Toymods » Tech & Conversions » Noisy 1jz
Bogrolls
icon4.gif  Noisy 1jz Fri, 05 July 2002 10:28 Go to next message
having just taken delivery of my JZZ30, it shits me that @ under 1500rpm it has a tapping coming from under the cam cover, which disapears when revved,
is there a regular fault with the lifters in 1jz's that is easily remedied,
i have NFI having never owned a 1JZ before, the car has been sitting for 5 months and has completed 200km since delivery which should rule out the possibility of it being a sticky lifter, it also only taps once at operating temperature,
any insight to the regularity of this occuring in 1jz's and to the possible fault would be greatly appreciated
Pete
gold coast
Re: Noisy 1jz Fri, 05 July 2002 10:37 Go to previous messageGo to next message
If it has about 80000 on it, i would say it needs the cam shims done.
Bogrolls
Re: Noisy 1jz Fri, 05 July 2002 11:16 Go to previous messageGo to next message
cheers for that,
clock reckons it has 45000 but we all know thats probably wound back a bit haha
HedgehogSandwich
UK
Re: Noisy 1jz Sat, 06 July 2002 13:36 Go to previous messageGo to next message
woah...hangon before you go doing the cam shims. Most 1JZ's have very ticky injectors...if it dissapears after 1500 then nothing to worry about. Can you hear it from inside the car or with the bonnet shut? If not then its prob injectors.
adi
OB1 JZA70
Central TX USA
Re: Noisy 1jz Sat, 06 July 2002 22:28 Go to previous messageGo to next message
I just completed installing a 1JZ GTE into a US spec 87 Supra and noticed tapping for the first week or so. Once I drove the car for a long road trip it cleared up. HTH.
Orin B Sr Nod
poombah
Forrestfield, WA
Re: Noisy 1jz Mon, 23 September 2002 16:07 Go to previous messageGo to next message
mines been very tappy under the bonnet from the day I owned it (80,000kms) till now (113,000) and its still running strong. I just put it down to thats the design of the engine.
I wouldnt really worry about it. Just change the oil and filter every 5000kms, use a good synthetic oil and enjoy the beast Smile
Soarer
Wollongong
Re: Noisy 1jz Tue, 24 September 2002 09:46 Go to previous messageGo to next message
I agree with the injector noise thoery. My JZZ30 does it too. Can only hear it outside the car at idle. Have to be close to the bonnet, or have it open to hear it though.
celicamad
newcastle
Re: Noisy 1jz Thu, 26 September 2002 00:21 Go to previous message
i have heard it in about six different 1j's .With any import motor change the all after the first 1,000 k's .Then every 5,000,
mobil 1 seems to be a little noisier .After a few oil changes the noise seems to go .In my engine the shims did not require any work and by second oil change the noise is only audible on a cold engine .Sounds more like a sludge related problem to me .
one mate tried a Nulon sludge removing oil additive with great results
To identify Injector tick verses Engine noise do the old screwdriver trick against the injector rail the injectors have a MUCH different sound
Previous Topic:MODIFYING 4AGE instead of 20v / ze conversion
Next Topic:conversions and rego?
Current Time: Sat Nov 21 15:03:15 UTC 2026
Total time taken to generate the page: 0.014999151229858 seconds
