Toymods » Tech & Conversions » Gearbox leaks x3
RA28midge
Adelaide and Queenstown T...
Gearbox leaks x3 Fri, 01 August 2003 01:50 Go to next message
I have 3 leaks, one at the back where the tail shaft goes in, one from the drain plug and one from the speedo cable.
Best ways to plug these would be??
need_boost
Re: Gearbox leaks x3 Fri, 01 August 2003 02:23 Go to previous messageGo to next message
replace rear oil seal on the gearbox...
for the drain and speedo cable try using locktite (cant remember which one, the one that comes in the syringe)
RA28midge
Re: Gearbox leaks x3 Fri, 01 August 2003 03:31 Go to previous messageGo to next message
Timing chain tensioner also leaks, it seems like it is coming out of the centre hole
It is an 18RGEU head.
Re: Gearbox leaks x3 Fri, 01 August 2003 03:59 Go to previous messageGo to next message
Seems all timing chain tensioners leak. My 18RG did, my 3TG does.
There is some O-rings in there that need replacing.
RA28midge
Re: Gearbox leaks x3 Fri, 01 August 2003 04:19 Go to previous message
Are these all standard rubbers that i can get from sprints or somewhere? With the locktite, does that make it a pain in the arse to undo next time?
I can wind out the timing chain tensioner all the way and it will just come out won't it, then i just screw it back in to reinstall- nothing tricking? I don't want to have something drop off the end and fall down the front of the timing chain cover!
[Updated on: Fri, 01 August 2003 04:20]
Previous Topic:18RG Conversion
Next Topic:brake pedal feel...
Current Time: Wed Oct 28 06:12:28 UTC 2026
Total time taken to generate the page: 0.034034967422485 seconds
