Toymods » Members Rides » Joel - 3T-GTE 1977 RA28 Celica
icon14.gif  Joel - 3T-GTE 1977 RA28 Celica Thu, 16 May 2002 03:46 Go to next message
OWNER
Joel Fitzgerald
YEAR/MAKE/MODEL
1977 RA28 Toyota Celica
ENGINE HARDWARE
3T-GTE
1.8L DOHC EFI Turbo
Tuned for 20 psi Evil or Very Mad - 163rwkw
ENGINE ACCESSORIES
1mm oversized forged pistons
Fully balanced & Blueprinted
Heavy duty valve springs
ARP rod bolts
Custom made headstuds
CT20-B split pulse turbo - (20 psi boost)
Custom made JMR exhaust manifold
Custom made JMR plenum & modified runners
Autronic SMC V1.91
MSD DIS-4 with direct fire ignition (no dizzy)
550cc 13B series 5 injectors
Bar and plate intercooler (core = 400mm X 300mm)
3" inch mandrel dump pipe with separate wastegate pipe
2.5 inch mandrel bent exhaust
K&N Air Filter
550HP Bosch Pump
4 litre + JMR Surge tank with lift pump
Upgraded fuel lines (8mm)
Alloy radiator overflow tank
DRIVELINE HARDWARE
Alloy W55 5 speed gearbox
4 puck sprung brass button clutch
Lightened & balanced flywheel
Tailshaft loop
Corona MKII F series 3.9:1 Torsen LSD
SUSPENSION & STEERING
Custom designed rack 'n pinion steering
Whiteline 24mm adjustable front swaybar
Shelby 18mm rear swaybar
Pedders sports rider shocks front/rear
Noltec adjustable strut tops (Camber & Castor adjustable)
All bushes replaced with Noltec items
Toyota Corona XT130 struts
Front coilover suspension with 275lbs/in springs
1 inch lowered rear king springs
Whiteline adjustable panhard rod
BRAKES
Front -
Peugeot 604 front discs, 273mm x 20mm ventilated items
Landcruiser 4WD 4 piston callipers
Rear -
Stock rear
BODYWORK
Respray in Subaru WRC Blue Mica
ROLLING STOCK
Front:
Rims - Enkei Racing 2 piece 15x6.5
Tyres - 195/50/15
Rear:
Rims - Enkei Racing 2 piece 15x7
Tyres - 205/50/15
INTERIOR GADGETRY
HKS Turbo timer
Momo fighter wood grain steering wheel
Full re-trim (New carpet, velour door trims & hoodlining)
Custom made velour centre console
DIN53 battery moved to the boot
Splitfire gauges (Volts, Tacho, Boost, Water temp, Fuel level, Oil pressure)
STEREO COMPONENTS
Pioneer CD/MP3/MWA Player
Samsui 6x9 speakers
PLANNED MODS
(In no particular order)
3S-GTE engine
Chassis bracing (Strut bar, seam weld)
Autronic boost controller
Koni short stroke dampers
RX7 brake calipers
Revised rear spring rates
Adjustable trailing arms
Revised fuel system - internal pump?
Adjustable rear swaybar
http://img22.exs.cx/img22/4130/celicalithgow4bx.jpg
http://img22.exs.cx/img22/2637/celicalithgow12qp.jpg
http://members.optusnet.com.au/helenfitz/pictures/front%20intercooler1.jpg
http://members.optusnet.com.au/helenfitz/pictures/celica%20straight%20side.jpg
http://members.optusnet.com.au/helenfitz/pictures/celica%20rear.jpg
http://members.optusnet.com.au/helenfitz/pictures/interia.jpg
http://members.optusnet.com.au/helenfitz/pictures/silvia%20seats.jpg
http://img95.exs.cx/img95/8751/engineincar6uv.jpg
http://img95.exs.cx/img95/513/engineincar11tc.jpg
[Updated on: Thu, 31 March 2005 00:19]
mr_messy
Re: Joel - RA28 Fri, 17 May 2002 11:22 Go to previous messageGo to next message
nice job wit the car joel dude!...
i like!!
Les
Re: Joel - RA28 Thu, 30 May 2002 01:23 Go to previous messageGo to next message
Hey
how much did u spend on the paint job ?
home job or shop ?
Re: Joel - RA28 Thu, 30 May 2002 02:13 Go to previous messageGo to next message
Shop job, was 5k.
TOY77
Re: Joel - RA28 Thu, 30 May 2002 08:53 Go to previous messageGo to next message
G'day
Our cars must be almost twins
Same colour and model, mine has a 1g.
You used to live on central coast?
Stew
Re: Joel - RA28 Mon, 03 June 2002 23:33 Go to previous messageGo to next message
Howdy, would love to see some pics of your car. I actually live on the Central Coast!
TOY77
Re: Joel - RA28 Thu, 06 June 2002 08:54 Go to previous messageGo to next message
Yeah i grew up on the coast...
All my mates used to wave at you thinking you were me till they got the number plates figured out.
I'll have to get some current pics done... or better yet just catch up. Where bouts on the coast u livin? i'm in newy now but most my mates still live down the coast.
Stew
Les
Re: Joel - RA28 Thu, 13 June 2002 02:22 Go to previous messageGo to next message
Hey dood,
With your speedo and tacho, how did you get it do give you the correct readings, or have you not fixed/calibrated it yet ?
I did a 1g conversion into my ra65 and the speedo is stuffed.. Called up a mechanic and he wanted $150 to fix it for me. Is this reasonable/correct?
CrAiGzEE
south of the big smoke
Re: Joel - RA28 Mon, 04 November 2002 08:33 Go to previous messageGo to next message
hey joel what happened to ya pics?
Re: Joel - RA28 Fri, 22 November 2002 03:49 Go to previous messageGo to next message
Fixed the pics and made a few updates Smile
Re: Joel - Turbo 1977 RA28 Fri, 22 November 2002 04:04 Go to previous messageGo to next message
hey whats that red thingy with the heatsink fins on the passenger side of the eng bay?
BTW: nice 28 jeol!!
Re: Joel - Turbo 1977 RA28 Fri, 22 November 2002 04:05 Go to previous messageGo to next message
Its the MSD dis-4!
Re: Joel - Turbo 1977 RA28 Fri, 22 November 2002 05:42 Go to previous messageGo to next message
cool mate.. i thought it might've been the computer... but i didnt want to look like a complete dickhead.
EvilJack
Sutho/Hills NSW
Re: Joel - Turbo 1977 RA28 Fri, 22 November 2002 05:55 Go to previous messageGo to next message
Dont worry i thought it was an amplifier Razz
Re: Joel - Turbo 1977 RA28 Wed, 10 September 2003 05:34 Go to previous messageGo to next message
Just put a few updated pics and info..
Evil_Foetus
Ballarat, Victoria
Re: Joel - Turbo 1977 RA28 Wed, 10 September 2003 06:17 Go to previous messageGo to next message
thats gorgeous. have you got any performance times or power thingmebobs?
Re: Joel - Turbo 1977 RA28 Wed, 10 September 2003 06:20 Go to previous messageGo to next message
Here is the latest dyno sheet from the Toymods Dynoday.
http://members.optusnet.com.au/helenfitz/dyno_toymods.jpg
CLG
Perth, Western Australia
Re: Joel - Turbo 1977 RA28 Wed, 10 September 2003 06:59 Go to previous messageGo to next message
any torque figures Joel?
coronamark2
Re: Joel - Turbo 1977 RA28 Wed, 10 September 2003 07:07 Go to previous messageGo to next message
nice power curve!
i got mine dynoed 103hp with a dodgy flat spot at the start, i need to get the A/F right im going to take it to a carbie tuner sweet celica by the way i thought i was the only one who liked wood.
http://xdesign.com.au/coronamk2/interior-small.jpg
Re: Joel - Turbo 1977 RA28 Wed, 10 September 2003 07:08 Go to previous messageGo to next message
This was a previous dyno run I had.. But as you can see there are some large differences in dyno figures between dynos.
It has torque though..
http://members.optusnet.com.au/helenfitz/dyno1.jpg
CrAiGzEE
Re: Joel - Turbo 1977 RA28 Thu, 11 September 2003 04:34 Go to previous messageGo to next message
love ya work!!
still aint a 1g thou! Razz
when ya wreckon u will have the 3s in?
Re: Joel - Turbo 1977 RA28 Mon, 15 December 2003 23:20 Go to previous messageGo to next message
Just a quick update...
RA28 now has rack n pinion steering and a few other suspension goodies Smile
rockguru
Central Coast
Re: Joel - Turbo 1977 RA28 Tue, 16 December 2003 23:22 Go to previous messageGo to next message
Joel
You goota bring it around and let me have a look at it.
It looks sweet.
Mine will be coming out of the shop in a few weeks.
finney
Re: Joel - Turbo 1977 RA28 Wed, 17 December 2003 10:32 Go to previous messageGo to next message
nice car, got those same rims on my ta22
T APLUS 22
Re: Joel - Turbo 1977 RA28 Sun, 21 December 2003 21:40 Go to previous messageGo to next message
simply put, it's f**king awesome. Specially that track picture. oh the envy.
IRA11Y
Club Member
Re: Joel - Turbo 1977 RA28 Mon, 22 December 2003 10:48 Go to previous messageGo to next message
Howd the new "suspension goodies" fit up?, no dramas? feel much better on the road?. You might wanna check my members page for the replacements Wink
Re: Joel - Turbo 1977 RA28 Mon, 22 December 2003 21:41 Go to previous messageGo to next message
Mate all fitted well.. But i'll probably be looking at changing to a slightly softer setup soon. Maybe around 300lbs/in . Also the shock really needs to be shortened as there is bugger all suspension travel left.
But overall it's feeling really good on the road, much better than it ever used to anyway.
Joel
Lambolica
Northwestern Sydney
Re: Joel - Turbo 1977 RA28 Tue, 23 December 2003 00:05 Go to previous messageGo to next message
How is it for going around round abouts? Less turns?
Re: Joel - Turbo 1977 RA28 Tue, 23 December 2003 01:02 Go to previous messageGo to next message
Yeah steering ratio is unreal! Smile feels so good to drive along twisty roads.
I think turning circle is worse though which is interesting.
Maybe this is ackermann problem?
Also i'm still using the original steering stops on the control arms. Whereas I understand with rack n pinion these are not needed as the rack limits the turning. So I probably should try taking those off.
T APLUS 22
Re: Joel - Turbo 1977 RA28 Tue, 23 December 2003 14:08 Go to previous messageGo to next message
awesome. just read the spec sheet and saw the color of WRX/WRC blue. This is the color I was considering for my respray and after seeing it on yours I think I'm soundly hooked.
sated
Re: Joel - Turbo 1977 RA28 Thu, 01 April 2004 17:45 Go to previous messageGo to next message
that is a very nice looking car.
kudos to you fella.
James
Re: Joel - Turbo 1977 RA28 Fri, 02 April 2004 00:09 Go to previous messageGo to next message
Just realised none of the pics were working.. Have updated now Smile
Not many of engine as there has been some changes but don't have any pics yet - included an old one for now.
Joel
Re: Joel - Turbo 1977 RA28 Sun, 04 April 2004 03:17 Go to previous messageGo to next message
I got a tune done on the weekend with the new JMR plenum and got 163rwkw, so almost a 20kw increase at the wheels.
We were also able to run a lot more timing which has made a huge improvement on the midrange.
Also added some new engine pics Smile
tanman
Re: Joel - Turbo 1977 RA28 Sun, 04 April 2004 03:28 Go to previous messageGo to next message
Interesting looking plenum, what did that cost you?
ta23
Re: Joel - Turbo 1977 RA28 Sun, 04 April 2004 12:44 Go to previous messageGo to next message
tanman wrote on Sun, 04 April 2004 13:28
About to ask that same thing, if it is reasonably cheap I might consider doing it to mine whilst doing my turbo/intercooler upgrade.
John K
Re: Joel - Turbo 1977 RA28 Wed, 07 April 2004 00:06 Go to previous messageGo to next message
One of the best I've seen.
Come to think of it, fu@#it, nicest one ever! Laughing
Re: Joel - Turbo 1977 RA28 Wed, 07 April 2004 06:48 Go to previous messageGo to next message
Guys have a chat to Yellorolla off these forums for pricing on the plenum! It's a worth while upgrade, has made the engine feel 100% better.
Thanks all for the comments Smile
Joel
Re: Joel - Turbo 1977 RA28 Wed, 07 April 2004 06:50 Go to previous messageGo to next message
What does everyone think of these wheels? I reckon they'd suit the Celica much better than whats currently on it.
The picture doesn't do them justice, but actually have quite a dish.
http://www.roh.com.au/pages/html/nr6com.jpg
tanman
Re: Joel - Turbo 1977 RA28 Wed, 07 April 2004 07:52 Go to previous messageGo to next message
What size TB are you running?
Andy_H
Westleigh, Sydney
Re: Joel - Turbo 1977 RA28 Wed, 07 April 2004 10:47 Go to previous messageGo to next message
i wanted to get those wheels for my celica but they were abit too expensive,
i like them
Re: Joel - Turbo 1977 RA28 Wed, 07 April 2004 22:37 Go to previous messageGo to next message
Stock TB, seems to flow more than enough.
How much were the wheels ?
Andy_H
Westleigh, Sydney
Re: Joel - Turbo 1977 RA28 Fri, 09 April 2004 08:11 Go to previous messageGo to next message
couple of grand, from bob janes up at hornsby.they are expensive because roh make them for the car when they are ordered. i saw your car at northshore perfomance mufflers a couple of weeks back, looks pretty shmick.
John K
Re: Joel - Turbo 1977 RA28 Wed, 21 April 2004 04:44 Go to previous messageGo to next message
TurboRA28 wrote on Wed, 07 April 2004 16:50
Those wheels would look a milion times better Cool
magicmitch
Sydney, Shire
Re: Joel - Turbo 1977 RA28 Wed, 21 April 2004 11:29 Go to previous messageGo to next message
yeh i agree
the wheels on it now are just holding the car back from further greatness
Re: Joel - Turbo 1977 RA28 Fri, 30 April 2004 07:07 Go to previous messageGo to next message
What about these wheels? Just trying to find something in the right offset to suit the new diff.
http://www.option1garage.com.au/wheels%2015x6.5%20+34%20114.3.jpg
magicmitch
Sydney, Shire
Re: Joel - Turbo 1977 RA28 Fri, 30 April 2004 07:10 Go to previous messageGo to next message
the first set u put up are better i reakon....i cant really picture the car with those rims
Re: Joel - Turbo 1977 RA28 Fri, 30 April 2004 07:14 Go to previous messageGo to next message
Maybe these?
http://www.option1garage.com.au/BBS%204x114.3%20+45%2015x6.5.jpg
magicmitch
Sydney, Shire
Re: Joel - Turbo 1977 RA28 Fri, 30 April 2004 08:05 Go to previous messageGo to next message
yeh they might not look to shabby actually....
peewee
adelaide
Re: Joel - Turbo 1977 RA28 Fri, 30 April 2004 13:44 Go to previous messageGo to next message
they look pretty cool, has the new offset put it higher or lower? some of them pics look like fwd offset? if so there's a dude selling similar mesh ones at the moment that would look sweet on an old celica
Re: Joel - Turbo 1977 RA28 Wed, 02 June 2004 05:35 Go to previous messageGo to next message
Well I finally crossed something of the Planned Mods list Smile
I now have the F series diff in the Celica! Hopefully no more changing diff centres because I am totally over that.
I have a Torsen TrueTrak LSD centre for it, but it currently isn't installed. I want to wait until I find a 3.9:1 gearset for it. I'll get around to building up the LSD in another centre and when its all ready just swap it over.
So for now have to put up with the open centre.
The F series diff was stripped of all mounts. I moved the panhard rod mount and spring lands over from the old RA item.
The trailing arms brackets have been custom made. The lower ones are longer so the angle of the lower trailing arm can be adjusted.
As the MKII corona diff is wider so I had to change the wheel offset as my original ROH wheels wouldn't fit.
I put some Enkei lightweight wheels on the back which are +32mm . These just clear the guards.
I think the wheels really suit the car and will try and hunt down a set for the front eventually. For now will have odd wheels front / rear.
There is now also a Whiteline adjustable panhard rod to centre up the rear end nicely.
[Updated on: Wed, 02 June 2004 05:42]
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Joel - Turbo 1977 RA28 Celica Thu, 03 June 2004 10:02 Go to previous messageGo to next message
Sounds bloody good mate, any chance of a few pics? In particular the trailing arm brackets & the wheels. Smile
Did you think at all about getting rid of the panhard rod & setting up a watts link for it? You reckon it would be worth it? I know dave GZE set one up in his, dunno how hard it was.
TE72_Turbo
Re: Joel - Turbo 1977 RA28 Celica Thu, 03 June 2004 12:16 Go to previous messageGo to next message
Hey Joel, what ratio do you have now? I have 3.9:1, and may be interested in a swap.
Phil
Re: Joel - Turbo 1977 RA28 Celica Thu, 03 June 2004 13:09 Go to previous messageGo to next message
Bigworm - Here is a pic of the diff housing. Haven't taken any of wheels yet but will shortly.
I definately will setup a watts link in the future. I grabbed one off a old Ford from pick n payless. But that will be a later project Smile I think the exhaust is in the way also.
Phil, I think I have a 4.3? which is a bit odd for a MKII centre but on the gears it says 10x43 so yeah. Though the build plate said 292 which should be 4.1 ... Confusing.
http://members.optusnet.com.au/helenfitz/pictures/complete_f_empty.jpg
TE72_Turbo
Re: Joel - Turbo 1977 RA28 Celica Fri, 04 June 2004 07:56 Go to previous messageGo to next message
Nice work Smile Are those shock mounts lower as well? Would make it easier to run standard length shocks with lowered rear axle if it was.
4.3 is an odd ratio for the F series diff. I wonder what it came from?
Re: Joel - Turbo 1977 RA28 Celica Fri, 04 June 2004 12:09 Go to previous messageGo to next message
Oh yeah should have mentioned that, the shock mounts are 30mm lower. So at full droop the lowered springs are now just captive - whereas before they were not captive. Also gets the shock back to where it should be in terms of how much it is compressed at ride height.
TE72_Turbo
Re: Joel - Turbo 1977 RA28 Celica Fri, 04 June 2004 13:56 Go to previous messageGo to next message
Good move Cool
YelloRolla
On your mum!
Re: Joel - Turbo 1977 RA28 Celica Fri, 04 June 2004 14:16 Go to previous messageGo to next message
I think that I am going to come! Mate your car is coming along very sweetly.
Diff looks the goods too.
Is there some reason why you say that the gears may be 4.3? Did you calculate that?
I hope to come and see how it is all going.
adit/ I reckon that it would look great with the superlites. These are my choice for the corolla - they are used on a lot of appendix J race cars - where they look right at home on the Mustang fast back.
[Updated on: Sat, 05 June 2004 06:33]
Re: Joel - Turbo 1977 RA28 Celica Sat, 05 June 2004 23:51 Go to previous messageGo to next message
Hey mate, with the gears I thought the numbers stamped into the ring gear indicated the ratio? It had 10x43 ? Does that mean 4.3 or am I off on my thinking here? If the build plate is correct it should be 4.1 (F292)
Yeah I'd like to see what a set of superlites would look like on it. I've seen a ra28 in Bris with superlites and looked good.
Here is a few pics of the enkei wheels.
http://members.optusnet.com.au/helenfitz/pictures/enkeiwheel.jpg
http://members.optusnet.com.au/helenfitz/pictures/side_enkei_wheel.jpg
[Updated on: Sat, 05 June 2004 23:53]
Re: Joel - Turbo 1977 RA28 Celica Mon, 21 June 2004 12:16 Go to previous messageGo to next message
Another pic with the new rear wheels..
I've found another set of Enkei's for the front on Japan Yahoo.. Hope I win the bid Smile
http://members.optusnet.com.au/helenfitz/pictures/celica rear quarter.jpg
Regina
Green Point
Re: Joel - Turbo 1977 RA28 Celica Thu, 24 June 2004 09:04 Go to previous messageGo to previous message
Nice....Very Happy
Pages (3): [1  2  3  >  »]   Switch to threaded view of this topic Create a new topic Submit Reply
Previous Topic:The Witzl's new car. UZS131 Crown
Next Topic:1977 RA28 Toyota celica - The Great Rebuild
Current Time: Thu Nov 19 10:24:11 UTC 2026
Total time taken to generate the page: 0.012969970703125 seconds
