Toymods » Tech & Conversions » 4AC flywheel on 4age?
DacBietAE86
4AC flywheel on 4age? Thu, 24 July 2003 08:07 Go to next message
im doing a conversion for a friend and his putting a 4age in his 4ac sprinter.
He has the 4age engine but no flywheel yet.Will the 4ac flywheel fit in the 4age or will he have to buy a RWD 4age flywheel?
Thanks guys
Re: 4AC flywheel on 4age? Thu, 24 July 2003 23:11 Go to previous messageGo to next message
My understanding is 4AC flywheel is only 6 bolts, 4AGE is 8. So not possible.
Joel
Sam
Sydney, Australia
Re: 4AC flywheel on 4age? Fri, 25 July 2003 00:50 Go to previous messageGo to next message
Aparently some of the very early 4AGE's used a 6 bolt flywheel - but yeah, generally 99.9% of them are 8 bolt.
Sam
Sydney, Australia
Re: 4AC flywheel on 4age? Fri, 25 July 2003 00:52 Go to previous messageGo to next message
I should add you can use the 4AGE front wheel drive flywheels as well, as long as it's not a GZE one. the 86kW and 100kW flywheels are different sizes, both will fit but will need clutch and pressure plate to suit. You'll also need a spigot bearing which the FWD doesnt have.
HTH
Sam.
Re: 4AC flywheel on 4age? Fri, 25 July 2003 02:21 Go to previous messageGo to next message
I might also add that I've got a 4AG flywheel lying around here looking bored Very Happy
Hunty
Re: 4AC flywheel on 4age? Sun, 27 July 2003 08:23 Go to previous messageGo to next message
just a quick one how exactly do u get the flywheel off coz when i tryed to undo the bolts the flywheel just turned around is there anyway to lock it down???
roadrunner
Hornsby, Sydney
Re: 4AC flywheel on 4age? Sun, 27 July 2003 08:26 Go to previous messageGo to next message
put one of the gear box bolts into its thread and get a mate to jam a big screw driver to hold it from turning.
Re: 4AC flywheel on 4age? Sun, 27 July 2003 08:34 Go to previous messageGo to next message
U can try putting a breaker bar and socket on the front of the engine on the bolt in the pulley/crank
Or you can try putting a very strong screw driver onto the ring gear and wedge it up against out of the dowls coming out the back of the block.
Joel
Hunty
Re: 4AC flywheel on 4age? Sun, 27 July 2003 09:01 Go to previous messageGo to next message
TurboRA28 wrote on Sun, 27 July 2003 18:04
Joel
Yep cheers the only problem with the breaker bar on the pulley is that the engine is out of the car so i think it would just lever the engine up, tho i could get 3 or 4 of my mates to stand on a rather long piece tube and hold the breaker bar on like that
thanks for the ideas Smile
Re: 4AC flywheel on 4age? Sun, 27 July 2003 23:57 Go to previous messageGo to next message
Or you can be a slack bugger and use a rattlegun... pfft Evil or Very Mad
Big screwdriver is all you need though!
Re: 4AC flywheel on 4age? Mon, 28 July 2003 00:55 Go to previous messageGo to next message
Chain one of the flywheel bolts to the engine mount Razz
Sorry, and I meant one of the outer flywheel ones where the clutch bolts to.
Hunty
Re: 4AC flywheel on 4age? Thu, 31 July 2003 13:48 Go to previous messageGo to next message
justcallmefrank wrote on Mon, 28 July 2003 10:25
That could work!
Thanks for all the ideas guys
i'll give it a go this w/e
Re: 4AC flywheel on 4age? Thu, 31 July 2003 13:55 Go to previous messageGo to next message
Hehe, it DOES work Razz Its almost as innovative as my method of removing the crank pullet bolt with the engine on an engine stand and without a rattle gun! Very Happy
Re: 4AC flywheel on 4age? Fri, 01 August 2003 02:22 Go to previous messageGo to next message
Crank pulley bolt is even easier than that in some cases - leave a spanner on the front and start it up Evil or Very Mad Used to do this ALL the time on my old man's car after setting the points etc. every, oooh, 3000km or whatever rediculously short time it was...
Re: 4AC flywheel on 4age? Fri, 01 August 2003 23:12 Go to previous messageGo to next message
Try starting it up on an engine stand!
wraith
Albany WA
Re: 4AC flywheel on 4age? Mon, 24 November 2003 15:53 Go to previous messageGo to next message
so a rwd 4age flywheel will accept a 4ac clutch?
Re: 4AC flywheel on 4age? Mon, 24 November 2003 22:47 Go to previous messageGo to next message
Yeah it will - but at least be generous enough to put the engine in with a new clutch...
Grega
melbourne.victoria.austra...
Re: 4AC flywheel on 4age? Mon, 24 November 2003 23:35 Go to previous message
yes indeed.
i use an 86kw flywheel as a DOOR STOP for my shed its nice and heavy Smile
but seriously JCMF - i LOVE that idea of holding the flywheel while undoing the bolts - using chain - sensational. good lateral thinking dude.
Previous Topic:Which Brake Master KE55 4AGZE?
Next Topic:ST162 A/C button flashes.. ?
Current Time: Sat Nov 21 09:16:18 UTC 2026
Total time taken to generate the page: 0.0068678855895996 seconds
