Toymods » Tech & Conversions » fuel system
rossvw
fuel system Fri, 18 July 2003 02:40 Go to next message
hey im putting a 1gge in my ra40 and was wondering where most people put their EFI pump. is it better to be close to the surge tank and have it push through the steel lines or can you put it in the engine bay? i ask coz i dont know what you need for high pressure efi fuel line connections. I thought if you have the pump in the engine bay you would just need efi line direct from pump to fuel rail (with efi filter in between?).
also the guy i bought the lift pump i want to use was talking about putting a fuel pressure regulating type valve in the return line to the tank from the surge tank. if you adjusted it to the pump pressure of the lift tank it would stop the lift pump pumping fuel around constantly in a circle. it would also mean the surge tank would be under some pressure maybe providing a better feed to the efi pump. has anyone seen/done anything like this?
apologies for my ignorance but any advice appreciated.
Seadog
Re: fuel system Sat, 19 July 2003 02:04 Go to previous message
All I know is efi pumps like to blow not suck. So if it is too high it won't work properly. Also, the intakes on most are 1/2" so you would have to run a 1/2" line along your car (but at least it wouldn't have to be high pressure).
By the way, if anyone is looking for some high pressure efi rubber fuel hose, I got some from Edgeworth auto parts for $10/metre. This is waaay cheaper than I have seen it anywhere else. The only difference is it's red.
Previous Topic:ct26 3tgte HELP!!!!
Next Topic:fuel problem
Current Time: Thu Nov 19 20:01:51 UTC 2026
Total time taken to generate the page: 0.16206097602844 seconds
