Toymods » Tech & Conversions » What is a VSV
trev64
icon5.gif  What is a VSV Thu, 04 July 2002 23:57 Go to next message
Wow this is fun, my first post.
I am in the middle of a 1JZ swap into a 1986 MA70.
I need to know what the VSV EVP is and where is it located.
DannyGT4
Toymods Board Member
Re: What is a VSV Fri, 05 July 2002 01:57 Go to previous messageGo to next message
Vacuum Switching Valve
lol thats the extent of my help... hehehe i hate VSV's too Razz
EDIT: i'm gonna correct myself and say Vacuum Solenoid Valve...errr same thing Razz
[Updated on: Sat, 06 July 2002 02:04]
trev64
Re: What is a VSV Fri, 05 July 2002 03:34 Go to previous messageGo to next message
Vacuum Switching Valve, that makes sense.
Thanks Danny.
But what the hell does EVP stand for?
The VSV EVP is located in the wiring diag between the ECU and the circuit opening relay.
Can the VSV be bypassed and still let the engine run?
HEEEEEEEEELLLLLLLLPPPPPPPP!!!!!!!!!!
roger
Re: What is a VSV Fri, 05 July 2002 04:12 Go to previous messageGo to next message
Not talking from direct experience here ( haven't installed a IJZ) but you could by pass it. Your idle will probably be stuffed, it is will be on the throttle body most likely or between throttle body and manifold. If it is the valve that I am thinking of.
trev64
Re: What is a VSV Fri, 05 July 2002 08:44 Go to previous messageGo to next message
Ended up finding that damn VSV EVP.
It was hidden under the inlet manifold in between the two knock sensors. I don't even know what it looks like. I knew that was it because of the color of the wires coming off it (and a good guess).
Anyways that was the only wire that preventing me from starting the car. After that was sorted the engine fired straight away.
Thanks to those who replied with their ideas it helped me alot.
DannyGT4
Re: What is a VSV Fri, 05 July 2002 09:48 Go to previous message
lol i hate mysterious engine bits
well done on finding it Smile
Previous Topic:Toyota Dealership
Next Topic:22RE -vs- 22R in Hilux
Current Time: Sat Nov 21 03:04:54 UTC 2026
Total time taken to generate the page: 0.0053701400756836 seconds
