Toymods » Tech & Conversions » air flow meter upgrade......
Iceman
icon5.gif  air flow meter upgrade...... Sun, 20 July 2003 03:38 Go to next message
Ok on my Camry the air flow meter (AFM) is a circular flap that swivels to adjust for the position of the throttle. Anyway I ripped it appart the other day and what happens is when the trottle moves off idle the air flow is almost completely cut off!!! then it opens up.
SO on idle it has a small gap then closes and then opens further...... So a mate of mine told me that it might be pos to replace it with a AFM from another car. Is this possible? If so which car would the pice come from??
I would prefer not to change the whole ECU and attached systems. So i guess a MAP system is out of the question. Swift GTI's have a single wire in the AFM and that just sends a change in voltage to the ECU, so i'm supposing that this would be a standard for most cars...
ANY HELP WOULD BE GREATLY APPRECIATED
Very Happy
Iceman
icon2.gif  Re: air flow meter upgrade...... Sun, 20 July 2003 03:40 Go to previous messageGo to next message
So yeah, does any1 know of a secific part which could replace the AFM on a '91 camry SV21.
Or at least how they work..... like readings sent to the ECU...
CamryMan
Re: air flow meter upgrade...... Wed, 01 October 2003 08:46 Go to previous messageGo to next message
Why can't you just replace it with another SV21 AFM?
In theory you can attach an RX7 AFM on it. Making the bloody thing work is another matter all together.
wil8115
Seattle area, USA
Re: air flow meter upgrade...... Thu, 02 October 2003 05:43 Go to previous message
find other flap door type AFM's and start checking them for the same Ohms as yours. Look for the same amount of wires, same shape, etc. Your bound to find one. Toyota doesn't like to re-invent the wheel. In the States there are several types that "can" work on different models. Just have to adjust the wheel tension.
Previous Topic:20v conversion into AE93 PLEASE HELP really need advice :(
Next Topic:1G-GTE GT28 upgrade question
Current Time: Sat Oct 24 22:21:37 UTC 2026
Total time taken to generate the page: 0.0044171810150146 seconds
