Toymods » Tech & Conversions » TA22 Brakes On Bigworms Webpage
bjkingwill
TA22 Brakes On Bigworms Webpage Thu, 31 July 2003 11:24 Go to next message
Hey guys i need to know if anyone has done a similar upgrade to their TA22 Brakes as this on website http://members.optushome.com.au/big.worm/scs/DSC00 455.jpg
The pic shows the brake fluid holder is on top of the brake booster unless i'm confused!
Can anyone explain this in more detail, my understading of braking systems is somewhat limited. So any insite would be greatly appreciated.
Is this a conversion which is combined with larger front and/or rear brakes or has this been done to create more engine bay room and to just make it look neater?
Also what motor is in this TA22 is it a 3sgte?
[Updated on: Thu, 31 July 2003 11:25]
juzzo84
Hornsby, N.S.W
Re: TA22 Brakes On Bigworms Webpage Thu, 31 July 2003 11:26 Go to previous messageGo to next message
NO NO NO, you are very confused, what you can see is the clutch master cylinder mounted along side the brake boosted, making it apear ontop, only due to the angle of the photo.
justin
Pumpkin
Toymods Board Member
Re: TA22 Brakes On Bigworms Webpage Thu, 31 July 2003 21:57 Go to previous messageGo to next message
bjkingwill
That is Yogi's car. It was a 4AGZE, now it's a 4AGTE..!! He only has one brake fluid resovoir, the other one is the clutch fluid.
[Updated on: Thu, 31 July 2003 21:57]
bjkingwill
Re: TA22 Brakes On Bigworms Webpage Fri, 01 August 2003 10:04 Go to previous messageGo to next message
Ok i think i'm still a little confused guys, i cans see that the clutch fluid resovoir is in it's standard position but on my Celica the brake fluid resovoir is mounted seperate to the brake booster. It still looks to me like yogi has mounted a resovoir on the brake booster!
Ben
Re: TA22 Brakes On Bigworms Webpage Fri, 01 August 2003 10:36 Go to previous messageGo to next message
He has just changed the master cylinder.
http://members.optushome.com.au/big.worm/scs/DSC00456.jpg
BigWorm
Turramurra, Sydney.
Re: TA22 Brakes On Bigworms Webpage Fri, 01 August 2003 17:03 Go to previous messageGo to next message
Ah, you're talking about having the reserviour bolted up next to the strut tower with a hose going to the master cylinder!
Different celicas come out with different locations for the reserviours, don't ask me why. Mine has 2 reserviours both in the master cylinder, but also has (well, it had) the holes in the panel up next to the strut tower for the remote reserviour.
Have a look around, you may be able to find something that will fit. If you pull the hose off the m.c. you'll prolly be able to bolt a couple of cups where it used to go.
Oh, & chances are yogis upgraded his m.c. Is it the tercel m.c. that is a straight swap for TA22s, or is that for sprinters?
thetoyman75
Club President
icon10.gif  Re: TA22 Brakes On Bigworms Webpage Tue, 05 August 2003 13:23 Go to previous message
Bjkingwill,
The TA22 brake master cylinder does have a remote reservoir from factory. Yogi has changed his master cylinder to a Toyota Tercel item. (Same as mine) Its simple and effective bolt on upgrade.
A T-18 Brake master will also bolt on but is apparently not as effective. ( Jamie changed his TA22 to a T-18 unit then to a Tercel unit and was happy with the end results. )
The Tercel unit does have the same size bore as the Stock TA22 but its alot more modern design and works alot better IMHO.
Yogi's car is actually no more so he may part with the brake master cylinder if he still has it. (And no it wasn't crashed just pulled apart and sold off in bits Sad )
Previous Topic:RA23 vs. TA22 rear track widths
Next Topic:TA22 blower fan replacement
Current Time: Sat Nov 21 02:18:57 UTC 2026
Total time taken to generate the page: 0.0042259693145752 seconds
