Toymods » Tech & Conversions » 1jz/2jz camshafts?
toypro
1jz/2jz camshafts? Sat, 06 July 2002 03:26 Go to next message
Can 2jz camshafts be used in a 1j engine? I've seen both engines with the valve covers off(not in the same day) and they look pretty close, and I've been told you can use 2j cam gears on a 1j..Thanks-Eric
Re: 1jz/2jz camshafts? Sun, 07 July 2002 02:32 Go to previous messageGo to next message
Dude, do a search. This has been covered before.
toypro
Re: 1jz/2jz camshafts? Mon, 08 July 2002 03:32 Go to previous messageGo to next message
I tried a search and could not find a definte answer, only a thread pretty much asking the same thing. If anyone has tried to put 2j cams in a 1j head, please let me know. Also would a 1j benifit at all from stock(us spec)2j cams? In the US it's easy to get 2j aftermarket stuff, but very hard to get 1j stuff. I would go with aftermarket 2j cams, but would like to see if stock ones would be an improvment. Thanks.
hcca
Re: 1jz/2jz camshafts? Mon, 08 July 2002 07:35 Go to previous messageGo to next message
I could sell you some stock 2j cams if you want.. no guarantee that they'll fit though.
Re: 1jz/2jz camshafts? Mon, 08 July 2002 08:30 Go to previous message
Detailed 1JZ/2JZ cam specs were covered in a thread not long ago, but possibly on the old forum so you might want to check there? From memory there wasn't much difference between them, so probably not worth swapping in stock 2JZ cams (that's if they'll even fit).
Previous Topic:The GT-Four is undergoing surgery...
Next Topic:RA 40 diff
Current Time: Mon Oct 26 18:31:48 UTC 2026
Total time taken to generate the page: 0.23202896118164 seconds
