Toymods » Tech & Conversions » Problems when accelerating (18R-C)
ra23celicachick
Mornington Peninsula
icon5.gif  Problems when accelerating (18R-C) Thu, 17 July 2003 22:26 Go to next message
Hi all,
I've had this problem for a while and it seems to be getting worse. Everytime I push my foot down on the accelerator my car hesitates for a few seconds before the speed increases. It happens from 0km/ph and when I'm already crusing and want to increase my speed. Sometimes when it's cold it will back fire through the carby.
I've thought it could have something to do with fuel flow as it's getting too much or not enought. I've got a ram-flow air filter on there but a stock carby, should I change it back to the original air filter?
Any suggestions would be greatly appriciated.
Thanks Smile
Jason
Re: Problems when accelerating (18R-C) Thu, 17 July 2003 23:15 Go to previous messageGo to next message
Sounds like a flat spot in the carby. Rebuild it and the problem will probably disappear. How long has it been since the carby was rebuilt?
ehendrikd
ballarat
Re: Problems when accelerating (18R-C) Thu, 17 July 2003 23:19 Go to previous messageGo to next message
hi
i have the exact same problem with my 18r-c but seems to be only when the engine is cold. i have a weber 32/36 dgv carby and before last weekend when i did something about it, when it backfired through the carby, it would jam the choke flaps stuck, and the car would just stop.
i think my carby is tuned a little rich, hence the backfiring through the carby, this could perhaps be your problem?
but i have noted that with my 18r-c that when the car is a little warm and still hesitating when i accelerate, i pull the manual choke out a little and that seems to fix it until the engine is fully warm.
hope this helps Very Happy
edit: either way i think it may be the mixture settings
[Updated on: Thu, 17 July 2003 23:22]
coronamark2
Re: Problems when accelerating (18R-C) Fri, 18 July 2003 01:01 Go to previous messageGo to next message
The dodgy flat spot - you've got to love it Laughing
First of all fck the ram flow off there shht you might as well stick carboard in there. get a K&N, if you can fork out the money for a carby rebuild do it but you will still have to get it tuned, which is what you should try before you get the rebuild done, get your air fuel mixture right and the timing and try some new or smaller sized jets, and your problem will go away.
I have a 350 holley on my 6 and have got it kind of tuned (need new jets) but it was doing all the dodgy back fires and flat spots thats all gone know though.
Re: Problems when accelerating (18R-C) Fri, 18 July 2003 02:40 Go to previous messageGo to next message
There's lots of things which could be causing those symptoms. It's all guesswork until you put the car on a dyno with a gas analyser jammed up the tailpipe. An experienced dyno operator will be able to diagnose the problem in 5 minutes. It costs money to put your car on a dyno, but it will probably work out cheaper than the "trial and error" method of replacing/rebuilding everything until it's fixed!
Re: Problems when accelerating (18R-C) Fri, 18 July 2003 05:30 Go to previous messageGo to next message
i agree with Norbie, go spend like $30 or whatever it is and have it put on an engine analyser. easy and quick.
as far as the popping out the carby thing goes? that happens under lean conditions. i have the same with my 34DMS weber as i removed the choke flaps, and it is lean when cold. i put a one size richer jet in and it is driveable when cold, and rich enough when hot to be very responsive.
as far as the hesitation when you poot your foot down? sound sremarkably like the accelerator pump is eithe rblocked, or the plunger is not working right. take of the air cleaner, and open the throttle when engine is off, you should see a little stream of fuel squirt in from the side of the throat. if not check linkages, check condition of plunger, check jets are clear.
basically, cold = fuel dropping out of intake mixture = popping
hesitation = lack of fuel = accelerator pump not working properly.
need_boost
Re: Problems when accelerating (18R-C) Fri, 18 July 2003 06:16 Go to previous messageGo to next message
have you checked the spark plugs recently?
ra23celicachick
Re: Problems when accelerating (18R-C) Sun, 20 July 2003 22:17 Go to previous messageGo to next message
Hey all,
Thanks for the help, It seems to be getting worse. Didn't have a chance to look at it over the weekend. Carby was rebuilt about 18 months ago. Spark plugs replaced less than 2 months ago (but probably need a clean.)
The choke on it is a auto but I've got it hooked up as a manual because of the extractors it wasn't heating up. Even when the choke is partly out it can still flat spot when it's warm.
It seems to be running fairly rich at the moment too, have to have a fiddle with the mixture.
A friend has got a dyno so I'll have to speak to him nicely and it should cost me a slab. It was put on the dyno about 18 months ago and basically cyl one wasn't working, compression was about 14 and cyl 2 was 215.
I'll see how it all goes. Smile
ra23celica
Re: Problems when accelerating (18R-C) Mon, 21 July 2003 01:30 Go to previous messageGo to next message
Just before you try all the expensive parts replacement, testing and rebuilding options, go and buy a $7 can of carby cleaner from Super Cheap / Rocca Bros, take off your air cleaner, start the car, and spray the cleaner all down, thru and around the carby.
Replace filter and then go for a drive.
If the problem is still there, then look at the previously mentioned options.
Mitch.
ra23celicachick
Re: Problems when accelerating (18R-C) Mon, 21 July 2003 02:35 Go to previous messageGo to next message
That does sound a lot cheaper than a slab of beer. Will Auto Barn have it? They're fairly close to my work.
ra23celica
Re: Problems when accelerating (18R-C) Mon, 21 July 2003 02:38 Go to previous messageGo to next message
They sure will, they will have name brands as well as cheaper generic stuff.
Don't be afraid to use most of the stuff as well too, and rev the engine a bit while you are spraying it into your carb.
If this does not work, test the plug leads with a multimeter for their resistance, and replace any dud leads, then borrow a compression tester and check your cylinders for compression.
Mitch.
ehendrikd
ballarat
Re: Problems when accelerating (18R-C) Mon, 21 July 2003 03:11 Go to previous messageGo to next message
i know now that my 18r-c must surely be running lean. it occasionally runs on after the ignition is turned off, and friend said that means it's running lean, so
backfiring through carby = lean
hesitating when accelerating
engine running on = lean.
if you are having this problem (engine running on) as well, probaly see what happens when you richen the mixture
i just have to find time now to change my float level setting Smile
[Updated on: Mon, 21 July 2003 03:12]
ra23celicachick
Re: Problems when accelerating (18R-C) Mon, 21 July 2003 22:14 Go to previous messageGo to next message
Yeah, it runs over sometimes (sign of a top quality car I was told Rolling Eyes )
I'm going camping this weekend and have to take my car so I'll have a fiddle around with it one night this week and see how I go.
Steve M
Re: Problems when accelerating (18R-C) Tue, 22 July 2003 03:37 Go to previous messageGo to next message
My brother's old 18rc had the same backfiring and accelleration probs, but only when it was cold the extractors made it worse, so we figured that it was a choke problem. When we pulled off the carby we found that there were little holes in the bottom of the carby and its mounting plate that were full orf silicone sealant, I guess we used too much , but that might have had something to do with the trouble. Blocked gas flow tubes can't be a good thing, as they are required for the carby to work right.
ra23celicachick
Re: Problems when accelerating (18R-C) Tue, 22 July 2003 04:22 Go to previous messageGo to next message
Looks like the best way to find out is the dyno. There is so many possibilities of what could be causing it, But one thing I'm certain of is that it has something to do with the Carby!
munki
Gold Coast
Re: Problems when accelerating (18R-C) Tue, 22 July 2003 07:17 Go to previous message
my rc has had similar problems recently, like others said carby cleaner points plugs and half an hour of tuning and it was running fine again.
Previous Topic:ta22 3tgteu conversion THE BIG QUESTION
Next Topic:simple question about compression testing.
Current Time: Thu Nov 19 00:59:24 UTC 2026
Total time taken to generate the page: 0.024496078491211 seconds
