Toymods » Tech & Conversions » ra65 ('84) gearbox and rt142 (12/85)
Asher
Northgate, QLD
ra65 ('84) gearbox and rt142 (12/85) Thu, 31 July 2003 00:39 Go to next message
I've got a corona with irs built in dec of '85 with 22R-E engine and have found a wreckers selling a gearbox from a RA65 which was built in '84.
Will the RA65 gearbox fit onto my engine??
From what I've read, my car should be the short block with digital EFI... (will check one day)
Does the '84 ra65 have the older analog efi 22r-e if so is there a difference between the 2 engines, gearbox wise?
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: ra65 ('84) gearbox and rt142 (12/85) Thu, 31 July 2003 03:48 Go to previous messageGo to next message
Best way to know for sure is to check the firewalls of both cars and compare the transmissions.
W55, W57, and W58 are interchangable.
You should be right, but check anyway.
XTreme_Corona
adelaide
Re: ra65 ('84) gearbox and rt142 (12/85) Sat, 02 August 2003 06:08 Go to previous messageGo to next message
my rt142 doesnt have the gearbox/axle codes on the firewall....
i guess they didn't think it that important at the time. is there any way to tell by looking at the gearbox which one it is?? would be nice to know!!
Re: ra65 ('84) gearbox and rt142 (12/85) Sat, 02 August 2003 14:40 Go to previous messageGo to next message
Unles you've got the Bog Warmer box in your corona! Evil or Very Mad
Re: ra65 ('84) gearbox and rt142 (12/85) Sat, 02 August 2003 23:39 Go to previous messageGo to next message
If there is no transmission code, that generally means you have a Borg Warner box. You can swap in a Celica box, but you'll need a tailshaft to match and probably other annoying little things (eg clutch line, crossmember etc).
BansheeBuzz
Gold Coast
Re: ra65 ('84) gearbox and rt142 (12/85) Sun, 03 August 2003 00:46 Go to previous messageGo to next message
there is no id for the trans on my corona either but i know it has either w55 or 57(from visual inspection)
Asher
Northgate, QLD
Re: ra65 ('84) gearbox and rt142 (12/85) Thu, 14 August 2003 00:06 Go to previous message
So even tho my corona has a 22r-e its got a different gearbox to a ra65 celica, great.
My IRS diff is out of a ra65 celica.
argh my gearbox is melting down, its got a 'grrrrrrrr' grinding sound now while accelerating in 2nd gear, it only used to happen while decelerating in 1, 2, 3, 4
So... if i get this gearbox i'll probably need to get the tail shaft as well?
Whats a clutch line? Confused
Previous Topic:Speedo replacement (A70 Supra)
Next Topic:Supra IRS Rear Hub Disassembly
Current Time: Sun Oct 25 03:41:54 UTC 2026
Total time taken to generate the page: 0.033151149749756 seconds
