Toymods » Tech & Conversions » ta22 blinkers inop
roadrunner
Hornsby, Sydney
ta22 blinkers inop Fri, 25 July 2003 09:33 Go to next message
Does any body know why my right blinker doesnt flash?
it shits me so much. both the celica's i play with do this so i'm guessing that it may be a common occurence (hopefuuly) and someone knows whats wrong.
please help Roadrunner
TA22 GT
Re: ta22 blinkers inop Fri, 25 July 2003 12:25 Go to previous messageGo to next message
Does your left blinker flash properly?
If it does, my guess is that you have either a blown globe on the RHS or wrong wattage globe. The flasher needs a certain load before it will flash.
From memory, I think you should have a 21W globe for the main blinker and 8W for the small front ones on the side fender.
MAybe someone can confirm these wattages.
Regards,
Simon
silverfox
Cabooture QLD
Re: ta22 blinkers inop Fri, 25 July 2003 13:56 Go to previous messageGo to next message
yeah the blinkers need a certain resistance to work
i discovered my right hand blinker didnt work , just turned out to be a bad connection to the blinker bulb on the front guard
roadrunner
Hornsby, Sydney
Re: ta22 blinkers inop Fri, 25 July 2003 14:16 Go to previous messageGo to next message
yeah left blinker flashes fine.
i'll check the connections and bulbs tommorrow
Silverfox when you say your right blinker didnt work, do you mean didnt flash or not at all.
my right blinker stays on with out flashing
roadrunner
Hornsby, Sydney
Re: ta22 blinkers inop Fri, 25 July 2003 14:17 Go to previous messageGo to next message
this only started a few weeks ago and i didnt change anything when it happenned so i wouldnt think globes
roadrunner
Hornsby, Sydney
Re: ta22 blinkers inop Fri, 25 July 2003 14:18 Go to previous messageGo to next message
silverfox
Cabooture QLD
Re: ta22 blinkers inop Sat, 26 July 2003 03:26 Go to previous messageGo to next message
yeah thats what mine did , it just stayed on , till i fixed the connection problem
Shteeve
near chris and murray vic
Re: ta22 blinkers inop Sun, 27 July 2003 02:19 Go to previous messageGo to next message
it could also be an earth problem, make sure all the globes are grounded
roadrunner
Hornsby, Sydney
Re: ta22 blinkers inop Sun, 27 July 2003 07:12 Go to previous message
thank you all. it was a corroded conection in the side guard blinker. i always thought that when blinker out it should flash double speed or so. but thanks again
[Updated on: Sun, 27 July 2003 07:13]
Previous Topic:RA28 Car Alarm Wiring??
Next Topic:4A, 3S, 7M, (1JZ? 2JZ?) Valve Stem Seal Offer
Current Time: Mon Oct 26 03:17:43 UTC 2026
Total time taken to generate the page: 0.05065393447876 seconds
