Toymods » Tech & Conversions » Aftermarket ECU with Toyota Auto?
7M-Brisbane
Aftermarket ECU with Toyota Auto? Fri, 25 July 2003 05:54 Go to next message
Howdy
Just wondering if anyone knows how to (or if) you can run a Toyota auto gearbox with an aftermarket ECU?
With respect to the 1JZ autos primarily, but any experiences with 7M/2J/1UZ would be helpful as they are essentially the same box.
Re: Aftermarket ECU with Toyota Auto? Fri, 25 July 2003 06:00 Go to previous messageGo to next message
No experiences but Allan had an email chat with the guys at Motec. Apparently the M800 can but it would take a day (ie a lot of money) to set up the hysteresis points. You can cheat a bit because those points are mapped out (IIRC even plotted out) in the TSRM.
I'm not sure if the other Motecs can or if other aftermarket ECUs can.
Just adding the relevant section of the TSRM:
http://www.cygnusx1.net/supra/library/TSRM/at/AT_040.gif
Cheers Dave.
[Updated on: Fri, 25 July 2003 06:03]
sideshow
Re: Aftermarket ECU with Toyota Auto? Fri, 25 July 2003 07:22 Go to previous messageGo to next message
i recently wired up a 1jz with auto to the standard ecu in an old soarer
they r goin to run and ems on it aswell
all u do is tap into the crank and cam signal wires
then cut the injector wires and run them to aftermarket ecu
and do same with ignition wires
so basicly u run both computers
the std on runs the auto and the auxilary stuff
and the aftermarket ecu runs the injectors and the ignition
Allan
Re: Aftermarket ECU with Toyota Auto? Fri, 25 July 2003 11:24 Go to previous messageGo to next message
Earlyer autos with cable controlled line pressure had a seperate ECT ECU swaping the valve body maybe possable..
Allan
Helmann
Ipswich
Re: Aftermarket ECU with Toyota Auto? Fri, 25 July 2003 16:36 Go to previous messageGo to next message
Apexi Power FC can now handle 1J auto.
Was in a issue of HPI a while ago.
It lets you change the shift points on the fly with the hand controler.
Which could be fun if you weren't driving but had the hand controler. Evil or Very Mad Evil or Very Mad Evil or Very Mad
Brett.
Soarer
Wollongong
Re: Aftermarket ECU with Toyota Auto? Sat, 26 July 2003 00:59 Go to previous messageGo to next message
Have you got a copy of HPI where this info is printed ?
For the life of me I cannot find any information regarding the PowerFC working on any 1JZ auto apart from the Chaser.
Please enlighten me.
Helmann
Ipswich
Re: Aftermarket ECU with Toyota Auto? Sat, 26 July 2003 04:39 Go to previous messageGo to next message
I think it was the supra/soarer special.
I cannot find it at the moment but i think it had a gold coloured supra on the front cover.
It was in the first section where they tell ya about all the new tech for cars. It was below something about sard injectors if i remember corectly.
Brett.
biased99
Re: Aftermarket ECU with Toyota Auto? Sat, 26 July 2003 08:18 Go to previous messageGo to next message
sideshow wrote on Fri, 25 July 2003 17:22
This is more or less exactly how mine is run... Autronic SMC for engine; 7M-GE/AT ECU for transmission.
Soarer
Wollongong
Re: Aftermarket ECU with Toyota Auto? Sun, 27 July 2003 02:03 Go to previous messageGo to next message
Helmann wrote on Sat, 26 July 2003 14:39
Brett.
I dug up that issue:
http://homepages.ihug.com.au/~trianta/PowerFC.jpg
Seems as though it's not suitable for the Supra/Soarer though.
MR. 2
Parramatta
Re: Aftermarket ECU with Toyota Auto? Sun, 27 July 2003 23:49 Go to previous messageGo to next message
or u could piggy back the ecu to the aftermarket one like ems etc easy....
1JZ.747
Osama's hideout
Re: Aftermarket ECU with Toyota Auto? Mon, 28 July 2003 06:16 Go to previous messageGo to next message
MV AUTOMATICS ask for michael
just ordered a item that allows you to run the toyota box with after market ecu. it is an electrical item that is wired into your box and makes it full manual shift.
i highly recommend this Michael, they rebuilt my standard box, shift kit and stall and strengthen. very very pleased
08 83700430
Soarer
Wollongong
Re: Aftermarket ECU with Toyota Auto? Mon, 28 July 2003 08:31 Go to previous message
So you got the "Stage 3" kit then ?
Michael is a top bloke... extremely helpful and willing to offer advice on virtually anything to do with the A340E autos.
Previous Topic:flwheel (?) is making a squeaking/rattling noise
Next Topic:7MGE Compression Ratio - How High ??
Current Time: Wed Oct 28 13:03:36 UTC 2026
Total time taken to generate the page: 0.0054121017456055 seconds
