Classifieds » Miscellaneous » FS: Ems dualsport ecu
muzzy
icon14.gif  FS: Ems dualsport ecu Mon, 21 July 2003 16:31 Go to next message
i have a full aftermarket computer from EMS its dualsport model with laptop controll and also comes with handpeice programmer.complete loom,recently had software upgrade. it is upgradeable to lambda.also has relays + 1 ems igniter.
and with cables to connect to laptop.
genuine sale do not need it anymore just sitting around so its gotto go.
asking for $1001 negotiable (just like nearly everything else in life) $1001.00
Built in Features
Set ups 1 & 2.
Injector types e.g.
Multi-Point or Throttle Body
Selectable sensor applications e.g.
Magnetic, Hall or Optical
Selectable trigger edges
Rising or falling
Selectable Ignition fire edges
Rising or falling
Selectable Ignition types
For special triggers / Igniters
Changeable Adjustment Pin Numbers
For settings lockout
Selectable No. Cylinders
1 to 16 cyl, 2 and 3 Rotor
Changeable Security Pin Numbers
Engine Immobiliser
Stage Injection Adjustment
Secondary Injectors tuning
Over Boost Cut Adjustment
To save engine (Wastegate fail)
Over Rev Limit
Soft limit
Rev Limit Cut
Fuel cut
Adjustable Ignition Dwell
0 - 5 mS or 50 % duty cycle.
Engine Status
Displays current status of engine. i.e.
Water temperature in Deg C
( -20 to +235 )
Air temperature in Deg C
( - 55 to + 200 )
Manifold pressure in K.P.A
(-100 to + 155 )
Engine RPM
( 0 to 12500 )
Fuel pulse in milliseconds
( 0 to 16 mS)
Battery voltage in Volts
( 6.5 to 23 )
Throttle position in % opening
( 0 to 100 )
Ignition in Deg. advanced
(0 - 51 deg Dual Sport I only)
Inputs
Built in manifold pressure sensor to
measure engine load.
Barometric pressure compensation.
(Auto compensation for different
weather conditions and changes in
altitude).
Internal battery voltage sensing and
compensation.
Air temperature sensing.
Water temperature sensing.
Selectable - Hall, magnetic or optical
on trigger circuit.
on sync circuit.
Coil pick up (optional F only)
Throttle position sensing
Intelligent Interface touch pad OR
Laptop.
Outputs
Adjustable ignition timing ( 0 - 51
Deg. advance in 0.2 Deg.
increments).
Adjustable dwell control ( 0 - 5 mS).
4 Ignition outputs for sequential
ignition timing.
Ignition output has adjustable
igniter triggering edge for different
ignition modules.
8 injector drivers incorporating 4 to
1 current ratio for injector
response and lower power
consumption.
Fuel pump control with automatic
safety cut out if engine stalls.
8 volt supply to hall effect or optical
sensors.
To Intelligent Interface OR Laptop.
4 Auxiliary outputs. Each o/p has 12
options – e.g., Boost control,
thermo fans, NOS, Tacho, Warning
lights, A/conditioning control,
Water inj, Methanol Inj., Shift light,
Idle control, Cam control (V-TEC). and many more.
Turbo timer.
Sam
Sydney, Australia
Re: FS: Ems dualsport ecu Mon, 21 July 2003 20:53 Go to previous messageGo to next message
I'm interested, i'll send you a PM.
EZZY
Re: FS: Ems dualsport ecu Tue, 22 July 2003 03:30 Go to previous messageGo to next message
hi, would you sell the handset only?
i need it to adjust my mr2, its running rich.
Sad Sad
Eric
muzzy
Re: FS: Ems dualsport ecu Tue, 22 July 2003 13:30 Go to previous messageGo to next message
id rather sell it complete,if i dont get a buyer soon maybe i could do something so u canm adjust what u want...
any questions guys dont hesitate to ask.
the wiring is complete as u would buy from ems ie its full length. i never cut it down.this is truly a good buy im the original owner of the ecu.
regards
EZZY
Re: FS: Ems dualsport ecu Tue, 22 July 2003 23:48 Go to previous messageGo to next message
thanks muzzy. that'd great.
my mechanic will be back to sydney next monday, do you think i can borrow the handset early next week? im in sydney, and i will work something out with you if you want.
Eric
king16
camden
Re: FS: Ems dualsport ecu Wed, 23 July 2003 13:45 Go to previous messageGo to next message
hey dude, very interested in the ecu... would you take $850 cash or do you want more... cheers man. let me know dude
muzzy
Re: FS: Ems dualsport ecu Wed, 23 July 2003 13:57 Go to previous messageGo to next message
i think ill wait and see what other offers are out there but id rather get what i advertised it for i think it is good buy it has all the upgrades done so just think about it and you should see that it is good offer.
i stand by what im selling 100% that it is like new and in very good running order.
muzzy
Re: FS: Ems dualsport ecu Fri, 25 July 2003 09:34 Go to previous messageGo to next message
King16 i will take $925 if u want it........
ReQuieM
Re: FS: Ems dualsport ecu Fri, 25 July 2003 09:53 Go to previous messageGo to next message
what engine is wiring loom for? or is it like a one size fits all? Very Happy
muzzy
Re: FS: Ems dualsport ecu Fri, 25 July 2003 10:17 Go to previous messageGo to next message
wiring is as u say one size fits all it is a full harness the ecu uses its own water and air temp sensors,
its usally the software that gets changed around to suit different engine combos,
it comes with full instruction manual in sfotware .
muzzy
Re: FS: Ems dualsport ecu Mon, 04 August 2003 15:32 Go to previous message
new price pplz just want to sell it $900
ps: i know stinger is $1000 new but dual sport allthough older is much more powerfull than stinger more aux outputs etc so keep that in mind.
[Updated on: Mon, 04 August 2003 15:34]
Previous Topic:ta22 parts f/s
Next Topic:fs: bov
Current Time: Wed Oct 21 14:46:46 UTC 2026
Total time taken to generate the page: 0.12971210479736 seconds
