Toymods » Tech & Conversions » ***Urgent*** RA40 front wheel bearing help
Simon-AE86
Banned user
ADELAIDE - The Drift City
***Urgent*** RA40 front wheel bearing help Fri, 18 July 2003 00:29 Go to next message
My ae86 has RA40 struts.. so since i dont own a whole RA40 i dont have the work shop manual
Anyone done a front wheel bearing before?
I need a run down on how hard it is, how long it takes and what tools i'll need for the job!!
thanks guys
Simon
Re: ***Urgent*** RA40 front wheel bearing help Fri, 18 July 2003 02:41 Go to previous messageGo to next message
It's a piece of piss man; if you've ever changed a wheel bearing before you won't have any problems. You can borrow my workshop manual if you like.
Simon-AE86
Banned user
Re: ***Urgent*** RA40 front wheel bearing help Fri, 18 July 2003 02:54 Go to previous messageGo to next message
cant say i have norbie Smile
i can do it without a manual but do i need any special tools?
i have the usual set of sockets and spanners etc etc.. anything else needed?
Re: ***Urgent*** RA40 front wheel bearing help Fri, 18 July 2003 03:03 Go to previous messageGo to next message
Take off wheel.
Prise little cap off the hub. Pull out split pin and undo big nut.
Pull off hub.
Outer wheel bearing will fall out.
Turn hub over. Destroy grease seal. Inner bearing falls out.
The races will be left in the hub.
Bash these out with a big screwdriver or punch - try not to damage the hub. You will see 2 little 'cutouts' where you can
Reverse process.
Use a socket with the right diameter to tap the beaing races into place.
Be very sure to pack bearings with plenty of high temperature bearing grease (usually a blue color), and make sure there is the correct amount of preload on the bearing. Use new split pins and grease seals - they don't cost much.
Simon-AE86
Banned user
Re: ***Urgent*** RA40 front wheel bearing help Fri, 18 July 2003 03:12 Go to previous messageGo to next message
thanks mate, that helps a fair bit.
a few further questions.. the nut under the cap.. when i undo that does the whole hub turn or is that fixed to the stub axle? Im really in the dark when it comes to suspension parts.
Im getting a Bearing kit from CBC, im assuming this comes with everything i need including pins and seals?
and.. what preload do i torque it too?
RobertoX
Re: ***Urgent*** RA40 front wheel bearing help Fri, 18 July 2003 03:28 Go to previous messageGo to next message
yeah the big nut on the outside is the only thing holding it on, once you have that off the whole hub should come off...
Re: ***Urgent*** RA40 front wheel bearing help Fri, 18 July 2003 05:01 Go to previous messageGo to next message
Nah, you'll have to buy the oil seals...they cost 5-6 each, and they usually don't come with split pins. Check the kit, you might be lucky.
The big castellated nut is the only thing holding the hub on to the stub axle.
You do it up till the hub is 'snug' - hard to define, but basically you want it to freewheel. Grab the top and bottom of the disc and rock it.....there should be no play. If it is too tight, it will not freewheel....leaving it this way will cause the bearing to overheat and seize....off comes the wheel.
On the good-bad continuum, that's bad. Laughing
Hope it helps.
rob_RA40
c'town, NSW
Re: ***Urgent*** RA40 front wheel bearing help Fri, 18 July 2003 05:11 Go to previous messageGo to next message
Mysterious Store Clerk: But it comes with a free frogurt!
Homer: Thats good!
Mysterious Store Clerk: But the frogurt is also cursed...
Homer: Thats bad.
Mysterious Store Clerk: But it comes with your free choice of toppings!
Homer: Thats good!
Mysterious Store Clerk: The toppings contain potassium benzuate................
Homer: *blank stare*
Mysterious Store Clerk: thats bad......
Homer: Can I go now?
Re: ***Urgent*** RA40 front wheel bearing help Fri, 18 July 2003 05:18 Go to previous messageGo to next message
It's magnificent how we can relate anything to the Simpsons.
Potassium benzoate facts.
Re: ***Urgent*** RA40 front wheel bearing help Fri, 18 July 2003 06:16 Go to previous messageGo to next message
Thanks for making me crack up at work... now all my cow-orkers think I'm crazy. Or easily amused. Or maybe both.
rob_RA40
c'town, NSW
Re: ***Urgent*** RA40 front wheel bearing help Fri, 18 July 2003 06:22 Go to previous messageGo to next message
Cool
Allan
Re: ***Urgent*** RA40 front wheel bearing help Sat, 19 July 2003 23:44 Go to previous messageGo to next message
gianttomato wrote on Fri, 18 July 2003 13:03
Take off wheel.
Pull off hub.
Reverse process.
Might help if you also remove the brake caliper, some people have had success with a large hammer and just bashing the hub off but thats bad!
Allan
Re: ***Urgent*** RA40 front wheel bearing help Sun, 20 July 2003 00:49 Go to previous messageGo to next message
Oops...yes. Embarassed Small oversight.
Simon-AE86
Banned user
Re: ***Urgent*** RA40 front wheel bearing help Sun, 20 July 2003 01:01 Go to previous message
Thanks guys... job done and i must say its a hell of a lot better now!!!
Hardest part was bashing the bearing caps out!
Previous Topic:Clutches again
Next Topic:anyone ever had "cryogenic" treated parts??
Current Time: Thu Nov 19 08:38:42 UTC 2026
Total time taken to generate the page: 0.0067968368530273 seconds
