Toymods » Tech & Conversions » Turbo Question
pulcino
Mackay QLD
Turbo Question Sat, 19 July 2003 13:15 Go to next message
Does anyone use a ct20 turbo or know anything about them? Not a ct20b but a ct20. I need to know what application and when they run out off puff ( at what revs ) eg boost from 2500 to 5000 etc.
How much boost they can hold etc.
wilbo666
Re: Turbo Question Sat, 19 July 2003 13:22 Go to previous messageGo to next message
I think the CT20 was off the 3T-GTE's ??
Thats all I know Confused No sure about boost etc (I think they take a while to come on tho?).
pulcino
Mackay QLD
Re: Turbo Question Sat, 19 July 2003 13:24 Go to previous messageGo to next message
I have one running in the car now just dont know what the limmitations of it is.Thanks for your speedy reply
earlyrolla
Re: Turbo Question Sat, 19 July 2003 13:40 Go to previous messageGo to next message
I have only ever seen one off an engine and it was a 3TGTE. From my perspective it looked pretty small (impeller and turbine). I would suspect on a 2L it would come on boost at fairly low RPM. Didnt look too good for high RPM applications. Wouldnt like to push the boost capabilities too much, as the air outlet temps would quickly skyrocket.
But as I said, I only looked at it. I don't really have any experience with one.
TE72_Turbo
Re: Turbo Question Sun, 20 July 2003 12:42 Go to previous messageGo to next message
When I had a stock 3TGTE (except for exhaust & 12psi boost) You could really notice a lack of power from 5000rpm onwards. Outlet temps from the turbo (at 12psi) would skyrocket to over 130 degrees C !
They are not the most efficient turbo around. Really just Toyota's first attempt at a petrol turbo, and since it's derived from their deisel applications, its hardly the most successful attempt Crying or Very Sad Smile
TA22 GT
Re: Turbo Question Sun, 20 July 2003 13:07 Go to previous messageGo to next message
Yep, the CT20 was on a 3T GTE and was Toyotas first attempt at a turbo.
I ran mine on my 3T GTE up to 10psi wihtout any problem. I think about 12 psi is about the limit without shortening its life too much. I know of people running them up to 18psi.
They are a small turbo and pretty laggy.
High boost wiht them = high temperature. So don't use it if you chasing more than about 200hp.
You can high flow the CT20's, but for that cash you are better off buying a better turbo.
Good luck,
Simon
Re: Turbo Question Sun, 20 July 2003 13:28 Go to previous messageGo to next message
From what I've seen of them on other's cars, and also having a good look at one I pulled off, I really wouldn't bother putting any $ into it - CT20B and CT26 seem to be a far better bet, if you must confine yourself to Toyota turbos!
pulcino
Mackay QLD
Re: Turbo Question Thu, 31 July 2003 11:27 Go to previous messageGo to next message
I have one on a 4agze at 1 bar. When I ran it on a 4age it used to boost right to red line.Now on the gze the torque drops off at 5 grand. My mate thinks its the cam timing.I seem to think so too but diddnt know much about the turbo. The 3tgte is a 1.8 and I have it on a 1.6 so you'd think it would be big enough a turbo for what I need.
rob_RA40
c'town, NSW
Re: Turbo Question Thu, 31 July 2003 22:04 Go to previous messageGo to next message
TA22 GT wrote on Sun, 20 July 2003 23:07
actually it was the M-TE which was toyotas 1st attempt at a turbo.
[Updated on: Thu, 31 July 2003 22:04]
pro_ke
adelaide
Re: Turbo Question Fri, 01 August 2003 00:23 Go to previous messageGo to next message
i thought the ct20 was off a hilux turbo diesel - i am probably wrong though
wilbo666
Re: Turbo Question Fri, 01 August 2003 01:10 Go to previous messageGo to next message
rob_RA40 wrote on Fri, 01 August 2003 08:04
Lol was there anything the "M" series wasn't the first of??
Turbo...EFI (4M-E)...lol ahhh what a series
Re: Turbo Question Fri, 01 August 2003 01:41 Go to previous messageGo to next message
Don't forget first twincam! 3M (2000GT).
ZZT231
melbourne.vic.au
Re: Turbo Question Fri, 01 August 2003 01:51 Go to previous messageGo to next message
Gees, I wanted to throw out my 5M-E for something faster but since it is a pioneer series motor... I'll keep it knowing I have one of the pioneer technology Laughing
Cheers.
rob_RA40
c'town, NSW
Re: Turbo Question Fri, 01 August 2003 02:06 Go to previous messageGo to next message
dont forget about multi-valve heads (in conjunction with the 4A)
u will find that toyota already played with all of these technologies before they were put into production, they ran a TT V8 powered racing car called the toyota sports 80 or something like that back in the 60's or 70's
rob_RA40
c'town, NSW
Re: Turbo Question Fri, 01 August 2003 02:12 Go to previous messageGo to next message
found it
its called the toyota 7
http://www.mmjp.or.jp/60srace/Toyotatarbo2.jpg
look at the hair dryers hanging out the back
http://www.mmjp.or.jp/60srace/Toyotatarbo3.jpg
TURBO CHARGED TOYOTA 7 in Fuji 1000kms race 1970.
<TECHNICAL INFORMATION>
CHASSIS : Alminium multi-tubular spaceframe
BODY : Carbon fiber and FRP
TYRES : Firestone Indy
ENGINE : Toyota
Type : Turbo chaged V8
Bore x Stroke : 102mm x 76mm
cc : 4986
HP at rpm : 800/8000(DIN)
kg-m at rpm : 74/7600
Turbo chaged : Dual
Cooling system : Water
Length of car : 3750mm
Width : 2040mm
Height : 840mm
Weight : 620kg(dry)
more pics here
http://www.mmjp.or.jp/60srace/TOYOTA7andSOLDIERS2. html
tempest
mona vale,northern beache...
Re: Turbo Question Fri, 01 August 2003 04:32 Go to previous messageGo to next message
the boost on mine kicks in at about 3000rpm
speakafreaka
Re: Turbo Question Fri, 01 August 2003 05:51 Go to previous messageGo to next message
wilbo666 wrote on Fri, 01 August 2003 11:10
7M - the first disposable head gasket?
[Updated on: Fri, 01 August 2003 05:51]
wilbo666
Re: Turbo Question Fri, 01 August 2003 06:14 Go to previous messageGo to next message
What the 7M should have been the first motor with a stock metal head gasket (and a proper torque setting?)? Razz (btw what was the first toyota motor with a stock metal hg?)
Re: Turbo Question Sat, 02 August 2003 01:51 Go to previous messageGo to next message
I'm pretty sure the first Toyota engine with a MHG was, funnily enough, the 7M-GTE's successor: the 1JZ-GTE. Smile
Re: Turbo Question Sat, 02 August 2003 02:07 Go to previous messageGo to next message
The M was also Toyotas first push into mass produced overhead cam motors and also alloy head motors.
Don't forget that the Crown was the first car to have self cancelling indicators.
Also released with the M series was Toyota's first attempt at electronic overdrive. The car came with a 3 speed column shift but the box was fitted with a range of solenoids and an extension housing full of planetary gears. Depending on speed and load, the overdrive could be activated simply be depressing the accelerator pedal. At highway cruising speed, you could simply mash the loud pedal and the overdrive would kick down (much like an auto). Overtaking was a breeze. I loved mine.
M and Crown, what a combination.
pulcino
Mackay QLD
Re: Turbo Question Sat, 02 August 2003 08:07 Go to previous messageGo to next message
I think were getting off the track a bit Rolling Eyes
Does anyone know anything substantial about the ct2o or its performance on the 3tgte?
cam_RA40
Launceston, Tasmania
haha, funny little head!
Re: Turbo Question Sat, 02 August 2003 08:17 Go to previous messageGo to next message
Norbie wrote on Fri, 01 August 2003 11:41
I think the first twincam engine was actually the 6RG, it was made in the early 60's
Mx73_LuXoBarge
Bris-vague-us
Re: Turbo Question Sat, 02 August 2003 21:32 Go to previous message
rob_RA40 wrote on Fri, 01 August 2003 12:12
Weight : 620kg(dry)
Similar specs to my M powered cressi Laughing
Previous Topic:7m into ra -- --
Next Topic:jzx90 diff n jz70 supra and any1heard of knightpager computers
Current Time: Wed Oct 28 16:01:32 UTC 2026
Total time taken to generate the page: 0.0063889026641846 seconds
