3 times the life' out of both items, whilst giving 'better feel' at the same time. even 'increased efficiency' from alternators! the brake discs may well be true if they are surface hardened, but....
they acknowledge that although there is no research to back up most of their claims, it must work because more people are using it!! (like 50%+ of NASCAR teams)
anyways, what have other ppl heard about it?
Jayem
Finland
Re: anyone ever had "cryogenic" treated parts?? Thu, 17 July 2003 20:06 Go to previous messageGo to next message
I think that cryogenic treatment would work, but is that needed? Exept in serious racing cars. Whole site looks like info-commercial and aimed to some (I wont say american) suckers who would believe everything what is said there. I dont think that car factories use that treatment (prove me wrong) and wouldnt they use it if that really would make for example "both brake pads and brake rotors achieve 2-3 times the life out of both items, whilst giving 'better feel' at the same time. even 'increased efficiency' from alternators!".
My opinion is that they over-exaggerate achieved results. That said call me skeptic.
twinturbo86
Re: anyone ever had "cryogenic" treated parts?? Thu, 17 July 2003 22:23 Go to previous messageGo to next message
there is a place in revesby called the lsw group(cryotuff)
they rekon parts come back up to 300% stronger
i got some gearbox+diff internals treated for my mates turbo lancer there was 16kg of gearbox internals and it cost $88, for that price why not give it a try, the gearbox is still holding together fine
Jayem
Finland
Re: anyone ever had "cryogenic" treated parts?? Fri, 18 July 2003 09:04 Go to previous messageGo to next message
I would give a try for that price too. I still have hard time to believe that 300%.
icon13.gif  Re: anyone ever had "cryogenic" treated parts?? Sat, 19 July 2003 01:23 Go to previous messageGo to next message
it's been a while since i studied science but i think the freezing thing's about as good as Arnie's acting skills as Mr Freeze in the Batman movie - its bullshit.
To change the crystaline or chemical stucture of just about any moden alloy or steel requires it to be heated up (e.g. energy added) whether it's case hardening (e.g. surface treatment) or anealing (e.g. entire depth of item) or nitriding (heat in non-oxygen environment?) or some other process.
The chemical bonds (and that's all we're talking about here - there's nothing at the subatomic level happening) between the atoms in modern metal alloys have to be strong and require significant addition of heat (e.g. energy) to be changed otherwise an engine would never run - application of heat (e.g. combustion) would make it fail.
So how-the-hell can freezing help? It will make parts fragile while frozen, but once you take that cold away? its the same metal, duh? any phase/crystaline change that might of occuring during freezing will simply reverse itself as energy is added (e.g. warming back to room temp).
I think the freezing fad is based on dodgy science (like cold fusion) and worthless. If you've paid hard cash, then i think you're due a refund (false advertising, misleading scientific claims, etc)
Charles.
Re: anyone ever had "cryogenic" treated parts?? Sat, 19 July 2003 07:24 Go to previous messageGo to next message
well, when you quench a steel to form martensite (from austenite) as is done with gear teeth, not all the austenite changes, so some is left over in a metastable state, by cooling down, you increase the driving force for change to the more stable martensite (which is itself metastable, but that's a bit diffrent Wink) although the kinetics are very slow at low temps, the driving force is high but it still takes a long time (days instead of hours). this change will remain at room temp because it is more stable than it was previously (fro a free energy / thermodynamic point of view)
that cryo treatment works in this situation (for quenched and tempered parts with surface hardening) is a researched fact. what i question is the other crap like making plastics stronger, yet less brittle and more wear resistant... and especially the brake pad bit....
i think they are taking it a bit far Wink
and 300%? it's pretty hard to make steel, especially gear steel, 300% stronger (i'm not sure it's even possible)
maybe they mean wear resistance, which might be possible depending on the failure mechanism of the surface....
Re: anyone ever had "cryogenic" treated parts?? Sat, 19 July 2003 08:44 Go to previous messageGo to next message
It sure is an interesting idea - sometime I do plan on getting some parts done, and seeing if I can compare them in any way to untreated parts, looking for an improvement. Sure, it's blown out of proportion, but there probably is SOME improvement available - and it is relatively cheap.
manipulate
Re: anyone ever had "cryogenic" treated parts?? Sat, 19 July 2003 08:49 Go to previous messageGo to next message
Jayem wrote on Fri, 18 July 2003 06:06
That would mean your customers of your particular make of car need to replace their parts less often....which = >$$$.....thats their motivation for NOT using it
Ta
Mani
Jayem
Finland
Re: anyone ever had "cryogenic" treated parts?? Sat, 19 July 2003 14:41 Go to previous messageGo to next message
What car maker would like to be notorious because of weak and non-long lasting cars cars?
Allan
Re: anyone ever had "cryogenic" treated parts?? Sun, 20 July 2003 00:48 Go to previous message
ill let anyone put there car bits in my fridge for $88 no stress!
*NEW* bag-o-peas turbo Cryo charge your engine for 10RWKW!!!!!
AS USED IN 2 FAST 2 FURIOUS!!!!!!!!!!!
Better then naws!!!!
BUY IT NOWWWW!!!! $2000USD
FOR OFF ROAD USE ONLY!!!
Previous Topic:***Urgent*** RA40 front wheel bearing help
Next Topic:beams 3sge?
Current Time: Thu Nov 19 08:24:36 UTC 2026
Total time taken to generate the page: 0.0058779716491699 seconds
