Toymods » Tech & Conversions » Surging = Detonation ???
bayka
perth
Surging = Detonation ??? Tue, 29 July 2003 06:59 Go to next message
Ive got a friend who insists on telling me that every time i get fuel surge when caining corners that my engine is detonating because it is leaning out. . .
Is this correct?
He rekons im damaging my engine, but i tend to disagree. Maybe a bit of fuel starvation for a split second but thats it. Frankly i don't care, cause i never have enough money to have more than half a tank, and i can't help thrashing my car regardless Very Happy
Any constructive input appreciated Smile
Re: Surging = Detonation ??? Tue, 29 July 2003 07:55 Go to previous messageGo to next message
bayka wrote on Tue, 29 July 2003 16:59
Is this correct?
Very possible
Any fuel starvation is a very bad thing and everything should be done to stop it.
RobST162
Re: Surging = Detonation ??? Tue, 29 July 2003 08:14 Go to previous messageGo to next message
I have a immobiliser switch that I turn on when I leave my car in the city and parra and places that switches off the fuel pump. (like depressurising the fuel system by unplugging the little connector there)
but sometimes I forget that I flicked the switch and try and start the car, and obviously it turns over 3 times and then I remember.
is that bad?
Re: Surging = Detonation ??? Tue, 29 July 2003 08:19 Go to previous messageGo to next message
prolly not really.
leaning out is only really a problem at high load and/or rpm, ie under boost for turbos or WOT for NA. otherwise it just runs out of fuel and cuts.
bad example, but for victa mowers the recommended way to turn them off is to cut the fuel supply and wait till the carby runs dry.
also not having fuel pressure when starting is not really a problem. you could try to start it with the fuel system disconnected and not have problems (as long as you have oil)
i have similar thing in may car, but is carby, so i can usually make it to the nearest intersection before it dies Very Happy.
Re: Surging = Detonation ??? Tue, 29 July 2003 08:22 Go to previous messageGo to next message
Also just remember that injectors are a little like fuel pumps! They dont like running dry!!!
RobST162
Re: Surging = Detonation ??? Tue, 29 July 2003 08:30 Go to previous messageGo to next message
that is what I was worried about... when I forgot I was always like, "DOH, my injectors!." they seem to be doing ok though.. niiiice injectors
better than having a car which could be stolen in under 30 seconds though I guess
bayka
perth
Re: Surging = Detonation ??? Tue, 29 July 2003 09:54 Go to previous messageGo to next message
So even if its starved for like 0.5 seconds my engine is actually DETONATING?
Or is it just a bit starved so i loose power for an instant?
rob_RA40
c'town, NSW
Re: Surging = Detonation ??? Tue, 29 July 2003 10:10 Go to previous messageGo to next message
a lot of stuff happens in 0.5 seconds
do a little maths RPM divided by 60 seconds divided by 2 will tell u how many times the crank turn in that 0.5 seconds.
Re: Surging = Detonation ??? Tue, 29 July 2003 10:23 Go to previous messageGo to next message
oldcorollas wrote on Tue, 29 July 2003 18:19
They actually suggested doing this so that 2 stroke fuel isn't left in the carby for a prolonged period, with resultant petrol evaporation and residual 2 stroke oil left behind, making start up 2-3 weeks (or in my case, months Very Happy) later hard. Point taken however - you don't see many Victas with big holes burnt thru the piston due to detonation because of this practice.
bayka
perth
Re: Surging = Detonation ??? Tue, 29 July 2003 10:29 Go to previous messageGo to next message
ok Rob_ra40 so its clear either u don't know, or you don't want to answer my question and just be a fucking smart arse
Im sorry if im stupid, but if the engine is starved of fuel for a second im not sure how that causes detonation or premature piston explosion.
If anyone could explain this concept it'd be appreciated Smile
Re: Surging = Detonation ??? Tue, 29 July 2003 10:32 Go to previous messageGo to next message
Man don't get upset. Starving your engine of fuel is a bad thing to do. Just think of it as tuning your engine to run very very lean. Whats happens when you run an engine too lean? Well it will detonate!
[Updated on: Tue, 29 July 2003 10:33]
Re: Surging = Detonation ??? Tue, 29 July 2003 10:37 Go to previous messageGo to next message
he was answering it!
if that happens when you're thrashing your car (say 6000rpm - makes the math easy for me)
so in 1 sec, you're doing 100 revs. 100revs running lean cant be a good thing, especially if your engine is under load (ie, when you're fanging it).
2 ways to fix this. either make sure you've alwaysd got at least 10 litres in the tank when you floor it (or however much it takes), or install a surge tank. Guess which the cheaper option is Smile
bayka
perth
Re: Surging = Detonation ??? Tue, 29 July 2003 10:39 Go to previous messageGo to next message
Ok dude, soz, so when ur car runs very lean what exactly causes detonation?
I understand that running lean heats up engine due to the fuel acting as a coolant, and can cause engine to overheat, but thats about it Smile
rob_RA40
c'town, NSW
Re: Surging = Detonation ??? Tue, 29 July 2003 22:12 Go to previous messageGo to next message
i didnt mean to sound condescending, i should have placed some smilies in there Embarassed my bad.
hope theres no beef...
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Surging = Detonation ??? Wed, 30 July 2003 00:30 Go to previous messageGo to next message
lets get a couple of things straight.
Fuel cuts, sudden fuel loss etc etc where the fuel supply is cut almost straight away is not harmful to the motor. Why? there is no fuel and no combustion. therefor no detonation.
However, gradual fuel loss, blocked filters, dying pump etc etc can cause detonation as the motor is forced to run lean and then theres a cance of pre ignition (detonation)
A lot of rev limiters are fuel cuts in aftermarket ECU's (like a microtech) they arnt bad for it in the same sence as detonation.
are we clear now?
Fuel surge is bad.. its a gradual loss of fuel supply.. while every time it surges the car may not be detonating.. theres a damn good chance it can... esp if you are on redline have a massive lean out and massive detonation occurs... buy buy motor!!!
put fuel in the damn thing!
Re: Surging = Detonation ??? Wed, 30 July 2003 01:10 Go to previous messageGo to next message
Simon-MrRx7 wrote on Wed, 30 July 2003 10:30
It is harmful to the injectors though.
Simon-AE86
Banned user
Re: Surging = Detonation ??? Wed, 30 July 2003 01:16 Go to previous messageGo to next message
Not if the injectors are shut off also.
Re: Surging = Detonation ??? Wed, 30 July 2003 07:24 Go to previous messageGo to next message
I those perfect worlds Yawn
cambelt
melb
Re: Surging = Detonation ??? Wed, 30 July 2003 07:53 Go to previous messageGo to next message
With this victa thing , with the old g3 metal carb it is ok to run it right out of fuel but with the later g4 plastic carb
about 1975 to current if left without fuel in carb the plastic bits somtimes swell then leak when fuel is next turned on and more important the governer diaphram dries out and goes hard,
p/s just thought id be a smart ass.
Mr DOHC
Re: Surging = Detonation ??? Wed, 30 July 2003 11:15 Go to previous messageGo to next message
cutting off the fuel supply is the only way to turn a top fueller off
but then again they have a life expectency of 60 seconds at full throttle,
they also have no injectors as such, they have 200 garden hoses dumping into the intake Laughing
BansheeBuzz
Gold Coast
Re: Surging = Detonation ??? Wed, 30 July 2003 17:42 Go to previous message
That 1 second wont matter a shit for your engine or injectors.
Your injectors will not dry out in 1 second.
But i suggest you do something about your fuel surge as the EFI pump is more of an issue.
Previous Topic:How do u rego a car from vic to nsw?
Next Topic:Knock Sensor Circuit Design ...
Current Time: Thu Nov 19 22:54:37 UTC 2026
Total time taken to generate the page: 0.0077130794525146 seconds
