Toymods » General Car Talk » Price of Koni reds compared to yellows?
Stefan
Hobart, Tas
Price of Koni reds compared to yellows? Mon, 28 July 2003 14:51 Go to next message
Genereally, are reds about the same price as the equivelant yellows, or cheaper? thanks
M Spec
Re: Price of Koni reds compared to yellows? Mon, 28 July 2003 15:12 Go to previous messageGo to next message
Koni reds will typcially be cheaper than Koni yellows.
Stefan
Hobart, Tas
Re: Price of Koni reds compared to yellows? Mon, 28 July 2003 15:14 Go to previous messageGo to next message
thanks. I know konis yellows for my car are ~265 front/165 rear each, trying to work out a ballpark figure for reds.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon1.gif  Re: Price of Koni reds compared to yellows? Mon, 28 July 2003 23:14 Go to previous messageGo to next message
Yup. Koni Yellows are more expensive 'coz they can be adjusted without taking anything off..
Stefan
Hobart, Tas
Re: Price of Koni reds compared to yellows? Tue, 29 July 2003 01:15 Go to previous messageGo to next message
No they can't. Not for the A6. That quote was for yellows, and they only come in internally adjustable.
Nark
Cabramatta, NSW
Re: Price of Koni reds compared to yellows? Tue, 29 July 2003 02:16 Go to previous messageGo to next message
You're enjoying the same amount of confusion I went through when I went to buy Konis. Very Happy
Companies don't seem to understand that the RA60, RA65, and MA61 are different cars!!
Reds are adjustable by turning the lower half of the shock. Needless to say that you have to unbolt the bottom of the shock to do this.
http://www.koni-na.com/konispecial.html
Yellows are adjustable by turning the little screw at the top of the shock. You don't need to remove anything to do this (except maybe the dust cover).
http://www.koni-na.com/konisport.html
Confusing catalogues here:
http://www.koni.com/_cars/_special/afram.html
http://www.koni.com/_cars/_sport/afram.html
wastegate
Gold Coast
Re: Price of Koni reds compared to yellows? Tue, 29 July 2003 04:02 Go to previous messageGo to next message
Nark, there are some Yellows that can not be adjusted though the top, eg the ones on my Supra.
Stefan
Hobart, Tas
Re: Price of Koni reds compared to yellows? Tue, 29 July 2003 06:51 Go to previous messageGo to next message
I understand that in principle, but don't belive it holds for ALL yellows for all cars. If you read the literature... i remember doing this once... it says SOME of their adjustables are done via a screw on top, some you have to unbolt the bottom etc etc
I got my quote from a suspension shop, and they told me that the koni yellows for my car are only internally adjustable. I queired that, 'cso i htought it would be external, and they no but they would set it up right when they install them. Now, with the rear shocks, it doens't matter that much if you have to unbolt the lower end and twist, but with stuts, internally adjustable would be a PITA.
Also.. are you talking JUST about shocks, rather than struts inserts? I thought only UBER-expensive struts could be externally adjustable
Jayem
Finland
Re: Price of Koni reds compared to yellows? Tue, 29 July 2003 18:54 Go to previous messageGo to next message
Lucky bastards! I did inquire and get price for koni reds for AE92. Price was 290¤ just for front. 290¤ is equivalent to 500AUD. There's the difference in Finnish(EU) and Australian prices Mad .
Helmann
Ipswich
Re: Price of Koni reds compared to yellows? Wed, 30 July 2003 07:57 Go to previous messageGo to next message
Koni yellows for MA70 are definately NOT externally adjustable.
I know cause i have a set.
Also, what is a koni blue?
A mate has some and i have never heard of koni blue before.
Brett.
SmellyTofu
Re: Price of Koni reds compared to yellows? Wed, 30 July 2003 08:27 Go to previous messageGo to next message
Some are externally adjustable, some are internally... I've got both... fronts are externally, rears are internally adjustable.
Check the product code of the shocks you're getting. Then check the instructions on how to adjust the shocks. That'll tell you if it's external or internal.
Stefan
Hobart, Tas
Re: Price of Koni reds compared to yellows? Wed, 30 July 2003 10:10 Go to previous messageGo to next message
IS that each, or for the pair? If it's for the pair, it's not that far off... a pair of yellow strut inserts is more than that over here.
Les
Re: Price of Koni reds compared to yellows? Mon, 04 August 2003 09:24 Go to previous messageGo to next message
Guys.. silly question, if u have these adjustable shocks, can it be used to heighten/lower your car ?
ed_ma61
Lost in the K hole
Re: Price of Koni reds compared to yellows? Mon, 04 August 2003 09:40 Go to previous messageGo to next message
no
it just adjusts the damping rate
SmellyTofu
Re: Price of Koni reds compared to yellows? Fri, 08 August 2003 14:17 Go to previous messageGo to next message
Les wrote on Mon, 04 August 2003 19:24
You'll need coilovers for that kind of application.... rebound rates is the only thing Koni is adjustable for. The bound are preset (though adjustable at the rebuild stage).
Les
icon5.gif  Re: Price of Koni reds compared to yellows? Sun, 10 August 2003 00:02 Go to previous messageGo to next message
SO u dont really need adjustable shocks,... unless u go to the track pretty often yeh ?
SmellyTofu
Re: Price of Koni reds compared to yellows? Sun, 10 August 2003 03:54 Go to previous messageGo to next message
Les wrote on Sun, 10 August 2003 10:02
Generally speaking, you're right. But then you can "tune" it for the street but of course not as aggressively as you would on the track.
Mind you I've taken my Astra on Wakefield and the shocks does do wonders from the street setup.
Also the adjustment can compensate for the general wear of the shocks so it can feel "new" again until you reach the hardest setting and you feel it's not doing its job.. and that's when a rebuild can happen.
Les
Re: Price of Koni reds compared to yellows? Sun, 10 August 2003 08:32 Go to previous messageGo to next message
sweet .. but if u wanna play with height adjustments, u gotta get them 'coilovers' right ?
SmellyTofu
Re: Price of Koni reds compared to yellows? Sun, 10 August 2003 09:39 Go to previous message
Yeap! That's right
Previous Topic:What costs involved in buying an IMPORT ?!
Next Topic:Another newbie here....
Current Time: Fri Oct 23 04:05:10 UTC 2026
Total time taken to generate the page: 0.0054268836975098 seconds
