Classifieds » Parts Wanted » worn 3S-GTE Needed
spectral
worn 3S-GTE Needed Tue, 29 July 2003 22:45 Go to next message
hi all
I need a 3S-GTE motor for a rebuild for my GT4.
So if you have a worn 3S-GTE please let me know.
I don't need the intercooler (unless its an ST205 or ST185RC motor Smile ) or the turbo. Just the block and head which need to be in "non-terminal" condition (ie. no holes in block or warped heads etc please).
I have around $500-$1000 to spend depending on the motor.
TerryOBeirne
Redbank Plains,near Ipswi...
Re: worn 3S-GTE Needed Wed, 30 July 2003 08:31 Go to previous messageGo to next message
i have a couple left. what model do you want??.
spectral
Re: worn 3S-GTE Needed Wed, 30 July 2003 22:52 Go to previous messageGo to next message
Thanks for your reply
Pref a ST185 GT4 motor.
But I will pay a bit extra for a ST185RC with intercooler if possible.
boost
MACKAY. QLD
Re: worn 3S-GTE Needed Wed, 30 July 2003 23:37 Go to previous messageGo to next message
hows a complete st205 3sgte with 80k on it.i have one for sale now as it was used as a spare motor.wasnt goin to sell anymore but if you need will sell.askin 1200.still running still assembled missing starter dizzy so basically long motor call me on 0417722201
spectral
Re: worn 3S-GTE Needed Wed, 30 July 2003 23:44 Go to previous messageGo to next message
does that include the intercooler as well? I notice you have it for sale in the other forum.
I understand it probably wouldn't have the pump and rad for the 'cooler thou. What about the ECU?
I've just heard of problems running the ST185 ECU with the ST205 engine.
ta
boost
MACKAY. QLD
Re: worn 3S-GTE Needed Thu, 31 July 2003 00:30 Go to previous messageGo to next message
mate call me on 0417722201 or give me your number ill ring you just that i have every thing comp etc
boost
MACKAY. QLD
Re: worn 3S-GTE Needed Thu, 31 July 2003 00:48 Go to previous messageGo to next message
ok i have st205 comp (aust delivery group a)with conector plug and abt 2 inch of wiring.i have got intercooler and have got aftermarket pump if you need (ive only upgraded to bigger heat exchanger)let me know what you need.most my gear is st 205 though.
spectral
Re: worn 3S-GTE Needed Fri, 01 August 2003 05:11 Go to previous messageGo to next message
my problem with the ST205 stuff is that I'd need to install the ST205 ECU (which sounds a bit tricky), plus my Aussie dumppipe is for a twin wastgate CT26 rather than the CT20B turbo.
But the idea of an ST205 motor is VERY tempting Razz
If you don't mind, I'll just wait for Terry (above) to reply to see what he has.
boost
MACKAY. QLD
Re: worn 3S-GTE Needed Sat, 02 August 2003 15:52 Go to previous message
hey mate the twin waste gate ct26 has same bolt up as ct20b just one has one less stud .i have had both on my same exht manifold.if i didnt tell you i also have a computer .cheers
Previous Topic:WTB: EMS or Microtech LTX8 engine management
Next Topic:WTD: MA61 Factory Alloys
Current Time: Wed Oct 28 06:10:36 UTC 2026
Total time taken to generate the page: 0.0057380199432373 seconds
