Toymods » Tech & Conversions » 4cyl+turbo+LPG (mrshin)
earlyrolla
4cyl+turbo+LPG (mrshin) Fri, 25 July 2003 11:28 Go to next message
Pretty much as the title says.
There is currently a thread on PF about LPG in turbo applications. As I am considering using LPG on the drag car I was just looking for others thoughts, experiences and suggestions.
mrshin - your name came up as someone who holds a valuable opinion.
Thanks,
Tyron.
Re: 4cyl+turbo+LPG (mrshin) Fri, 25 July 2003 15:28 Go to previous messageGo to next message
Good to know SOMEONE values my opinion Evil or Very Mad As far as my experiences etc. goes, I can tell you a little bit here now. LPG seems to behave in a slightly strange way, ie it will take more abuse than the octane rating suggests. Nearly all commonly available gas systems are crap. Much of what many people tell you is questionable. Lastly, it can potentially work pretty well! I guess the best thing to do if you want to milk my head for what I've learnt would be to ring me up one evening - otherwise I'd be typing here all night and getting nowhere Evil or Very Mad
Allan
Re: 4cyl+turbo+LPG (mrshin) Sat, 26 July 2003 02:37 Go to previous messageGo to next message
a GRA mixer set up blow thru is about the current best and only way to get things happening with LPG
dont forget a closed loop controller or your fuel econ on a trip will suck and also make shure you have a pressure switch to disable closed loop on boost or else it trys to get 14.7:1 fuel ratio on boost = BAD
The bigest problem with strait LPG is the haltech IG5 is no longer made so geting good ignition advance and retard for a decent price is impossable Sad
Dont know if you guys have a company up there called "supagas" anyway down here thay sell strait propane rather then the AutoGAS mix one gets from the servo, its much cleaner and has a much higher octane rating!
Allan
earlyrolla
Re: 4cyl+turbo+LPG (mrshin) Sat, 26 July 2003 03:28 Go to previous messageGo to next message
Thanks for that mrshin, will get back to you.
I know of the GRA carbys, but I prefer a computer controlled system simply because of the flexibility. I was contemplating using one of those 'floating gas valves' that goes between the converter and mixer. The only computer available uses a TPS and O2 sensor as input, and simply cycles around 14.7:1 A/F at cruise. I was thinking of improving on this by building my own computer instead of using the crappy one currently available. But this wont be for a little while as I am flat out with other commitments at the moment Razz
Grega
melbourne.victoria.austra...
Re: 4cyl+turbo+LPG (mrshin) Sat, 26 July 2003 03:50 Go to previous messageGo to next message
nothing a microtech wouldn't fix....use it for ignition and tps input...don't run the injector side of things...
pro_ke
adelaide
Re: 4cyl+turbo+LPG (mrshin) Sat, 26 July 2003 04:09 Go to previous messageGo to next message
Grega wrote on Sat, 26 July 2003 13:50
careful, all the megasquirt boys might get upset because you mentioned microtech
get hold of a MTX8 or LTX8 and your problems are solved
for prices look on www.dysonrotary.com.au
ab
Grega
Re: 4cyl+turbo+LPG (mrshin) Sat, 26 July 2003 23:57 Go to previous messageGo to next message
ab....megasquirt don't do ignition fella. microtech does Smile
LTX8 would be the way to go. thx for the URL too!
Allan
Re: 4cyl+turbo+LPG (mrshin) Sun, 27 July 2003 00:23 Go to previous messageGo to next message
ewww think i would prefer to get a wolf then one of those!
Allan
Re: 4cyl+turbo+LPG (mrshin) Sun, 27 July 2003 02:45 Go to previous messageGo to next message
Allan, so you're still into the gas thing? Good to hear... As for control, economy, etc. - forget gas research stuff, forget stepper motors - hopefully SOON I'll have something to offer that's MUCH better than ANY of that crap! A couple of you know what I mean already... Evil or Very Mad
I get more detirmined every day too, because my present GRA setup is progressively working at me to piss me off as much as possible... Causing me grief in any way that it can!
pro_ke
adelaide
Re: 4cyl+turbo+LPG (mrshin) Sun, 27 July 2003 09:07 Go to previous messageGo to next message
Allan wrote on Sun, 27 July 2003 10:23
Allan
thats nice to know, maybe you should go buy the wolf then. simply stating the MTX8/LTX8 will do the job very well on the other guys drag car.
tyron, i would suggest getting in contact with one of the big rotary workshops for some more info, they are generally pretty helpful.
ab
Grega
Re: 4cyl+turbo+LPG (mrshin) Sun, 27 July 2003 10:30 Go to previous messageGo to next message
yeah nothing wrong the microtech. horses for courses...
Guest
Re: 4cyl+turbo+LPG (mrshin) Sun, 27 July 2003 11:37 Go to previous messageGo to next message
This is my mates navara ute, goes very hard, on dedicated lpg setup. Note the MASSIVE intercooler. Its making about 150 kw at the wheels on 1 barr boost from the original SOHC engine.
http://www.users.tpg.com.au/yojimbo/jamie1.jpg
Matt
Allan
Re: 4cyl+turbo+LPG (mrshin) Sun, 27 July 2003 12:35 Go to previous messageGo to next message
LPG requires a VERY good spark for NA let alone when boosted and looking at the lower microtecs thay dont do coil packs
Maybe fine for petrol!
Allan
Re: 4cyl+turbo+LPG (mrshin) Sun, 27 July 2003 13:07 Go to previous messageGo to next message
When it comes to ignition, while the chemical properties of LPG do indeed prefer a slightly beefier spark, most the the trouble in that department is the result of the fuel systems that are generally used offering the control of a 1920s carb. When correct mixtures/distribution are used, ignition is no big issue (I like to see at least multi coils on any engine anyway!) - but when control is poor, misfire is prevelant. I'd say I've proved this by busting enough bits!
earlyrolla
Re: 4cyl+turbo+LPG (mrshin) Sun, 27 July 2003 13:30 Go to previous messageGo to next message
Thanks for that ab. There are a couple of heavy hitter rotary places over here (FORMAZ, ROTOMOTION etc). Could even ask PERFORMANZ TURBOCHARGERS as they had a dedicated VG20(?) running LPG and getting 11 second quarters.
Yes, I did mean VG20 not VG30. Not sure if it is VG or VQ though.
Have heard about the need for a decent ignition system. Agree with mrshin, looking at the chemical properties table, LPG does have a higher ignition limit than premium, but generally the problem lies with controlling the gas mixture correctly. I had an IMPCO 255 mixer apart a couple of weeks back, and the technology is soooooo basic. Even though it was a 70's gas carby, it uses the same principles as the majority of gas carbys available today.
Re: 4cyl+turbo+LPG (mrshin) Sun, 27 July 2003 23:55 Go to previous messageGo to next message
Yeah that bluebird uses a VG20E (single cam non turbo 2 litre V6), with a turbo, GRA system, basic ignition, etc.
As for the impco stuff... Oh dear, it hasn't changed in 30 years! The so-called 'feedback fuel processors' (and similiar) are piss poor excuses for oxy sensor control too...
pro_ke
adelaide
Re: 4cyl+turbo+LPG (mrshin) Mon, 28 July 2003 01:00 Go to previous messageGo to next message
Allan wrote on Sun, 27 July 2003 22:35
Allan
mtx8 and ltx8 are hardly the 'lower' microtechs mate!
ab
Allan
Re: 4cyl+turbo+LPG (mrshin) Mon, 28 July 2003 12:21 Go to previous message
yeah only about $500 more then what the haltech IG5 sold for! that being my point!
I dunno Mazda loven hippys Razz
Allan
Previous Topic:CHASER JZX100 ???
Next Topic:Fuel lines
Current Time: Sun Oct 25 06:45:52 UTC 2026
Total time taken to generate the page: 0.0055849552154541 seconds
