Toymods » Tech & Conversions » RA28 Idler and Pitman arm replace
RA28midge
Adelaide and Queenstown T...
RA28 Idler and Pitman arm replace Sun, 27 July 2003 02:21 Go to next message
I have bought a new Idler arm and pitman for my steering because they are a little loose, but I can't get the old ones off the steering linkages. Do I need a special tool to get the buggers off, or do i just need to use brute force?
Re: RA28 Idler and Pitman arm replace Sun, 27 July 2003 07:24 Go to previous messageGo to next message
There is a tool you can get to seperate ball joints. It's like a large wedge shaped fork.
Otherwise, a hard wack with a hammer can help.
roadrunner
Hornsby, Sydney
Re: RA28 Idler and Pitman arm replace Sun, 27 July 2003 07:31 Go to previous messageGo to next message
If they are very loose and worn and old they will need to be hit very straight down while holding the other parts. this is very very hard to do sometimes and may need to be pressed out using a hydrolic press. common mech workshop equipment.
hope its a little help
Steve M
Re: RA28 Idler and Pitman arm replace Mon, 28 July 2003 01:59 Go to previous messageGo to next message
A mini sledgehammer did it for us.
gold28
Madrid - Spain
Re: RA28 Idler and Pitman arm replace Mon, 28 July 2003 03:19 Go to previous messageGo to next message
These parts are on a tapered shaft, meaning that they are designed to wedge themselve on when you do up the bolt. You will need to use a splitter to get them off. There is a couple of different types, one looks like a forked wedge, another a bit like a clamp with a forked end. Don't try doing it without the right equipment, you will only break something and it will cost you more money. Go to a suspension shop or your mechanic and get him to split them for you.
RA28
Re: RA28 Idler and Pitman arm replace Mon, 28 July 2003 12:31 Go to previous messageGo to next message
yeah, you could break something with brute force....but anyway,
I had a steel rod going in down through the engine bay and found someone stupid enough to hold it while I smacked it with a big hammer.
the other idea is to get a lever on it and apply a fair bit of pressure, then smack it with a big hammer, right in the side of the joint, like when you are removing ball joints.
Tim,
RA28midge
Re: RA28 Idler and Pitman arm replace Wed, 30 July 2003 03:53 Go to previous message
Thankyou guys, I bought a seperator fork and got the idler arm off okay, but the pitman really is a pain in the arse. I am going to have to get a volunteer and try the pole and sledge hammer trick, lucky I kept that old panhard rod, perfect me thinks as a whacking stick.
Previous Topic:Jenny Craigs for MA61
Next Topic:1GEU pinouts - Wiring minded people come this way...
Current Time: Fri Nov 20 01:52:06 UTC 2026
Total time taken to generate the page: 0.005047082901001 seconds
