Toymods » Tech & Conversions » Diff Jumping
Danish
Diff Jumping Tue, 29 July 2003 11:54 Go to next message
Hello,
I have a GZ20 Soarer, with a 1JZ, how do I stop the diff from bouncing when it breaks traction (which is all the time). It is lowered 1" with kg/mm springs, stock shocks. 5 speed g/b, LSD.
Thanks.
TE72_Turbo
Re: Diff Jumping Tue, 29 July 2003 12:03 Go to previous messageGo to next message
screwed shocks and/or worn bushes are the first thing you should replace. I just fixed the same problem in my car with fitment of polyurethane bushes in the rear end.
Phil
Danish
Re: Diff Jumping Tue, 29 July 2003 12:46 Go to previous messageGo to next message
Last time I got Polyurethene bushes they sqeaked really badly!
So that's basically it, new bushes/shocks?
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Diff Jumping Wed, 30 July 2003 00:38 Go to previous messageGo to next message
Axle tramp is the term used for this prob.
i suggest you read my Traction Brackets thread...
Generally when you lower a vehicle you are also changing the rear geomtry... which can cause tramp.
Oh and for squeaking bushes.. use a good quality bush oil.
lumpy
Adelaide, SA
Re: Diff Jumping Wed, 30 July 2003 00:47 Go to previous messageGo to next message
Does the Soarer have an independant rear end? I notice this effect (stuttering and jumping) quite badly on my 1jz powered MA70 Supra - it has new shocks and pretty stock ride height.
I also noticed that Martin Donnon once wrote about it in HPI about his Soarer and polyurethane diff mounts/bushes didn't help at all.
The only thing I can advise is to launch at a higher RPM (seems to work in the Supra) - then it smoothly spins both rears without jumping around, but this does mean you lose some traction....and only regain it mid-way through 2nd gear!
gold28
Madrid - Spain
Re: Diff Jumping Wed, 30 July 2003 03:35 Go to previous messageGo to next message
Axle tramp occurs when the suspension cannot dissapate enough energy. It is common in high powered cars, particularly with leaf sprung live axles.
On a trailing arm live diff, traction bars wont help here, if anything they will make the problem worse.
To cure this you need to allow the car to put the energy down effectively. This means that the first thing you need to do is have a good look at all your pivot points and bushes and make sure they are in good condition. If the problem still exists, increase the damping rate of the shocks. Possibly look into rising rate springs as well. These allow you to have a relatively soft spring setup which will help with launching while still offering enough spring to stop it bottoming out.
Danish
Re: Diff Jumping Wed, 30 July 2003 03:39 Go to previous message
It was happening before I lowered it, the extra horespower did it. Thanks for your help guys, sounds like i need new rubber bushes and adjustable shocks. Although launching at higher rpm does light them up smoother.
Previous Topic:1GEU pinouts - Wiring minded people come this way...
Next Topic:jza70 vs ma70 swaybars! are they the same?
Current Time: Fri Nov 20 02:44:39 UTC 2026
Total time taken to generate the page: 0.0039918422698975 seconds
