Toymods » Tech & Conversions » Sprinter w/ VL/VN Fuel Pump Help
Necros
Sprinter w/ VL/VN Fuel Pump Help Fri, 01 August 2003 13:02 Go to next message
Hey Guys,
Im doing the 4age conversion on my sprinter this weekend and ive run into some problems with fuel delivery.
Ive heard it is pretty common to use Camira/VL/VN etc
The problem is. The sprinter has 6mm lines, and VL Turbo pump I have has a 12mm inlet and 8mm outlet. The 8mm fits easy enough but the 12mm is WAY off ;p And I dont know what I can use to tapper the line down?
Any sugestions?
Re: Sprinter w/ VL/VN Fuel Pump Help Fri, 01 August 2003 13:32 Go to previous messageGo to next message
easy, get a piece of brass machined at an engineering place, or by someone with a lathe...
if i had a lathe, i'd do it for ya.
Grega
melbourne.victoria.austra...
Re: Sprinter w/ VL/VN Fuel Pump Help Fri, 01 August 2003 21:15 Go to previous messageGo to next message
camira/vl yes
vn v6 no - the pump is in the tank
vn v8 yes - high pressure pump external to tank.
wouldn't most plumbing places be able to help you here?
IRA11Y
Club Member
Re: Sprinter w/ VL/VN Fuel Pump Help Fri, 01 August 2003 22:25 Go to previous messageGo to next message
goto an air tool specialist they will have brass fittings that you can adapt to make it work, repco usually has a good selection as well, they usually have one piece units that adapt from one size to another
sideshow
Re: Sprinter w/ VL/VN Fuel Pump Help Sat, 02 August 2003 11:56 Go to previous messageGo to next message
the vl commodore has a ruber hose with 90 degree bend in it
it goes from the fuel line to the vl fuel pump
one end is 12 mm the other end is 8 mm
so goto a holden dealership and ask for this hose if it will do the job
they r pretty cheap too
we always use these for goin from surge tanks to vl efi pump
so imagine an L shaped hose with a 12mm sized outlet on one end and an 8 mm outlet on the other
Necros
Re: Sprinter w/ VL/VN Fuel Pump Help Sat, 02 August 2003 13:59 Go to previous messageGo to next message
Thanks guys....
Should have the 4age running in a couple of days ;p Just gota get the hose and my shiny new red rocker covers Smile
Necros
Re: Sprinter w/ VL/VN Fuel Pump Help Sat, 02 August 2003 14:03 Go to previous messageGo to next message
Oh, does the vl run a fuel filter too? Wouldnt that be between the tank outlet and the pump?
I.E. L Shaped pipe is from the tank to the filter or its from the filter to the pump?
Ill have to be specific when ordering the part Razz
Re: Sprinter w/ VL/VN Fuel Pump Help Sat, 02 August 2003 14:29 Go to previous messageGo to next message
Although, if you still haven't sorted this, I MIGHT be able to help you out with a 'real' EFI tank to fit Very Happy
Necros
Re: Sprinter w/ VL/VN Fuel Pump Help Sat, 02 August 2003 14:32 Go to previous messageGo to next message
Real EFI tank?
...Please Explain... ;p
Oh and on the carbie tank, which is the outlet pipe? there is three of em Sad two are connected near the engine one is not.
[Updated on: Sat, 02 August 2003 14:40]
Re: Sprinter w/ VL/VN Fuel Pump Help Sat, 02 August 2003 14:43 Go to previous messageGo to next message
I might be able to get you a factory EFI tank, have to ask someone about that...
Also, if I can't get it, I've got a spare tank at my place, if you want to mod it first before you rip your car apart! Evil or Very Mad
7M-Brisbane
Re: Sprinter w/ VL/VN Fuel Pump Help Sun, 03 August 2003 02:05 Go to previous messageGo to next message
You may want to do a little more research as VL and VN pumps are completely different types. A VN is a submersible pump for a baffled EFI tank, and a VL pump is suitable for an external setup.
SPRINTAH!
Re: Sprinter w/ VL/VN Fuel Pump Help Sun, 03 August 2003 13:09 Go to previous message
the small hose coming from the engine bay is the return
one of the big ones is the vent and the other one is the supply,
blow into the big ones and the one making bubble noises is supply, or just look at whichever big one is going to the engine.
i cold be wrong as its been a while since i did it.
ill check tmrw on the car to make sure.
Previous Topic:1GGTE Power figures?
Next Topic:Difference with 1/2 Piece Tailshafts
Current Time: Sat Oct 31 23:45:11 UTC 2026
Total time taken to generate the page: 0.019899845123291 seconds
