Toymods » Tech & Conversions » Turbo dump pipe for 7MGTE
celicaboy_2000
Lismore, NSW
Turbo dump pipe for 7MGTE Sun, 20 July 2003 06:09 Go to next message
Has anyone got or know where I can get one made up, I want one that has a seperate pipe for the waste gate if you no what I mean?
Allan
Re: Turbo dump pipe for 7MGTE Sun, 20 July 2003 07:13 Go to previous messageGo to next message
I Made a large 3.5 inch single pipe basicly to my thinking once the wastegate is open anyway if it causes some turbulance it wont matter because it only opens when its trying to slow down the turbine anyway
a 3.5 inch pipe should cause the largest possable pressure drop across the turbine with luck
http://users.tpg.com.au/supra80/DSC00296.JPG
I still have a few plates left if you would like me to make you one let me know
celicaboy_2000
Lismore, NSW
Re: Turbo dump pipe for 7MGTE Sun, 20 July 2003 07:22 Go to previous messageGo to next message
You wouldn't beable to get more pics at different angles would you?
Allan
Re: Turbo dump pipe for 7MGTE Sun, 20 July 2003 07:40 Go to previous messageGo to next message
not much more to show! just a big ass bit of 3.5inch pipe with a plate to bolt to the turbo and a plate for the O2 sensor.
Fits under the stock heat sheild all good
Allan
celicaboy_2000
Lismore, NSW
Re: Turbo dump pipe for 7MGTE Sun, 20 July 2003 07:47 Go to previous messageGo to next message
Is it basically the same shape as the toyota one eg is it a straight bolt in? Is the pipe bent into shape to fit into the hole of the plate or have you done more plate welding etc? How much would you want to make me up one?
Allan
Re: Turbo dump pipe for 7MGTE Sun, 20 July 2003 08:16 Go to previous messageGo to next message
pipe is shaped to the hole on the plate, its 3.6 inchs so i had to expand the pipe .1 of an inch.
Give me an Email and tell me what the rest of your system has and we can go from there but looking at cost price im not looking to make money from it at all.
Allan
allanlangford(at)yahoo.com
celicaboy_2000 wrote on Sun, 20 July 2003 17:47
chrisss
melb
Re: Turbo dump pipe for 7MGTE Sun, 20 July 2003 12:50 Go to previous messageGo to next message
Allan did you have a problem getting the pipe to clear the steering box?(MA40's use a recirc ball sys dont they?)
just wondering if I would have probs trying to fit a 7MGTE into a MX62.
Allan
Re: Turbo dump pipe for 7MGTE Sun, 20 July 2003 20:21 Go to previous message
This is on my MA70, the 45 should be fine, would have to reduce down to 3 inch earlyer and hug the block a bit, but it runs in the stock location remember the 5m-e runs two 2inch pipes down there so one 3 inch is not an issue.
Allan
Previous Topic:3tgteu injectors in a 2tgeu
Next Topic:4AGE with Weber
Current Time: Thu Nov 19 08:06:18 UTC 2026
Total time taken to generate the page: 0.097049951553345 seconds
