Toymods » Tech & Conversions » CLUTCH ISSUES
Dnation
CLUTCH ISSUES Sun, 03 August 2003 11:28 Go to next message
Hi Guys,
I need your knowledgable expertise. I have issues with my stupid clutch in my MR2. Its a new HD Exedy import clutch made specifically for a 1996 3SGTE MR2.
My problem is when I turn the engine on, I cannot put it in gear but I can change gears when the engine is off though. If I select a gear, then start/crank the car, it will go. However when driving I cannot change gears properly. When travelling at about 50km/h in 2nd, sometimes I can put it in 3rd or 4th, but its REALLY hard and i have to force it. Putting it back into 2nd or 1st is impossible.
I have bled the hell out of the thing. I have also changed the whole secondary slave unit from the 3SGTE gearbox to the 3SGE clutch unit and its still doing the same thing.
What can be my problem?
Is it the slave? the Master? Not bled enough? Wrong installation of clutch? Fork? I am lost now and its getting on my nerves coz Im hanging to unleash my new found power.
Please help
Dave
gold28
Madrid - Spain
Re: CLUTCH ISSUES Mon, 04 August 2003 00:30 Go to previous messageGo to next message
Are you sure you put the clutch plate in the right way round. It sounds like it isn't disengaging enough
Re: CLUTCH ISSUES Mon, 04 August 2003 01:09 Go to previous messageGo to next message
Agreed. My clutch was behaving the same way when I put the clutch plate in backwards.
Dnation
Re: CLUTCH ISSUES Mon, 04 August 2003 05:31 Go to previous messageGo to next message
frig..
u just confirmed my worst fear..
I thought you cant put it the wrong way coz the flywheel gets in the way...
Oh nooooo
What happened with yours when u put it in wrong?
Re: CLUTCH ISSUES Mon, 04 August 2003 12:04 Go to previous messageGo to next message
The springs in the clutch plate were slightly damaged from grinding against the flywheel bolts. Apart from that it was all good though; I just turned the clutch plate around the right way and it all worked fine.
Dnation
Re: CLUTCH ISSUES Tue, 05 August 2003 00:43 Go to previous messageGo to next message
Hi Norbie,
Just found out that i did put the clutch plate in the right way. I checked on my old 3SGE and there is no way the plate will sit right if put in backwards. The springs knock the flywheel bolts tooo much..
So yaeh.. Thats not my problem..
Wat do u reckon?
Re: CLUTCH ISSUES Tue, 05 August 2003 00:53 Go to previous messageGo to next message
I'm out of ideas. Time to pull the box out and have a look!
gold28
Madrid - Spain
Re: CLUTCH ISSUES Tue, 05 August 2003 00:59 Go to previous messageGo to next message
Are you sure that the clutch arms are the same? It may be that the clutch you are using requires a different arm to move it more.
RA28midge
Adelaide and Queenstown T...
Re: CLUTCH ISSUES Tue, 05 August 2003 03:20 Go to previous messageGo to next message
not to be patronising but have you re-adjusted it to account for the last clutch being worn and not having as much tread and the new clutch sticking out more. it just sounds like it isn't disengageing properly.
Dnation
Re: CLUTCH ISSUES Tue, 05 August 2003 03:28 Go to previous messageGo to next message
Hi Guys,
Ok heres the latest. I went home at lunch today to check it some more. I know the clutch is in the right way. I started the engine, got my dad to push the clutch pedal down and change gears after I got a crowbar to push the fork further. I can push a further 7-10mm beyond how muich the 2ndary slave rod is pushing it. When I push it further, my dad can change gears..
From this is am guessing a few things..
- Both my 3sgte and 3sge 2ndary slave units are dead
- My master cylinder is dead
- Theres a hole in the piping thus causing air pockets all the time. have bled it soo many times to eliminate air pockets.. But they keep coming back.. HAve been through more than 500ml already...
U think one of these are the problem?
YelloRolla
On your mum!
Re: CLUTCH ISSUES Tue, 05 August 2003 04:38 Go to previous messageGo to next message
Maybe the clutch fork has slipped/been pushed off it's ball? Maybe when you were reinstalling the box. This would cause a dramatic change in the geometry. I definitely think that it is NOT the bleeding of the system. You have checked that path a few times, it is time to look elsewhere.
The last time that I put the clutch disc on backwards it undid all of my flywheel bolts Laughing laugh now, but not at the time
Ribbo
Northern Beaches
Re: CLUTCH ISSUES Tue, 05 August 2003 09:41 Go to previous messageGo to next message
could putting a clutch disc in backwards cause a squeeking noise when engaging a little like a fan belt slipping?
Re: CLUTCH ISSUES Tue, 05 August 2003 11:27 Go to previous messageGo to next message
In my case, it made a very unpleasant loud grinding sound. A squeaking noise would probably be the throwout bearing.
dispatcher
Malaysia,Kuala Lumpur
Re: CLUTCH ISSUES Thu, 07 August 2003 04:36 Go to previous messageGo to next message
I recently had this problem with my Cressida 1GGTE conversion,used the slave and master clutch pumps from the Supra including the pedals. Couldn't engage gears. Finally found out that the pedals hit the floor sooner than the GX60 ori would. So went back to original GX60 setup , WORKS FINE NOW. So in your case, check for air/oil leaks at the slave pump and master pump.It might actuall be some small adjustment somewhere.
Dnation
Re: CLUTCH ISSUES Thu, 07 August 2003 07:17 Go to previous messageGo to next message
thanks for all your help.
Figured out that everything was ok.. I just had to adjust the clutch pedal to be REALLY REALLY high... feels weird now coz it sits about 5cm higher than the brakes..
But at least i can drive the baby
BlackGT4
February 2005
Re: CLUTCH ISSUES Wed, 24 August 2005 14:50 Go to previous message
nm Neutral
[Updated on: Wed, 24 August 2005 16:29]
Previous Topic:Leaking Front Shock
Next Topic:help
Current Time: Wed Nov 18 13:46:38 UTC 2026
Total time taken to generate the page: 0.0057539939880371 seconds
