Toymods » Tech & Conversions » What kinda injectors?
Jayem
Finland
What kinda injectors? Sun, 03 August 2003 21:49 Go to next message
First I have to say Im considerable newbie with EFI's. Im trying to find some suitable injctors to my 3T. I will be running MegaSquirt and quad TB's. I allready have some minor improvements like Martelius extractor and higher CR. Cam shaft is STILL stock. Anyways I have calculated that 200cc/min would be about right. Smaller would be ok in NA but I have plans to go to forced induction.
What is the best nozzle type in my case?
High impedance is desirable?
I measured Turbo Saab injectors and lower end - the one which sits to intake manifold is 14mm - is this common diameter? I want some injectors which are commonly used and externally common size.
Are all/most of the Bosch injectors physically same size and what about NipponDenso ones? Both externally same size?
I was thinking of using later 3S-FE injectors.
here's the data...
Color: Dark-blue
Ohms: 13.8
CC/Min: 200
Test pressure kg/cm^2: 2.9
Valve hole: cone (2)
Engine: 3S-FE (87:8)
http://www.sdsefi.com/injectors.htm
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/Injectors.html
http://www.co.jyu.fi/~rax/suutin.htm
[Updated on: Sun, 03 August 2003 21:51]
Jayem
Finland
Re: What kinda injectors? Mon, 04 August 2003 19:22 Go to previous messageGo to next message
Hey! Anyone? I need to know ASAP so I can drill injector holes to my quad TB'b/manifold construction.
trent_kershaw
Re: What kinda injectors? Tue, 05 August 2003 13:34 Go to previous messageGo to next message
How do you calculate neccessary injector flow?
Re: What kinda injectors? Tue, 05 August 2003 15:10 Go to previous messageGo to next message
Jayem, also remember to consider the time available for the injector to open at high rpm.. my 1.3L will need 180-185cc/min injectors to run WOT at 8000rpm (reason is that 80% duty cycle at 8000rpm leaves 12ms for injectors to do their thing, and MS REQ Fuel is 12ms for 180-185cc/min)
you may want to check the rpm vs req fuel to see what size you need.
using the MS, low impedance is better as you can run PWM and open the injectors faster, but this is more an issue with turbo cars rather than NA.
Bosch injectors are pretty standard size, but i think Denso injectors are smaller than the bosch ones. both have a decent range of flows. google "autospeed injector flow" and that will get you a good list of injectors.
nozzle, dunno, any should be fine unless you are trying to do something tricky.
there are 4AGE injectors about the same range, and a few a little larger and smaller... both denso and bosch are commonly used and so it is a choice you gotta make as to which you can get most easily (both now and for your turbo setup later) in the right sizes....
hope this helps..
Jayem
Finland
Re: What kinda injectors? Tue, 05 August 2003 15:21 Go to previous messageGo to next message
I used this rough formula...
7 * (Estimated)Power (kW)
cm3/min = -----------------------------
Number of injectors
And here's a clip from MegaSquirt manual...
(MegaManual Version 2.02 ©2003 Bowling & Grippo Page 45)
Injector Selection
In order to properly install your MegaSquirt, you need to select and install fuel system components appropriate for your engine. Most important is that you have fuel injectors that are the correct size. Injectors that are too large will make it difficult to tune the engine at idle and cruise. Injectors that are too small can starve the engine of fuel at full power, and
seriously damage your engine. To determine how big should your injectors should be, multiply estimated horsepower (HP) of your engine by the brake specific fuel consumption (BSFC)* and divide by the number of cylinders and the desired duty cycle and you'll get a rough estimate of injector size:
InjectorSize = (HorsePower * BSFC) / (#Cylinders * DutyCycle)
for example, a 135 horsepower gasoline fuelled 4 cylinder engine with 2 throttle body
injectors and 0.55 brake specific fuel consumption gives:
(135 HP * 0.55 lb/hr/HP) / (2*.85) = ~ 43.7 lb/hr
Injectors rated between 42 and 45 lb/hr would be okay in this case.
*BSFC is usually between 0.42 and 0.58 at maximum power. Normally aspirated engines with efficient combustion processes are at the lower end of the BSFC scale [~0.45], supercharged
engines tend to be towards the higher end [~0.55].
Or you can use the following chart to select injectors based on the total horsepower of your engine and the total number of injectors:
Number of Injectors
HP 1 2 4 5 6 8
100 59 (620) 29 (305) 15 (158) 12 (126) 10 (105) -
150 88 (924) 44 (462) 22 (231) 18 (189) 15 (158) 11 (116)
200 - 59(620) 29 (305) 24 (252) 20 (210) 15 (158)
250 - 74(777) 37 (389) 29 (305) 25 (263) 18 (189)
300 - 88 (924) 44 (462) 35 (368) 29 (305) 22 (231)
350 - - 51 (534) 41 (431) 34 (357) 26 (273)
400 - - 59 (620) 47 (494) 39 (410) 29 (305)
450 - - 66 (693) 53 (557) 44 (462) 33 (347)
500 - - 74 (777) 59 (620) 49 (515) 37 (389)
550 - - 81 (851) 65 (683) 54 (567) 40 (420)
600 - - 88 (924) 71 (746) 59 (620) 44 (462)
based on 0.50 BSFC and 85% duty cycle
Supercharged engines should add 10% to listed minimum injector size.
Minimum Injector Sizes in lb/hr (& cc/min) for Gasoline Engines.
Another way to select injectors is to take them from an engine that makes nearly the same power as your engine will [assuming the same number of injectors].
Injectors seem to be rated in either lbs/hour and cc/min. The accepted conversion factor between these depends somewhat on fuel density, which changes with formulation (i.e., by
season), but the generally used conversion for gasoline is:
1 lb/hr = 10.5 cc/min
Injectors frequently have identifying numbers stamped on them. You may be able to identify
your injectors by looking on:
[[url]=urlhttp://www.geocities.com/MotorCity/Pit/9975/dat aBySubject/Injectors.html]urlhttp://www.geocities.com/MotorCity/Pit/9975/dat aBySubject/Injectors.html[/url][/url]
or
http://www.telusplanet.net/%7Echic hm/tech/injectors.pdf
Injectors should not be used at much more than 80-85% duty cycle. However, injector rates are always specified at 100% duty cycle and some nominal pressure (usually 43.5 psi = 3
atmospheres). The manufacturer leaves it up to you to determine a system pressure and maximum duty cycle in order to compute the resulting flow.
[Updated on: Tue, 05 August 2003 15:26]
Re: What kinda injectors? Tue, 05 August 2003 23:16 Go to previous message
200cc/min on a 4 cylinder will die at about 140hp - if that's your target, you're laughing. With a megasquirt,I'd keep them as small as possible to allow for whatever control you could get from it. However, if that doesn't sound like enough power for you, then you're gonna need bigger than 200cc. Much bigger!
Previous Topic:Drivetrain Loss
Next Topic:4EFE and 4EFTE
Current Time: Sat Nov 21 01:28:43 UTC 2026
Total time taken to generate the page: 0.0068578720092773 seconds
