Toymods » Tech & Conversions » R154 v's W58 differences
JustenGT4
R154 v's W58 differences Thu, 24 July 2003 00:49 Go to next message
Anyone out there who can list the most obvious differences between an R154 and a W58? I have a guy selling a box but he's not sure what he has. It should be a R154 as it's from a JZA70 Supra with a 1JZ but i want to be 100% as he has no pics. Is there a part number or a measurement that's really obvious that i can ask him to do to confirm it's a R154?
Kinda urgent too Smile
Re: R154 v's W58 differences Thu, 24 July 2003 00:58 Go to previous messageGo to next message
http://www.speedtoys.com/~stryder/w58vsr154/w58vsr 154.html
[Updated on: Thu, 24 July 2003 00:59]
JustenGT4
Re: R154 v's W58 differences Thu, 24 July 2003 01:15 Go to previous messageGo to next message
That site looks really promising but i can't access it? You haven't downloaded the info by any chance ? What a tease Smile
JustenGT4
Re: R154 v's W58 differences Thu, 24 July 2003 01:17 Go to previous messageGo to next message
OK i managed to crack their security Razz Thanks
Re: R154 v's W58 differences Thu, 24 July 2003 01:22 Go to previous messageGo to next message
An easy way to tell them apart is to look at the slave cylinder. The W58 has the slave bolted to the side of the box like most gearboxes, while the R154 has a weird arrangement where the slave is inside the bellhousing.
Greg55_99
Boston, USA
icon12.gif  Re: R154 v's W58 differences Thu, 24 July 2003 04:14 Go to previous messageGo to next message
I've found the easiest way to tell them apart is to look at them from the side. The W58 has three horizontal ribs along the side of the case while the R154 has four ribs. Easy.
R154 here:
http://www.classicconversions.co.uk/images/r154%20 pic.jpg
W58 here:
http://www.classicconversions.co.uk/images/w55%20p ic.jpg
Greg
JustenGT4
Re: R154 v's W58 differences Thu, 24 July 2003 04:38 Go to previous messageGo to next message
Thanks Norbie,
Turned out to be a W58? bummer
Re: R154 v's W58 differences Thu, 24 July 2003 04:51 Go to previous messageGo to next message
Wasn't the one in Adelaide was it Justen?
JustenGT4
Re: R154 v's W58 differences Thu, 24 July 2003 04:54 Go to previous messageGo to next message
Nah it was from an importers. The guy said it was out of a JZA70 which would make it an R154 i thought? Definitely a W57/8 though as it has the external slave cylinder.
Re: R154 v's W58 differences Thu, 24 July 2003 05:06 Go to previous messageGo to next message
How much was it going for? I'm after a W58 Smile
JustenGT4
Re: R154 v's W58 differences Thu, 24 July 2003 05:13 Go to previous messageGo to next message
They were after $400ish but it may have been just a W57? Miost of the importers can get you a W58 pretty easily
Stenno
Re: R154 v's W58 differences Thu, 24 July 2003 05:47 Go to previous messageGo to next message
The slave cylinder is external on the R154 - it bolts in from behind the bellhousing, it's not an internal unit.
There are 2 inspection covers on the R154, the slave is located on the left hand side, behind the inspection plate.
http://www.adelaidejap.com.au/images/1JZGTE_5speed.jpg
The W5x series slave cylinder bolts onto the side as has been mentioned above - I dont' believe this box has inspection covers on the bell housing?
Re: R154 v's W58 differences Thu, 24 July 2003 07:02 Go to previous messageGo to next message
Stenno wrote on Thu, 24 July 2003 15:47
Behind the inspection plate... wouldn't that make it "internal"?
lumpy
Adelaide, SA
Re: R154 v's W58 differences Thu, 24 July 2003 07:45 Go to previous messageGo to next message
I think he means after the inspection plate if you look along the side of the box. At least that's where the slave cylinder is located on mine. It is a different setup from the W58 - from memory when I converted from 7m to 1jz we used the clutch master from the jza-70 as well - can't remember exactly why though.
I'm pretty sure my W58 had no inspection covers, but the R154 certainly does. Also $400 is damn cheap for an R154 - esp with a 1jz bellhousing. Most are $1000 plus.
Put them side by side and you'll know the difference - the R154 looks bloody huge by comparison.
Stenno
Re: R154 v's W58 differences Thu, 24 July 2003 23:11 Go to previous messageGo to next message
Norbie wrote on Thu, 24 July 2003 17:02
I believe my first line said "The slave cylinder is external on the R154 - it bolts in from behind the bellhousing, it's not an internal unit."
Reading is fundamental Jeremy Smile
Re: R154 v's W58 differences Thu, 24 July 2003 23:56 Go to previous messageGo to next message
Stenno wrote on Fri, 25 July 2003 09:11
Nasty! Laughing
Here's a pic to show you the difference with regard to the slave cylinders.
http://www.cygnusx1.net/supra/library/TSRM/mt/MT_05.gif
JustenGT4
Re: R154 v's W58 differences Fri, 25 July 2003 00:21 Go to previous messageGo to next message
Thanks Stenno,
Although that's confused the poor guy again Smile You wouldn't happen to have an R154 for sale or know of one for sale? At a price i don't have to give up my first born son for Smile
Stenno
Re: R154 v's W58 differences Fri, 25 July 2003 00:24 Go to previous messageGo to next message
Dave has just said a thousand words in 1 hit Smile
I had 1 about 3 months ago, but it had an M bellhousing on it.
Adelaidejap have the JZ R154's for $1800 (bit steep if you ask me). Have you tried giving Rolin Imports a call?(www.japparts.com.au)
JustenGT4
Re: R154 v's W58 differences Fri, 25 July 2003 00:43 Go to previous messageGo to next message
Yup i agree, $1800 is way too steep. It's not that flash a box. Bellhousing doesn't matter as it's going behind a 1UZ. Thanks for the tip though i'll give rolin a call
Stenno
Re: R154 v's W58 differences Fri, 25 July 2003 01:14 Go to previous messageGo to next message
They (Adelaidejap) have the M bellhousing equiped R154 for $1200, I *think*
JustenGT4
Re: R154 v's W58 differences Fri, 25 July 2003 01:49 Go to previous messageGo to next message
thanks i'll give them a bell
E30-323ti
Re: R154 v's W58 differences Fri, 25 July 2003 02:57 Go to previous messageGo to next message
A bit late, but nevermind.
Reverse light switch is on the opposite side.
kingmick
Banned by his request
moved to tamworth
Re: R154 v's W58 differences Fri, 25 July 2003 13:12 Go to previous message
Norbie a hydra-fork or throw out bearing ect{it has a lot of names) or as Norbie put it "weird arrangement where the slave is" is used by all race cars and alot of performance cars. it is the best of the lot, but the price of them starts from about $850 and goes to about $2000. they take a bit of measuring to fit prop but they work the best. plus they keep the slave away from heat like exhast. they are the best bar none.
mick
p.s haha the r154 question has been answered already!
Previous Topic:Front shocks questions for a TA23
Next Topic:Head bolt upgrade to studs
Current Time: Sat Oct 17 03:44:05 UTC 2026
Total time taken to generate the page: 0.0076630115509033 seconds
