Toymods » Tech & Conversions » 6 speed supra
XTreme_Corona
adelaide
6 speed supra Thu, 16 May 2002 02:22 Go to next message
just a few questions...
1) how many rwkw's can the 6 speed handle before modifying it
2) can it be made to fit the 1uzfe
3) is the clutch run by cable or hydrolics
if it is put on the 1uzfe and has hydrolics does the 1uz have the mounting for the slave cylinder for the clutch to work
also does anyone have an idea how much it would cost for it to be matted to the 1uz
stevevp
Brisbane Qld
Re: 6 speed supra Thu, 16 May 2002 02:59 Go to previous messageGo to next message
1) Don't know, maybe Getrag in Germany can tell you. Its a V160 or V161 gearbox depending on ratios.
2) Yes, but lots of work
3) It's hydraulic and mounted on the bell-housing
There are manual kits for the 1uzfe, try Hadfields or the Castlemaine Rod Shop, but it wont be cheap!!! The box alone is worth more than my wifes car.
If anyones interested, here are the ratios
v161 v160
1 3.724 3.827
2 2.246 2.360
3 1.541 1.685
4 1.205 1.312
5 1.000 1.000
6 0.818 0.793
Re: 6 speed supra Thu, 16 May 2002 07:35 Go to previous messageGo to next message
There are Mk4 Supra's in the US running 9 second 1/4 miles with the stock 6-speed box... that makes it pretty much the strongest manual box in any production car, ever! It won't have any problems with the torque of a 1UZ.
japspec
Re: 6 speed supra Thu, 16 May 2002 08:18 Go to previous messageGo to next message
Xtreme Corona:
Not sure what stage your at with the idea of the 1uz and the supra 6 speed but if you find any good info on prices, troubles etc post it up as I'm realy interested in the use of that set up with a couple of turbos.
I reckon it'll be a killer! I started looking into it a little while ago but I haven't got the dosh at the mo, gota sell one of my cars to pony up the doe.
That set up in a Mk3 supra was just meant to be! Fair bit to think about though, but with the job done right, what a match! I've heard nothing but good things about boosting that motor to about 10psi and if you wanted to go wild then theres a hell of a lot of potential. I just dont understand why I haven't seen more conversions using a boosted 1uz, the motors are relatively cheap at $1500?
Only problem i saw was going to be the price of the 6 speed. What are they worth?
Well post it up if you get anything off the ground!
Re: 6 speed supra Fri, 17 May 2002 11:24 Go to previous messageGo to next message
I always thought that the V160 was the six-speed Getrag box from the Mk4 Supra...I was under the assumption that the V161 was the box used in the Altezza/IS200...
Can anyone clarify this for me?
humble
Brisbane, QLD
Re: 6 speed supra Fri, 17 May 2002 12:33 Go to previous messageGo to next message
I've heard some pretty bad things about the IS200 gearbox... So better make sure it's the getrag 6-speed off and Mk4 and not the IS200 box... Wreckers seem to rip people off by selling the gearbox out of the IS200 as a Supra mk4 six speed...
My 2 cents.... Smile
Re: 6 speed supra Fri, 17 May 2002 13:07 Go to previous messageGo to next message
What have you heard about the Altezza box?
faulksy
Re: 6 speed supra Fri, 17 May 2002 16:12 Go to previous messageGo to next message
I dont think your going to get into a power range to worry the 6 speed Supra box. Not when u see those power figures some yanks are putting thru them
Re: 6 speed supra Sat, 18 May 2002 04:28 Go to previous messageGo to next message
The V160 and V161 are practically identical, I think the only difference is ratios. The Altezza 6-speed is a totally different box, and it's the same one used in the S15 200SX, MX5 and S2000. It is widely regarded as one of the best RWD boxes around at the moment, and I've yet to hear anything negative about them...
Bill Sherwood
Brisbane / Gold Coast
Re: 6 speed supra Sat, 18 May 2002 14:25 Go to previous messageGo to next message
Okay, something bad - They're rather expensive! Smile
The Nissan turbo boys are running up around 400hp through them okay, I hear, so they seem to be pretty strong.
Re: 6 speed supra Sun, 19 May 2002 12:39 Go to previous messageGo to next message
I might just go have to test drive a 200SX so I can see if I like the box Smile
Guarantee the dealer is more likely to let me test one of those than a S2000 .... Razz
humble
Brisbane, QLD
Re: 6 speed supra Sun, 19 May 2002 13:57 Go to previous messageGo to next message
Norbie,
Do you know what altezza 6-speed boxes go for or even if they are fairly available at all?
I am tossing the idea of a 6-speed box for my MkII at the moment as it is gonna get a 1jz (or a 2jz) as soon as I can find a motor with vvt-i.
Re: 6 speed supra Tue, 21 May 2002 09:24 Go to previous message
I've heard rumours of Altezza 6-speeds going for about $2k, but I've never seriously looked into this so I can't confirm. I don't know about putting one behind a torquey six like the 1JZ/2JZ, remember they're only put behind relatively small engines from the factory... and of course you'd be up for a custom bellhousing to suit a JZ block, so it wouldn't be cheap by any means.
I reckon you're better off sourcing a late-model W58 with the correct bellhousing - plug and play, no fuss. The later model W58's (with the bigger input shaft) are supposed to be pretty tough.
Previous Topic:HELP What do i need to change
Next Topic:Ra23 Windows
Current Time: Wed Nov 18 05:31:05 UTC 2026
Total time taken to generate the page: 0.0062859058380127 seconds
