Toymods » Tech & Conversions » 1JZ Basics
Bounty
_Sydney _
icon3.gif  1JZ Basics Fri, 05 July 2002 09:27 Go to next message
Can any one give me some basic preferd oils sparkies etc etc, they use on there 1jz gte engine, and also some info on timing belts when should be changed and all that....... New owner of a 1jz Smiley =
Guest
Re: 1JZ Basics Fri, 05 July 2002 09:32 Go to previous messageGo to next message
I use mobil 1 5w/50 I think it is.
Plugs are NGK BKR6E
if you want the xtra expense and loss of HP then go the platinums NGK BKR6EP
use ONLY genuine filters - oil and fuel, they're worth the extra expense.
Oh and Boost, I use only 1 Bar of cool clean BOOST!!
The cool variety is better !!
Matt
[Updated on: Fri, 05 July 2002 09:33] by Moderator
jza70-mel
Perth WA
Re: 1JZ Basics Fri, 05 July 2002 11:01 Go to previous messageGo to next message
If you want to use Ryco filters for oil - z418
Valvoline V022 (?)
Change timing belt at 100,000Kms - give you mechanic plenty of notice. I got one from Gates.
I agree - nothing but synthetic oil to keep those turbos happy (double turbos = double potential troubles)
[Updated on: Sat, 06 July 2002 07:39]
Bounty
_Sydney _
Re: 1JZ Basics Sat, 06 July 2002 07:21 Go to previous messageGo to next message
Thanks for the input so far Ill probably ask more questions in the future can I get a serial number on the genuine oil filter, thanks.
TRACTION_ISSUES
Re: 1JZ Basics Sun, 07 July 2002 02:24 Go to previous messageGo to next message
Hey Anthony,
Bit of a step up from the old AE82 then ay?? Is it a Soarer or Supra?? Manual or auto??? Rolling
Bounty
_Sydney _
Re: 1JZ Basics Sun, 07 July 2002 08:27 Go to previous messageGo to next message
soarer manual Smiley =
Soarer
Wollongong
Re: 1JZ Basics Fri, 12 July 2002 06:31 Go to previous messageGo to next message
If you want a genuine filter for a 1JZ, go to your local Toyota dealer and ask for an oil filter for a 1996 Vienta V6.
There are a host of other cars that use the same filter as the 1JZ, and the Vienta is one of them.
Bounty
_Sydney _
Re: 1JZ Basics Fri, 12 July 2002 07:58 Go to previous message
Ahh cool thanks for that coz I just got the car home today and looked over the endine bay and all the buttons n stuff in the car, lots to play with something id like to know is that theres like a small rubber hose next to the excelerator pedal with a screw pluging the end of it the nrma report said something abt it 'vacum hose pluged as requierd" does any one know what thats all about? and also
the cd player doesnt work just spits out the cd after a few seconds but the tape deck works fine. The reverse sensor works alrite too. Anything else I find ill put up later as time goes on.
Previous Topic:Suspension Lights Flashing
Next Topic:Rebuild kit for 4agze
Current Time: Thu Oct 22 06:54:23 UTC 2026
Total time taken to generate the page: 0.0045130252838135 seconds
