Toymods » Tech & Conversions » best computer for 20V?
the dayo
best computer for 20V? Sun, 03 August 2003 03:25 Go to next message
i was just wondering what coumputer would be best on the 20v and how much they sell for?
Putting 20V in a sprinter and don't wont to cut the fire wall for dizzy and want to run a coil pack. would this come with the computer or would you have to buy them seperate, and how much.
any help would be great. Cheers.
sideshow
Re: best computer for 20V? Sun, 03 August 2003 05:22 Go to previous messageGo to next message
u can run an autronic haltech motec microtech
how much money u wanna spend
u will need about 2000 to 4000 bucks depending what one u buy
just ring microtech haltech or someone who sells the ecus
latest microtech is bout 1300 i think
ems stinger is round the 1000
autronic is about 1800
motec is bout 3000
then u need extras for some ecus
its not a simple case of buying an ecu and wiring it up
some need more extras than others
the dayo
Re: best computer for 20V? Mon, 04 August 2003 01:20 Go to previous messageGo to next message
what about the coil packs? whats the deal with them?
sideshow
Re: best computer for 20V? Mon, 04 August 2003 01:26 Go to previous messageGo to next message
well u still need the dizzy in the back so as u get a crank signal
or u could fit triggers to the front of the crank pulley
but if u run the dizzy just make a small cover for it since u dont need the plastic dizzy cap
then u use the aftermarket ecu to trigger the coils
if u run the twin output coils like a 4agze u will then need ignitors u can use either 2 bosch modules about 250 to 300 bucks each or if the aftermarket ecu can use the factory 4agze ignitor then u can buy one of them
u have to sit down and make sure u have priced everything u need
otherwise u could start the project and it might blow out by 1000 bucks which usually happens anyway
Youngy
Eskilstuna, Sweden
Re: best computer for 20V? Mon, 04 August 2003 01:41 Go to previous messageGo to next message
Have a look at this document:
http://www.toymods.org.au/photo//TechDocs/How%20to %20install%20a%2020v%20in%20RWD%20trim%20properly. pdf
This project has moved on from here though and currently is one step away from firing the engine.
It is using a wolf 3D (the latest version) and has come together very nicely. I myself do not know too much about the wiring side of the install. If you want to know more send a pm to seadog
10sec_rx7
Syndey
Re: best computer for 20V? Mon, 04 August 2003 03:33 Go to previous messageGo to next message
at the moment the LTX8 microtech is $1095, plus $165 for a handset or $100 for a laptop adaptor,
it uses all your factory sensors and coils, no need to buy anything else, just purchase the ECU and tuning option and wire up and away you go,
if you want more info please PM me or email dheiler@toshiba-tap.com
Dale
the dayo
Re: best computer for 20V? Fri, 08 August 2003 02:13 Go to previous messageGo to next message
sideshow,
if its not to much trouble could you list all the things needed to run an ems stinger on a 20V, not using the dizzy,
10sec_rx7
Syndey
Re: best computer for 20V? Fri, 08 August 2003 02:47 Go to previous message
im not sure that the ems stinger can talk to the toyota igniters,
microtech require no igniters as they are built in in the LTX8 model
Previous Topic:which brake master cylinder?
Next Topic:Power steering Help please fellas
Current Time: Sat Oct 31 13:21:34 UTC 2026
Total time taken to generate the page: 0.023123025894165 seconds
