Toymods » Tech & Conversions » 1JZ non turbo engine
1JZracing
1JZ non turbo engine Fri, 01 August 2003 08:34 Go to next message
does anyone know which cars and models are around with non turbo 1JZ-GE engines? and how do the cams compare to the 1JZ-GTE ones.
I am looking for a set to compare if anyone has any or knows where to find some.
[Updated on: Fri, 01 August 2003 08:36]
rob_RA40
c'town, NSW
Re: 1JZ non turbo engine Sat, 02 August 2003 00:22 Go to previous messageGo to next message
hope this helps Try This Thread
Danish
Re: 1JZ non turbo engine Sun, 09 November 2003 07:58 Go to previous messageGo to next message
That thread doesn't really help, has anyone on this forum actually put 1JZ-GE cams into a 1JZ-GTE?
I am looking at upgrading the cams or adding adjustable cam gears to gain a little, or in a cam conversion, a lot more power.
However, I do not have the money to go through with a big single or better twin turbo setup.
Any ideas?
Re: 1JZ non turbo engine Sun, 09 November 2003 10:21 Go to previous messageGo to next message
I THINK the ones to go for are the VVTi 1JZGE cams - I've got no idea about the exact details, or if they'll fit though...
However, 1JZGTE's can make more power than their standard turbo's deserve to without touching the cams anyway, in fact I doubt you'd gain a lot until you can afford some big $ bolt on parts anyway. What sort of power are you making now? and what's been done to it?
Danish
Re: 1JZ non turbo engine Sun, 09 November 2003 10:35 Go to previous messageGo to next message
Toyota Soarer GZ20 1986
1JZ-GTE from a Chaser:
MicroTech LTX12 + Hand Controller + Air, Boost, A/F Sensors.
3" Exhaust, 3" Dump Pipe, 3" Cat
HKS Air Filter + 3" Stainless Steel Intake Pipe
Celicamad Boost Controller
Thermo Fans
Approx. 185kwrw. Have to wait till next week to see the dyno sheet.
Next that I have sitting in my room:
600*300*76 Hybrid FMIC
IC Water Spray
APEXi Muffler
It has never been tuned properly also. I will proberly get it back next week.
Re: 1JZ non turbo engine Sun, 09 November 2003 11:05 Go to previous messageGo to next message
If the 2JZGE and GTE cams are anything to go by, there is SFA difference (something like 3 degrees advertised duration difference).
2JZGE VVTi cams actually have LESS lift (approx 6mm vs. 8.3mm.).
I can't comment specifically on the 1JZ but....
Danish
Re: 1JZ non turbo engine Sun, 09 November 2003 11:47 Go to previous messageGo to next message
So everywhere and everyone I've spoken to so far has said that the 1JZ-GE cams fit the 1JZ-GTE cams, but no one was exactly sure, or had done it before, and no one knows the results!
Re: 1JZ non turbo engine Sun, 09 November 2003 12:01 Go to previous messageGo to next message
I doubt it's worth the effort. People occasionally do a similar thing with 7M's, but the improvement is invariably far from impressive. I think it's a safe bet the 1JZ will be much the same, and GT's advice above is further proof.
The stock turbos are always going to be the bottleneck anyway; once they've reached their flow limit, that's it - you're not going to make any more power, no matter how big your cams are!
Re: 1JZ non turbo engine Sun, 09 November 2003 23:02 Go to previous messageGo to next message
Fit the new cooler, along with one of those separated dump pipes off of the turbo, tune it carefully, and you should net yourself a handy increase.
Danish
Re: 1JZ non turbo engine Sun, 09 November 2003 23:36 Go to previous messageGo to next message
Copy that mrshin!
rob_RA40
c'town, NSW
Re: 1JZ non turbo engine Mon, 10 November 2003 01:49 Go to previous messageGo to next message
1JZracing wrote on Fri, 01 August 2003 18:34
danish if you look closely u will find that the thread i posted up answers the first part of his question. So infact it does help.
Danish
Re: 1JZ non turbo engine Mon, 10 November 2003 04:00 Go to previous messageGo to next message
rob_RA40, that thread has nothing to do with what I was asking. That was a quote and question from 1JZracing.
What I want to know is has anyone put 1JZ-GE cams into a 1JZ-GTE, and has it made a greater difference.
So far I hear that they can be put in, but no one has done this, or seen it done.
Thanks.
BlackSupra
Re: 1JZ non turbo engine Mon, 10 November 2003 04:53 Go to previous messageGo to next message
Just get custom cams. Cool
Danish
Re: 1JZ non turbo engine Mon, 10 November 2003 04:55 Go to previous messageGo to next message
That would be thousands!
Re: 1JZ non turbo engine Mon, 10 November 2003 06:11 Go to previous messageGo to next message
Mmmm.. JUN cams
edit: $1300 the pair, not counting shipping from japan
[Updated on: Mon, 10 November 2003 06:14]
BlackSupra
Re: 1JZ non turbo engine Mon, 10 November 2003 06:16 Go to previous messageGo to next message
So list your current mods then:
Danish
Re: 1JZ non turbo engine Mon, 10 November 2003 08:25 Go to previous messageGo to next message
Who me or Draven? I just listed mine above.
BlackSupra
Re: 1JZ non turbo engine Mon, 10 November 2003 08:29 Go to previous messageGo to next message
My bad Embarassed
AS mentioned, dual dumps will be the next step.
and what about dual intakes?
Danish
Re: 1JZ non turbo engine Mon, 10 November 2003 09:02 Go to previous message
I've also got a Bosch 979 fuel pump which i forgot to mention.
Previous Topic:cam change
Next Topic:2t/3t geu cams
Current Time: Fri Oct 23 23:59:11 UTC 2026
Total time taken to generate the page: 0.0051989555358887 seconds
