Toymods » Tech & Conversions » Hollow camshafts..
SW20R
Hollow camshafts.. Mon, 21 July 2003 15:30 Go to next message
Mitsubishi seems to be using this in their evo engines.. to reduce weight helping the other components rev happier.
What are your thoughts?
would you get these done on a new set of camshafts?
Re: Hollow camshafts.. Mon, 21 July 2003 23:10 Go to previous messageGo to next message
Which bit of the cam is hollow?
M and JZ series cams have a hollow core for oil flow to the bearing journals. If it's the lobe, then it sounds like a flashy excuse for inbuilt obsolescence. Rolling Eyes
Would I core my otherwise solid cam? For the likely imperceivable performance gain balanced against the cost and likely weakening of the shaft, a big fat NO.
Steve M
Re: Hollow camshafts.. Tue, 22 July 2003 02:50 Go to previous messageGo to next message
18rg camshafts have a hollow core so that oil can get to all of the cam journals through its centre.
YelloRolla
On your mum!
Re: Hollow camshafts.. Tue, 22 July 2003 06:13 Go to previous messageGo to next message
3T GTE cams are also hollow for the oil circulation.
1bam777
Perth WA
Re: Hollow camshafts.. Tue, 22 July 2003 16:59 Go to previous message
Hmm... so are 4AG ones.
Previous Topic:Can someone explain De Dion Rear Axles?
Next Topic:Supra 6 speed to 1UZFE
Current Time: Sat Oct 24 14:57:21 UTC 2026
Total time taken to generate the page: 0.01042103767395 seconds
