Toymods » Tech & Conversions » front strut tower bar installation
freakysoarer
front strut tower bar installation Fri, 25 July 2003 10:34 Go to next message
would the above account for a wheel alignment?
i have recently(like a week ago) had the car aligned and now, am contemplating whether to get a strut bar in...
if wheel alignment is needed, i would hold off the installation.
[Updated on: Fri, 25 July 2003 10:35]
Stefan
Hobart, Tas
Re: front strut tower bar installation Fri, 25 July 2003 13:49 Go to previous messageGo to next message
I seriously doubt it. Unless you extend or tighten the bar after installing (extending, ie stressing the chassis is Not A Good Idea At All, I'm not 100% sure about tightening slightly) things shouldn't be any different.
Except, turn in should be improved, the front end will feel tighter and driving should be more fun Smile Strut brace made quite a difference for me.
I belive you're supposed to install in when on level ground; someone else will know more.
demuire
Ipswich
Re: front strut tower bar installation Fri, 25 July 2003 23:07 Go to previous messageGo to next message
Yes, you should install it on level ground with the car actually on the ground. Basically you want the brace to hold the towers where they will usually sit. If you have the car off it's wheels it'll be too wide, if you put too much weight on the front end it'll be too narrow when it's driving normally...
freakysoarer
Re: front strut tower bar installation Sat, 26 July 2003 02:59 Go to previous messageGo to next message
thanx for the replies.
freakysoarer
Re: front strut tower bar installation Sat, 26 July 2003 16:22 Go to previous message
by the way, anyone knows where to get "spacers" for strut bars?
or are they available at all suspension places?
Previous Topic:Small brake booster
Next Topic:ATF cooler question..
Current Time: Mon Oct 19 17:52:53 UTC 2026
Total time taken to generate the page: 0.023672103881836 seconds
