Toymods » Tech & Conversions » Jap Spec diff fitting to AE86
cswan
icon5.gif  Jap Spec diff fitting to AE86 Mon, 28 July 2003 06:21 Go to next message
I've just fitted a jap spec disc brake diff (early series) to my AE86, but there seems to be a clearance problem at the support between the tailshaft and halfshaft.
Is this usual or do I need a different tailshaft?
Is this diffential itself longer?
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Jap Spec diff fitting to AE86 Mon, 28 July 2003 11:31 Go to previous messageGo to next message
you must have a a shorter nose diff.. in which case you will require a modded half shaft
Dodgy_Haro
Re: Jap Spec diff fitting to AE86 Tue, 29 July 2003 03:45 Go to previous messageGo to next message
cswan wrote on Mon, 28 July 2003 16:21
Yes ... if you have ever seen the two piece drive shaft on a Jap spec AE86, you'd notice straightaway how much beefier the drive shaft is & the different lengths (not sure which one is longer though) ... same goes for the rear diff for that matter.
I got around my problem by getting a custom made 1 piece drive shaft which has worked fine thus far.
I have seen others adapt the existing two piece shaft to the car but I'm not sure how it was exactly done - you could ask Simon RX7 to have a look under his car for that matter ... Very Happy
Simon-AE86
Banned user
Re: Jap Spec diff fitting to AE86 Tue, 29 July 2003 04:05 Go to previous messageGo to next message
its held in by bolts Wink
acctually.. the aust 86 with single tailshaft has mounting brackets mid way half way down the chassis for the two piece unit.. it is not used tho.
cswan
Re: Jap Spec diff fitting to AE86 Wed, 30 July 2003 02:58 Go to previous message
Thanks Guys for your thoughts.
FWIW, I now believe that if I get a tailshaft from a T18 (which has the same chassis as the '86 and a longer diff) that will fit perfectly.
So it's off to pick-a-part I go. Cool
Previous Topic:jza70 vs ma70 swaybars! are they the same?
Next Topic:where can i get a 3.6 final drive set?
Current Time: Fri Nov 20 04:31:57 UTC 2026
Total time taken to generate the page: 0.004162073135376 seconds
