Toymods » Tech & Conversions » ma61 lights wiring
ma61 lights wiring Wed, 30 July 2003 07:55 Go to next message
I'm wondering what wire is the "parkers or headlights" 12v wire that I would hook a gauge light to.
Allan
Re: ma61 lights wiring Wed, 30 July 2003 08:26 Go to previous messageGo to next message
Depending on where your gauge is you can find it from the glovebox or cigy lighter illumination
Allan
STR8 2.8
Re: ma61 lights wiring Wed, 30 July 2003 09:33 Go to previous messageGo to next message
i used teh glove box light wires, and tapped off them. i didnt have a light in the ciggie lighteer so i cudnt use that.
one note however if you do use the glovebox, u have to tape down the switch thing that rests against the glovebox door.
when teh glovebox is opened it releases the switch and the light goes on. easy to just pull it out and tape it down so that u dun have to open the glove box to turn your gauge light on
BlackSupra
Re: ma61 lights wiring Wed, 30 July 2003 10:34 Go to previous messageGo to next message
You can also use the air con lights as well or the dash lights
what year model do you have?
BlackSupra
Re: ma61 lights wiring Wed, 30 July 2003 10:44 Go to previous messageGo to next message
www.geocities.com/ifli4u/BE_033.gif
I uploaded a pinout for the digi dash, on my account i would assume using pin 32 and 33.
ill see if i can find anything else
Light control rheostat (little n00b for the brightening of the dash)
[Updated on: Wed, 30 July 2003 10:50]
Re: ma61 lights wiring Wed, 30 July 2003 10:51 Go to previous messageGo to next message
it's an '84
I'm intalling it on the drivers a-pillar, so anything from the HUGE bundle of wires under the steering column/dash would be ideal.
but I dont mind running a wire from the ciggy lighter
BlackSupra
Re: ma61 lights wiring Wed, 30 July 2003 10:58 Go to previous messageGo to next message
Try the rheostat then, it only has a power feed when the lights are on. (im pretty sure about this but double check first)
All you need is a multimeter to find the positive and im pretty sure it only gets the positive feed when at least the parkers are on. (and it should be a simple 2 wire exercise)
ok, car newbie question
what is a rheostat?
Allan
Re: ma61 lights wiring Wed, 30 July 2003 11:03 Go to previous messageGo to next message
Adjusts the brightness of your dash lights.. make shure you grab power from the side of it thats dimmed or when you turn your gauges down your piller gauge (most likly to be the one shiting you off that you turn the brightness down) with stay full bright
Allan
Re: ma61 lights wiring Wed, 30 July 2003 11:05 Go to previous messageGo to next message
ah, that's easy - and on the side I need!
got a multimeter, so can just test voltage drop on the "rheostat" wires to see which one is the dimmer
thanks guys!
BlackSupra
Re: ma61 lights wiring Wed, 30 July 2003 11:06 Go to previous message
Sitting in the drivers seat, look to the right of the steering wheel and down a little bit
There is a black plastic nob with a little pic of a light bulb on it. Turn on your headlights, twist the nob and watch the dash get brighter and darker. Thats the rheostat, crazy word for a nob.
EDIT: Like Allan said ^ Cool
[Updated on: Wed, 30 July 2003 11:07]
Previous Topic:Knock Sensor Circuit Design ...
Next Topic:1JZ into commodore - engine mounts.
Current Time: Fri Nov 20 00:49:56 UTC 2026
Total time taken to generate the page: 0.0058720111846924 seconds
