Toymods » Tech & Conversions » Smoking brakes
gtman
Smoking brakes Thu, 31 July 2003 01:52 Go to next message
have noticed this over the last week or so. Mainly coming home when I stop I've seen some smoke coming from the wheel arch of my front left. I passed it off as heat build up being expelled when the car stopped, as it was pretty cold. The other thing I thought it could have been was tyres rubbing against the strut, which they have a tendancy to do as they are alittle big. This morning however when I rock up to work I see a fair bit coming again from just the front left. I have proper sized tyres on the front now so that couldn't be it, and the weather, whilst not being beach temp, wasn't frigid either. I looked underneath as best I could and saw the smoke coming out from around the disk.
Is this something to be ultra concerned about? Am I due for pad replacement? The brake pedal feels hard as a rock, although there is sometimes the car has a tendancy to move around under hard braking. Any suggestions would be much appreciated
Re: Smoking brakes Thu, 31 July 2003 02:00 Go to previous messageGo to next message
Its locking up the front tyre? Confused
gtman
Re: Smoking brakes Thu, 31 July 2003 02:14 Go to previous messageGo to next message
no, there are no tyre lockups
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Smoking brakes Thu, 31 July 2003 02:21 Go to previous messageGo to next message
I'd take everything appart and clean it all, check for any possible oil or fluids being spilled onto the rotors/pads or traces of hub grease..
gtman
Re: Smoking brakes Thu, 31 July 2003 02:28 Go to previous messageGo to next message
yeah, not a bad idea. I just hope it will take another hundred kays as I have to go home then into and out of town tonight, Placebo are playing, woot
Re: Smoking brakes Thu, 31 July 2003 02:31 Go to previous messageGo to next message
It sounds like you have a seized caliper or master cylinder. Get this seen to immediately! You don't want to muck around when it comes to your brakes.
Re: Smoking brakes Thu, 31 July 2003 02:38 Go to previous messageGo to next message
it's gonna be one of two things,
smoke form the pads, or smoke from the oil or grease.
if the pads are dragging it's cos of stuck calipers or master cylnder as norbie said.
it could alo be whel bearing, but you would prolly feel that as well.
i've had smoke from my bearings before after hard driving (it's leak out on the discs) and also had brake fires, but if it comes form normal drivin, then somethings dragging.
kits are pretty cheap and will take you an afternoon to do. i recommend pushing the pistons out while the calipers are still connected to MS tho Wink
"Sydney Clutch and Brake" in Alexandria are usually pretty good on price and availability.
edit "oh right.. Perth" Rolling Eyes
[Updated on: Thu, 31 July 2003 02:39]
gtman
Re: Smoking brakes Thu, 31 July 2003 02:53 Go to previous messageGo to next message
Norbie wrote on Thu, 31 July 2003 10:31
if its a master cylinder I'm going to be mighty pissed as I just had this repaired about 2 months ago
Mr DOHC
Re: Smoking brakes Thu, 31 July 2003 10:41 Go to previous messageGo to next message
[/quote]
if its a master cylinder I'm going to be mighty pissed as I just had this repaired about 2 months ago[/quote]
warranty to the rescue Very Happy
manipulate
Re: Smoking brakes Thu, 31 July 2003 10:56 Go to previous messageGo to next message
Yeah caliper sounds seized
take it apart lube it up etc etc
see how that goes
i only say that cause u said under hard braking your car likes to steer itself
Ta
Mani
juzzo84
Hornsby, N.S.W
Re: Smoking brakes Thu, 31 July 2003 11:23 Go to previous messageGo to next message
check for a seized caliper and also check that there are no sticks or anything like that jamed in between the rotor and the sheild at the back, cause it might be rubbing on the disk and getting really hot, but you dont see any smoke untill you stop cause when you are moving its allways behind you. this happened to a lady that came into my workshop, its just a thought
justin
Re: Smoking brakes Fri, 01 August 2003 02:24 Go to previous messageGo to next message
how was placebo? Damned concert in melbourne, I came out with a parking ticket, and a little red slip from 2 unfriendly officers! Wasn't happy...
gtman
Re: Smoking brakes Fri, 01 August 2003 03:57 Go to previous messageGo to next message
Placebo was pretty awesome. Most amount of goths I've seen in one place tho which was abit disturbing Laughing
Yeah, its definately something sticking somewhere. I just swapped some wheels over on the front today and while I could semi tighten the front right when it was off the ground, the front left would spin freely once it got past finger tight. I'll pull it apart tomorrow, today I'm concentrating on trying to get my silver car over the pits
gtman
Re: Smoking brakes Sun, 03 August 2003 09:24 Go to previous messageGo to next message
yeah its a seized caliper. Took off the wheel and had a look, and the caliper wasn't moving when I put my foot on the brakes, and the wheel wasn't turning as freely as the left. Me and my dad had a quick look around, and when I put the tyre back on it seemed to rotate alittle better then before, but obviously I'm not going to drive on it Razz Good thing one of my brothers is away for a few months so I'll use his car till either I get that fixed or my other car licensed.
About how much would I be looking at to fix this myself? As in, what would cost of equipment to fix be approx.
Thanks guys
juzzo84
Hornsby, N.S.W
Re: Smoking brakes Sun, 03 August 2003 10:09 Go to previous message
if its just a sciezed caliper slide, and its not to major, or you have to do is remove the slide from the caliper and clean and lubricate it and place it all back together
justin
Previous Topic:Toyota epc for imports
Next Topic:stripping paint off intercooler, cleaning, polishing, and checking for leaks
Current Time: Thu Oct 29 19:57:42 UTC 2026
Total time taken to generate the page: 0.0098888874053955 seconds
