Toymods » Tech & Conversions » 4ac water in oil woes
4ac water in oil woes Fri, 25 July 2003 00:14 Go to next message
I have been playing with an old 4ac over the past week, and i have stumbled across a small issue after replacing the head gasket.
# oil is watery, and gets that emulsified white paste everywhere
# water is not consumed, there appears to be no water used up, nor are there bubbles coming out the radiator
# temp guage doesnt go up much at all, nor does water get very hot
# head gets RATHER warm
# water appears to flow through the engine (can see small chunks of crap flowing into radiator)
# engine runs ok!
When i removed the head from the motor, no visible sign of BHG save for a swolen watery spot around the oil return.
Checked both the head and block for warpage - each was PERFECT with warpage less than 0.02mm, and 0.05mm is the tolerance.
I did everything as i knew to be right - cleaned the crap out of the head & block, drained all oil and water, degreased cam/rockers area, tightened head bolts in stages according to specifications in the right order...... EVERYTHING.
WTF is going on!?!?!
Do i have a cracked head or block? Is the head gasket fubar again? IS there just some leftover water in the oil and the motor is otherwise fine?
IRA11Y
Club Member
Re: 4ac water in oil woes Fri, 25 July 2003 10:27 Go to previous messageGo to next message
ok depending on how much sludge you are getting in the cap theres no need to panic.....yet Smile
sometimes small traces of water can collect in the PCV filter (and other places in the head) and it takes time to get out, usually there can be small traces in the cap over about 2 weeks before it totally disappears (if you wipe the sludge away every day). If you are getting LOTS of milky sludge then it may well be that the block is cracked, most likely between the bores.
Also did you change the oil filter? a lot of water gets trapped in there too, maybe thats where its coming from.
One other place that causes problems is the head. being alloy, if it hasnt had a good service history the alloy can break down, especially at the water ports (GE heads are notorious for this) , sometimes its bad enough to bypass the gasket and cause major leaks.
stupid question but are you sure its the right head gasket? If youre head is getting REALLY hot then there is definately some sort of problem, maybe the thermostat? is it opening??
gimme a call in the weekend if you cant figure it out Karl
Re: 4ac water in oil woes Fri, 25 July 2003 15:17 Go to previous messageGo to next message
well it appears there is a lot of sludge building up.. i might take the car to work on sunday and see how she goes over a longer drive.
Ill clean out the sludge again and see if it builds up again... i think it will becuase there was a large amount of sludge previously.
Chemiweld?
Flem
cambo
Re: 4ac water in oil woes Sun, 27 July 2003 09:41 Go to previous message
did u get the head crack/pressure tested????, try giving a tk test or put a radiator pressure tester on it load the engine upthen check the pressure if it goes up heeeps and then comes back down youve prob got a cracked head Sad
[Updated on: Sun, 27 July 2003 09:42]
Previous Topic:Car Alarm Help
Next Topic:Flywheel Bolts
Current Time: Mon Oct 26 08:44:00 UTC 2026
Total time taken to generate the page: 0.0054278373718262 seconds
