Toymods » Tech & Conversions » Water Injection Pump...
ed_ma61
Lost in the K hole
Water Injection Pump... Tue, 22 July 2003 04:45 Go to next message
To use a fuel pump or not to use a fuel pump, that is the question...
2 standard cold start injectors are being used as the jets (these act as a solenoid too, prevents leakage under hi vac)
im guessing with a simple hi pres external fuel pump ill have to run a pres regulator and a return pipe... ? damn... things then get complicated huh...
are there fuel pumps with regulated outputs around 40psi?
the alternative is a SHURflo diaphragm pressure response water pump that is regulated at 40PSI standard (ie maintains 40psi, and turns itself on and off when system pressure drops).
SHURFLO 2080 FRESHWATER PUMPS
http://www.camec.com.au/images/3541-339ab.jpg
being regulated at 40PSI seems like a good idea, and they are specifically for water... but theyre more expensive than a simple external fuel pump...
any thoughts ??
ed
[Updated on: Tue, 22 July 2003 05:08]
YelloRolla
On your mum!
Re: Water Injection Pump... Tue, 22 July 2003 08:08 Go to previous messageGo to next message
Most of the EFI pumps use the fuel to cool the armature, I am not even sure that the fuel pump would work with water running thru it.
roger
Re: Water Injection Pump... Tue, 22 July 2003 08:15 Go to previous messageGo to next message
Most external fuel pumps run a roller bearing pump on high tolerances. The slightest amount of rust kills them instantly. You may have problems there. If you can find a fuel pump that is of the vane design you may have a better solution. Some VDO pumps even use a plastic vane. The diaphram pump sound like the go.
Re: Water Injection Pump... Tue, 22 July 2003 09:06 Go to previous messageGo to next message
Those SHURFLO pumps are really freakin expensive. They are commonly used on luxury boats for deck hoses, showers and the like.
How about a dedicated water injection pump. MRT Performance sell these? Rolling Eyes
ed_ma61
Lost in the K hole
Re: Water Injection Pump... Tue, 22 July 2003 10:00 Go to previous messageGo to next message
SHURflo abound on ebay for US$40-50
think i might just get one of these. theyre pressure demand switched and regulated at 45psi - sounds good for regular injector use to me Very Happy
ed
Re: Water Injection Pump... Tue, 22 July 2003 10:14 Go to previous messageGo to next message
ed_ma61 wrote on Tue, 22 July 2003 20:00
Damm I wish I found these a while ago. I have paid up to $600 for these in the past Confused
TA22-3SGTE
MACKAY
Re: Water Injection Pump... Tue, 22 July 2003 12:03 Go to previous messageGo to next message
OK a tested and proven method to stop detonation and increase power ..
Stainless steel tank ( 4ltrs or so ) efi pump , pressure regulator , 2 Hobbs switches , a relay , some efi line , large injector .
Set this up the same as for standard efi system , fit the injector about 300mm before the throttle body ( this gives time for atomization and equal distribution ) wire the injector up to one of your existing injectors via a Hobbs switch , wire the pump up via a relay and the other Hobbs switch , set the Hobbs switch for the pump to about one lb and the Hobbs switch for the injector to what ever boost you want it to start , make sure you use a injector with the same impedance as the one's in your motor , This is not for water injection but for Methanol injection , You can't use straight Methanol as there is no lubricant in it and the pump need to be lubed , So the best mixture I have found is to 1 liter of methanol add 50 ML of mineral turps ( This acts as a cleaner for the system ) and 20 ML of Castrol M ( This is the lubricant for the pump ) .
Any other Q's .
Trevor
Allan
Re: Water Injection Pump... Tue, 22 July 2003 13:02 Go to previous messageGo to next message
Would a fuel injector give a fine enough spray to be mounted pre turbo and not cause damage to the compressor wheel?
would be nice to have one pre turbo to basicly clean the intake path (better heat transfer with an internaly clean intercooler!) and one pre throttle body!
Guess if it does eat the compressor wheel I would just have to get it hi-flowed!
Allan
Joshstix
Toymods Vice President
Re: Water Injection Pump... Wed, 23 July 2003 00:18 Go to previous messageGo to next message
I'd be more worried about pumping a combustable mixture through all of your intake plumbing including intercooler etc than whether it would damage the compressor. One backfire and there could potentially be a lot of damage, it would be pretty spectacular though.
ed_ma61
Lost in the K hole
Re: Water Injection Pump... Wed, 23 July 2003 00:31 Go to previous messageGo to next message
a simple 50% water/methanol mix is neither combustable nor have a flashpoint, so its pretty safe...
allan - i once read if you can get a spray atomisation under 5 microns (i think - could be a bullshit number i just made up) then you minimise the risk to the compressor wheel. to achieve 5 micron atomisation, you need ~40psi and a regular fuel injector type jet
ed
Joshstix
Re: Water Injection Pump... Wed, 23 July 2003 00:53 Go to previous messageGo to next message
ed_ma61 wrote on Wed, 23 July 2003 10:31
ed
That's true enough but the system TA22-3SGTE was describing is is 93% Methanol. This was the post directly before Allans.
My reply was aimed more at making sure people with shall we say "V8 supra" style technical knowledge, who may end up reading this, didn't try and inject a combustable mixture at the beginning of the intake tract and then wonder where all their pipework went.
ed_ma61
Lost in the K hole
Re: Water Injection Pump... Wed, 23 July 2003 01:01 Go to previous messageGo to next message
Joshstix wrote on Wed, 23 July 2003 10:53
good call - yeah, 93% methanol running from in front of he compressor wheel is 'bad'
Homer- *Kaboom* *Blam*
Marge- "homer, whats that noise?"
Homer- "huh? oh, nothing"
Homer- *BOOM*
Marge- "Homer?"
Allan
Re: Water Injection Pump... Wed, 23 July 2003 01:56 Go to previous message
coolies 40psi not a problem! next thing I need is a cheap AIC!
Allan
Previous Topic:1uz into 4x4 hilux
Next Topic:Can someone explain De Dion Rear Axles?
Current Time: Sun Oct 25 17:29:36 UTC 2026
Total time taken to generate the page: 0.0042300224304199 seconds
