Toymods » Tech & Conversions » Cat removal on 3SGTE
CS3086
Denmark
Cat removal on 3SGTE Mon, 28 July 2003 15:36 Go to next message
Hey..
Do anybody know how much hp. I can get if I remove the cat on a 3SGTE model carlos sainz ?
Can I feel it or what?
Any tips on that type of engine?
Jacob
Re: Cat removal on 3SGTE Mon, 28 July 2003 21:08 Go to previous messageGo to next message
You wont notice the difference unless your already getting 500hp?
JustenGT4
Re: Cat removal on 3SGTE Tue, 29 July 2003 02:53 Go to previous messageGo to next message
It all depends on your setup Jacob.
If you have a full 3 inch system already then gutting the stock cat will give you a noticeable increase in bost and therefore hp.
I have consistently have an approx 3psi boost increase between running a cat and not. This has been the same with a couple of different exhaust systems and turbos.
All those flow tests that show no drop in flow from a cat are bogus. yes at the pitiful flow bench flow they are testing theres no flow restriction but try pumping 500cfm thru it and i can guarantee you'll see a restriction. Blind freddy can see that there's not the same cross sectional area in a act as there is in a straight pipe. And even if they get close the frictional surface is orders of magnitude greater.
The short answer is yes you will see some gains, even if only in quicker spool up. How much will depend on how you have set up the rest of your exhaust system.
i should add that it's totally illegal and attracts a hefty fine if you run this setup on the street
Classique71
Colac, Victoria
Re: Cat removal on 3SGTE Tue, 29 July 2003 03:08 Go to previous messageGo to next message
justen - thats exactly what i was going to say - for a few HP - do you want to have the risk of an unroadworthy , and therefore illegal streetcar ?
If your concerned about power - just get a proper 3 dump pipe + performance exhaust made up - with a high flow cat moved back further than where the stock one is ..
youd still get a few more neddys from having none - but at least it would be legal .
Im taking this avenue before years end on mine..
Re: Cat removal on 3SGTE Tue, 29 July 2003 07:32 Go to previous messageGo to next message
Or just crank the boost up 3psi Rolling Eyes
Shteeve
near chris and murray vic
Re: Cat removal on 3SGTE Tue, 29 July 2003 07:42 Go to previous messageGo to next message
what are you guys talking about, im sure he's gonna get a whole lot more flow if he takes out the cat thats stuck in his exhaust... Rolling Eyes
Soarer
Wollongong
Re: Cat removal on 3SGTE Tue, 29 July 2003 09:21 Go to previous messageGo to next message
Guys, Jacob is from Denmark... probably not illegal to remove the cat over there.
Necros
Re: Cat removal on 3SGTE Tue, 29 July 2003 12:10 Go to previous messageGo to next message
Hey Guys,
Well I have a CS GT4 and DID gut the cat... It was a pain in the arse to do as there is covers and bolts and more covers heh But it did make an improvement over stock... I would say about 10-15hp.
Then I put a 3 1/2" downpipe on and well, huge difference. Easy double the power increase of the gutted cat.
Luke
Classique71
Colac, Victoria
Re: Cat removal on 3SGTE Wed, 30 July 2003 08:59 Go to previous messageGo to next message
the downpipe is your god Smile
btw luke - what happened to your Gt4 - did you end up selling it ?
CS3086
Denmark
Re: Cat removal on 3SGTE Wed, 30 July 2003 09:04 Go to previous messageGo to next message
Hey..
Soarer it´s also illigal in Denmark to remove the cat, but sometimes you have to be a criminal, and get some more Hp. I currently run about 14psi - 1bar but I want a little bit less spool up time of the turbo.
I think I get a 3" pipe instead of the cat.
Jacob
Thanks for all the replies Very Happy
CS3086
Denmark
Re: Cat removal on 3SGTE Wed, 30 July 2003 09:13 Go to previous messageGo to next message
Hey.
Downpipe? Is it the same as a pipe just instead of the cat? or has it some importánce for the Hp.? Confused
Jacob
Re: Cat removal on 3SGTE Wed, 30 July 2003 09:25 Go to previous messageGo to next message
The down/dump pipe bolts to the turbo then the cat bolts to the down/dump pipe.
Classique71
Colac, Victoria
Re: Cat removal on 3SGTE Wed, 30 July 2003 09:31 Go to previous messageGo to next message
Quote:
DR nick says: and the kneebone's connected to the leg bone - the leg bones connected to the anklebone , the anklebones connected to my ... wristwatch !
CS3086
Denmark
Re: Cat removal on 3SGTE Wed, 30 July 2003 09:44 Go to previous messageGo to next message
Hey
Do anybody have pictures or sites of the downpipe? Smile
Jacob
Re: Cat removal on 3SGTE Wed, 30 July 2003 09:48 Go to previous messageGo to next message
The down pipe is on the back of the turbo. Down pipe is the dump pipe.
[Updated on: Wed, 30 July 2003 09:50]
Classique71
Colac, Victoria
Re: Cat removal on 3SGTE Wed, 30 July 2003 09:51 Go to previous messageGo to next message
look up " aussie exhausts " on the net - they have off the shelf dump pipes for st185's
CS3086
Denmark
Re: Cat removal on 3SGTE Wed, 30 July 2003 09:58 Go to previous messageGo to next message
Hey.
Sorry all of my questions!
Is possible to make a downpipe yourself of a 3" pipe and place it between the cat and the turbo?
Can I feel the difference with the downpipe?
Jacob Confused
Re: Cat removal on 3SGTE Wed, 30 July 2003 10:01 Go to previous messageGo to next message
The down pipe is a pretty tricky thing to make! If you were extremly good with steel works you could possibly pull it off but you would be best buying and off the shelf item.
Classique71
Colac, Victoria
Re: Cat removal on 3SGTE Wed, 30 July 2003 10:03 Go to previous messageGo to next message
yes you can make your own - but its a turd of a job
a exhaust shop could make it - but may charge you like a wounded bull
the aussie ones a off the shelf ready to bolt up job - just buy and get fitted
CS3086
Denmark
Re: Cat removal on 3SGTE Wed, 30 July 2003 10:04 Go to previous messageGo to next message
Hey.
Do you know who fabricates it?
Mongoose,blitz,hks or?
Jacob
Classique71
Colac, Victoria
Re: Cat removal on 3SGTE Wed, 30 July 2003 10:07 Go to previous messageGo to next message
aussie exhausts do - they make it themselves
http://vs84208.serverstore.com/sto re/products/category1.inetstore
click there
Necros
Re: Cat removal on 3SGTE Thu, 31 July 2003 08:44 Go to previous message
Classique71, Ive still got the gt4 atm.. Its in this weeks Trading Post ;p
If anyone wants pics of a aussie exhaust dp installed let me know....
[Updated on: Thu, 31 July 2003 08:47]
Previous Topic:MA70 Front wheel barings + scum bag wreckers
Next Topic:Decal Removal - how to???
Current Time: Sun Nov 1 03:54:55 UTC 2026
Total time taken to generate the page: 0.0057721138000488 seconds
