Toymods » General Car Talk » Kill Switch
!*HeAt-SeCa*!
Kill Switch Mon, 04 August 2003 04:39 Go to next message
Does anyone know where I can get a Kill switch done in the Sydney Area?
EVOSTi
cambo
      no
Re: Kill Switch Mon, 04 August 2003 09:08 Go to previous messageGo to next message
dood, any auto elec will do it for pretty cheap its a very simple job. ill do one for you if you like im a mechanic, in denham court. if thats near you come see me if not go to thew nearest auto elec cause really its a piss easy job to do.
!*HeAt-SeCa*!
Re: Kill Switch Mon, 04 August 2003 11:19 Go to previous messageGo to next message
wats involved?
Can u give me a price?
Is it a prob if the car already has an immobiliser?
This is a precaution to stop my sister using the car.
Re: Kill Switch Mon, 04 August 2003 11:30 Go to previous messageGo to next message
You can connect the kill switch to a number of things on the engine!
Coil
Igniter
Injectors
Or all of the above Very Happy
sideshow
Re: Kill Switch Mon, 04 August 2003 14:01 Go to previous messageGo to next message
i dont like fitting kil switches to electrical things that require good power
best thing to do is fit it to hte fuel pump trigegr wire or the wire that triggers the circuit openin relay
its usually a green wire
Les
Re: Kill Switch Tue, 05 August 2003 03:30 Go to previous messageGo to next message
on an aside...
sideshow (im the fella with the 1ggte celica that didnt start and u tried helping out), just some advice for ur business - u should really replace all the things that you take off on someones car instead of just leaving the job half done. fair enough the car could not start, but at least put the bits back on u know what i am saying.
also dont say that u would give me a call when u next go to SSS automotive and pick up a part for us to try on the car - and not call ok. its bad business sense.
Im not bagging u, just givin some advice - cuz i felt it was a waste of my hard earned $100, u pulling out a few wires and leaving them out.
Les
[Updated on: Tue, 05 August 2003 03:31]
sideshow
Re: Kill Switch Tue, 05 August 2003 05:41 Go to previous messageGo to next message
yes i understand
but on the other hand yr friend who was hgoin to change the fuel pump was going to get back to me on whether the car started after changing the fuel pump
but im sure someone rang me and i said that sss didnt have any fuel pressure regulators
another thing is if u took it to a proper worshop they workj charge u haeps more than i did
specially when half the places dont know what theyre looking for
but anyway im sorry u feel this way
next time tsake it to a workshop and let me know if they r any better or cheaper
Les
Re: Kill Switch Tue, 05 August 2003 07:06 Go to previous messageGo to next message
dood - just advise for next time and your next jobs ok.. my mate was pissed that everything was left out of place...thats all
also - its not a matter of the price u charge or what the workshops charge... if you want ppl to like you for the job u do, make sure u impress them ok
then they would make recommendation etc Very Happy
EVOSTi
cambo
      no
Re: Kill Switch Tue, 05 August 2003 11:23 Go to previous messageGo to next message
heat seca,
its quite easy to do yourself, just find a wire the car needs to run. this can be a wire going to the coil, ecu, fuel pump, or if you like just the starter motor. then all you do is put a switch in the wire. cut the wire and use wire of the same size to run the switch into your car wherever you want the switch to be and use an appropriate sized switch. any easay way to see if the wire your using will work before you cut it is to simply disconnect it and see if the car will start. easy Very Happy
RobST162
Re: Kill Switch Tue, 05 August 2003 11:51 Go to previous messageGo to next message
Quote:
i dont like fitting kil switches to electrical things that require good power best thing to do is fit it to hte fuel pump trigegr wire or the wire that triggers the circuit openin relay its usually a green wire
in your car dude there is a little connector for the fuel pump under the back seats. My kill switch is linked to that. Nice and easy. No chance of screwing any other circuits and totally stops the car Smile
Little switch is hidden nicely somewhere where no one could find it Very Happy
Re: Kill Switch Tue, 05 August 2003 11:54 Go to previous messageGo to next message
We dont need to know where the switch is. You've just told us what it does Rolling Eyes Laughing
RobST162
Re: Kill Switch Tue, 05 August 2003 11:56 Go to previous messageGo to next message
oh yes. quite a point you have there Cool1. Shocked
Maybe I was just saying that to throw off anybody who would try to steal my car....
then again, if somebody is going to go to all the effort to rip my seats out deserves to steal my car. (my latches are busted on the bottom part of them)
[Updated on: Tue, 05 August 2003 11:58]
ZZT231
melbourne.vic.au
icon4.gif  Re: Kill Switch Tue, 05 August 2003 13:04 Go to previous messageGo to next message
Here is something better then a Kill switch, you can make your own immoboliser http://www.autospeed.com/cms/article.html?&A=0 059&P=1
Cheers.
Trick_T18
Earth
    n/a
Re: Kill Switch Fri, 08 August 2003 11:03 Go to previous messageGo to next message
an easy spot to run a kill switch off is your engine fuse... when they turn the key it iwll crak, but it will not fire... it confuses the hell out of the would be stealer... what area u in?
!*HeAt-SeCa*!
Re: Kill Switch Sun, 10 August 2003 06:43 Go to previous messageGo to next message
Strathfield
GIN51E
Berowra-Sydney
Re: Kill Switch Sun, 10 August 2003 08:02 Go to previous message
Go to Subaru, buy a keypad imobiliser from spares, $150 you have to enter a code before you can start the car its just like a kill switch except it connects up to 3 different circuits, ecu, fuel pump, injectors ect so they can rewire one thing but then they have a few more things they have to rewire, the keypads look good the lights flash around when its armed so it will stand out in the car an make people think twice before thinking about braking in. look under the hand break in any new WRX and you will see what i'm talking about,
also has high jack mode,
if the door gets opened and seat belt comes off while the engine is running 30sec later the engine will shut down thats then the theif is 100m down the road from you.
Previous Topic:Another newbie here....
Next Topic:Insurance For AE82
Current Time: Sat Oct 24 03:57:44 UTC 2026
Total time taken to generate the page: 0.0057859420776367 seconds
