Toymods » Tech & Conversions » pressure/volume curve = simple maths ?
ed_ma61
Lost in the K hole
pressure/volume curve = simple maths ? Mon, 28 July 2003 08:40 Go to next message
ok, question:
2 engines; 7mge and 7mgte...
- they both have the same cam (esentially)
- they both have the same swept vol per cyl (492.3mls)
7mgte: 8.45:1 c/r = 142psi cranking pressure
7mge: 9.20:1 c/r = 156psi cranking pressure
using this data, is there anyway to extrapolate the cranking pressure for 10:1 and 11:1 respectively??
whats the curve look like?
anyone??
ed
Henn
Rosanna, Melb
Re: pressure/volume curve = simple maths ? Mon, 28 July 2003 11:25 Go to previous messageGo to next message
I have no practical experience with this, but it seems that:
Cranking pressure = atmospheric pressure * CR
thus making your problem simple. From the readings you've given, atmospheric pressure is 16.8-16.9psi for both, a bit higher than the 14.7 that's the standard. Maybe it was just a cold cold day.
So 10.0 CR = 168 psi cranking
11.0 CR = 184.8 psi cranking
Hope this makes some sense.
Hen
PS, and I think the curve will just be stretched slightly vertically.
Seadog
Re: pressure/volume curve = simple maths ? Mon, 28 July 2003 12:06 Go to previous messageGo to next message
Hmm...
That's an interesing problem. There are alot of variables in cranking pressure and it rarely directly relates to a CR. But if those variables were removed (ie same cam, bore x stroke, etc. as you mentioned) you may be able to make a rough estimate. But I think you might need more than two points to extrapolate from since it will more than likely be a curve of some order. I might ask one of my lecturers about it (I doubt they will have any answers though, they have been pretty dissapointing so far!)
IRA11Y
Club Member
Re: pressure/volume curve = simple maths ? Mon, 28 July 2003 22:35 Go to previous message
Ive got no idea Smile
but contact stuart at oldcorollas (i think thats his addy at toymods as well?) and he will most likely be able to give you an answer
Previous Topic:Camira Fuel Pump
Next Topic:2tgeu dizzy in a 2t???
Current Time: Tue Oct 27 00:43:46 UTC 2026
Total time taken to generate the page: 0.14587092399597 seconds
