Classifieds » Parts Wanted » Cold-start air bypass valve needed...
biased99
Cold-start air bypass valve needed... Wed, 30 July 2003 01:36 Go to next message
I need an air-bypass setup for the Cressida, as it's cold-start idle isn't particularly flash...The kind of thing I'm looking for is off a 22RE or 2SE (or similar).
As I understand it, it "plumbs" into the intake before and after the throttle butterfly. When the engine is cold, it allows air to by-pass the throttle, effectively "upping" the idle. When the engine warms, air is directed back thru the throttle, allowing "normal operation... (Or something like that Razz )
So, if anyone has one, or knows where I can get one, please respond here, or PM me.
Cheers!
[edit: Poor proof-reading! Razz ]
[Updated on: Wed, 30 July 2003 01:37]
biased99
Re: Cold-start air bypass valve needed... Wed, 30 July 2003 08:13 Go to previous messageGo to next message
Guys, anyone???
BansheeBuzz
Gold Coast
Re: Cold-start air bypass valve needed... Wed, 30 July 2003 17:26 Go to previous messageGo to next message
i have 1 from a 22r - where are you based?
biased99
Re: Cold-start air bypass valve needed... Wed, 30 July 2003 23:41 Go to previous messageGo to next message
Hi mate...I'm in Canberra. How much do you want for the entire thing (incl. plugs etc) + shipping?
BansheeBuzz
Gold Coast
Re: Cold-start air bypass valve needed... Thu, 31 July 2003 03:20 Go to previous messageGo to next message
$40 including postage
biased99
Re: Cold-start air bypass valve needed... Thu, 31 July 2003 03:48 Go to previous messageGo to next message
As long as it's the entire thing (in other words, I just adapt it to my existing setup, and away I go), then that would be fine.
(Naturally, it would also be excellent if the thing actually worked... Razz )
PM me and we'll work out details.
roger
Re: Cold-start air bypass valve needed... Thu, 31 July 2003 04:45 Go to previous messageGo to next message
You can get these of almost an car injected from the mid 80s backwards. If you have a pick apart go and get one. Doesn't need to be toyota, can be any bosch or nippon denso L jetronic.
biased99
Re: Cold-start air bypass valve needed... Thu, 31 July 2003 06:07 Go to previous message
roger wrote on Thu, 31 July 2003 14:45
Fair go mate, I did say that I'm Canberra Razz
I may ring around in the interim, however...
Previous Topic:...URGENT.. 1JZ AIR FLOW METER... URGENT...
Next Topic:Sx stockies
Current Time: Tue Oct 20 22:53:58 UTC 2026
Total time taken to generate the page: 0.015192031860352 seconds
