Toymods » Tech & Conversions » Nitrogen in ya tyres?
Hunty
Nitrogen in ya tyres? Thu, 24 July 2003 03:29 Go to next message
I heard an ad on the radio that bob jane are offering to inflate your tyres with nitrogen for better performance and less tyre wear
me thinks this is a bit of a wanky scam
thoughts anyone??
Re: Nitrogen in ya tyres? Thu, 24 July 2003 03:33 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=14713&rid=21&S=fe3df37d1b421cdbb5ae7683f 33bcd9e&pl_view=&start=0#msg_121978msg_121 978
Re: Nitrogen in ya tyres? (it's already ~80%) Thu, 24 July 2003 06:27 Go to previous messageGo to next message
funny thread Smile to get all technical about it....
heat capacity (at constant volume) of nitrogen vs air is 0.71 vs 0.72 (kJ/kg.K) so no difference there.
from http://www.engineeringtoolbox.com/24_159.html
gas density at zero deg C.
nitrogen vs air = 1.250 vs 1.293 (kg/m^3) (same site) stuff all..
viscosity at (0°C,101 kPa)
nitrogen vs air = 1.66^-05 vs 1.71E-05 (N*s/m2) air has _higher_ viscosity (so should leak less)
also, "Valve Leakage Classifications ANSI/FCI 70-2 1976" states that for class 6 leakage (lowest leak rate) they specify using air OR nitrogen for the testing, so there can't be that much difference.
"Nitrogen benefits 'over-inflated', says RACQ" heh heh
http://www.racq.com.au/13_news/articles/20030610_N itrogen_benefi.htm
seems that the only reason to use 'nitrogen' is becuase it has a lower level of water impurity (as it usually comes in bottles)
i apologise for getting all techy, but at least ya know the facts... there is nothing between them (except the oxidation at higher temps)
[Updated on: Thu, 24 July 2003 06:31]
Stenno
Re: Nitrogen in ya tyres? Thu, 24 July 2003 23:15 Go to previous message
There is an article from Toyo on this exact subject.
http://www.toyo.com.au/tech_info11.html
Pretty simplified, but a good read none the less Smile
Previous Topic:DC2 (integra) mags on Ae86?
Next Topic:Plastic inner guard
Current Time: Sat Oct 31 14:43:15 UTC 2026
Total time taken to generate the page: 0.043686151504517 seconds
