Toymods » Tech & Conversions » Fuel lines
Henn
Rosanna, Melb
Fuel lines Sun, 27 July 2003 14:50 Go to next message
I am EFIing an oz-spec Sprinter. Got a holley blue lifting into the surge tank and a Bosch high pressure pump pulling out of that. Can I use normal carby fuel lines for tank-Holley Holley-surge and surge-Bosch? Then efi lines for the Bosch to the fuel rail and back?
Also, I plan to use the stock 6mm ID fuel pipes, will these be too restrictive for a (hopeful) 140-150kw at the fly?
Hen
Re: Fuel lines Sun, 27 July 2003 23:30 Go to previous messageGo to next message
You only need high-pressure EFI hose for the high-pressure parts of the system, ie between the Bosch pump and the fuel rail. The rest can be ordinary low-pressure stuff. 6mm will be more than enough for what you're doing.
BansheeBuzz
Gold Coast
Re: Fuel lines Mon, 28 July 2003 02:49 Go to previous messageGo to next message
Why did you use the holley blue?
You can buy lift pumps that are vertually fail proof for less than half the price of a holley and will still flow ample fuel.
pro_ke
adelaide
Re: Fuel lines Mon, 28 July 2003 03:02 Go to previous messageGo to next message
im going to get asked a similar question when people see in my boot, i have a pretty 'sik' carter pre pump that flows way more than i need
the reason i have it is because i got a very good deal on the pre pump/main pump/surge tank as a package so i will just use it.
anyway back on topic, are EFI fuel lines that much more expensive than the stock ones? i would have thought you would pull out the entire fuel system except the fuel tank and replace it with higher pressure lines?
ab
BansheeBuzz
Gold Coast
Re: Fuel lines Mon, 28 July 2003 03:05 Go to previous messageGo to next message
EFI fuel hose is alot more than standard carb fuel hose.
You will pay around $20 for efi and around $5 for ordinard fuel hose.
Re: Fuel lines Mon, 28 July 2003 04:02 Go to previous messageGo to next message
hmm, so what about the metal lines.
Norbie, you say 6mm will be fine for that kind of power?
what sort of metal tubing can be used (legally or not) for fuel tubing. afaik copper is out as the RTA thinks that it will work harden and crack with car vibrations. is aluminium ok? or will it have to be seamless steel bundy tube?
are the high pressure fittings usually threaded or banjo fittings? or can good quality hose clamps be used. fuel pressure will be about 300kpa max.
Re: Fuel lines Mon, 28 July 2003 04:18 Go to previous messageGo to next message
AFAIK steel tube is the only way to go for fuel lines. High pressure fittings are usually threaded or banjo, however you can get away with a flared pipe and good hose clamps. We're not talking really high pressures here; stock fuel pressure is less than 40psi on most cars, which is nothing really.
Henn
Rosanna, Melb
Re: Fuel lines Mon, 28 July 2003 11:16 Go to previous messageGo to next message
I'm using a Holley blue because it turned up conveniently and wasn't expensive. The entire fuel system has been replaced bar the tank and metal tubing. Hopefully should do the trick.
Hen
Seadog
Re: Fuel lines Mon, 28 July 2003 12:15 Go to previous message
You can get high pressure efi hose from edgeworth auto parts for $10/meter but it's red. Thats the cheapest I've found.
I'm nearly certain the fuel lines in my KE20 are aluminium. I bought some steel pipe to make new ones and found it was about four times the weight , and smaller ID anyway! Some new cars have plastic (probably some kind of ABS type) fuel lines. The other thing to do is go to a wrecker and get fuel lines from an XF or something big like that, and re-bend it to suit.
Previous Topic:4cyl+turbo+LPG (mrshin)
Next Topic:1GGTE error codes
Current Time: Sun Oct 25 23:23:32 UTC 2026
Total time taken to generate the page: 0.0042719841003418 seconds
