Toymods » Tech & Conversions » 3tg hybrid
xxaccoxx
icon5.gif  3tg hybrid Sun, 27 July 2003 03:21 Go to next message
i hav bits for the 2tg 3t hybrid. my question is can i use 2tg bits for the bottom end, or do i need to run all 3t bits in the bottom end?
reason i ask is i hav a 2tg in my car and only got some bits from a 3tc (block, crank)and i need a new engine sooner rather than later Confused
i know its a personal preference, but what cams are good to run?
should the compression influnce my choice?
and finally what engine internals should i get new (if i can)
hope the above makes sense Razz
xxaccoxx
Re: 3tg hybrid Tue, 29 July 2003 06:19 Go to previous messageGo to next message
Smile bump Smile
juzzo84
Hornsby, N.S.W
Re: 3tg hybrid Tue, 29 July 2003 07:59 Go to previous messageGo to next message
you will have to get some 3t pistons, cause you cannot use the 2tg ones with the 3t crank.
justin
Re: 3tg hybrid Tue, 29 July 2003 08:22 Go to previous messageGo to next message
xxaccoxx wrote on Sun, 27 July 2003 13:21
try toms corolla site for 2T/3T info.
cams and CR?? well, you chould choose before you start building the motor what rpm range you want it to work in. that will decide all your other choices like intake and exhaust manifolds, dry sumping etc Wink...
if you want high rpm power, then you have a cam with large overlap (and lower dynamic compression) so you need to have higher static compression. if you have a low rpm torquey motor, static compression will need to be lower etc etc..
basically, pick you rpm range and build everything around that. you will end up with a better performing motor that way Very Happy
xxaccoxx
Re: 3tg hybrid Tue, 29 July 2003 11:40 Go to previous messageGo to next message
ok, i have got the pistons and apparently they should run 11 11.5 :1 compression. so is this high rev power? what would a milder cam to suit be?
can i have another clue re: toms 2t 3t site??
Re: 3tg hybrid Tue, 29 July 2003 12:05 Go to previous messageGo to next message
hint, google for "toms corolla site" Wink
http://www.netwiz.net/~tcar/corolla.html
my stage 4 cam 275/285 with 65 deg overlap was recommended as 10:1 minimum.
for 11:1 your looking at more like 300 deg duration, which is getting up to power bands that start around 5-6000rpm.
xxaccoxx
Re: 3tg hybrid Wed, 30 July 2003 00:22 Go to previous messageGo to next message
i tried a search and got nuthin'
thanks for the cam info! i have bought this engine half done so i dont get to decide everything
xxaccoxx
icon10.gif  Re: 3tg hybrid Wed, 30 July 2003 01:13 Go to previous message
fully sic cuz! i now know what im going to do and have all the bits! Very Happy
Previous Topic:Wheel sizes (newbie question)
Next Topic:Rav4 to camry
Current Time: Fri Nov 20 06:30:09 UTC 2026
Total time taken to generate the page: 0.0062029361724854 seconds
